Question about i-mate Pocket PC
PDA displays only a white Screen
I just turned off the PDA (pressed the turn off button for a long time than usual) and it displays only a white screen. It never turns off. when trying to charge the battery it is getting charged. but i'm not getting the desktop. pls give me a solution. my acer touch screen doesn't work but the screen comes up
  • 1 more comment
  • bocaj Dec 06, 2007
    blackjack screen only is white. able to call but nothing on screen visual. phone is only 3 months old. pls let me know if you can purchase new screen or how to repair.
  • simoncaccess Jan 28, 2008
    hi there. for no apparent reason I have this same problem. I can't seem to access the desktop and the screen is just white. Resetting or taking out battery does not work. Randomly pressing buttons and screen worked once but it quickly returned to whitescreen. frustrated as phone is 4 months old
  • Anonymous Nov 10, 2008
    i have the same problem turend it off whent white :(
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 146 Answers
Hi there
it seems your phone is in bootloader mode....try to softreset with stylus ...if works then fine...if not.....hard rest your pda usnig camara+recording button+power button and reset it with stylus....but you will loose your data stored on phone.....bet data on storage card will be saved........reinstall the OS (if required)...for more details...
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 15, 2008
I recently replace my lcd and initially had that problem.  I fixed it by reseating the cable that connects the motherboard to the main phone piece.  (its the cable that is about 1/2 an inch wide and is very short, barely wraps around motherboard).  Reseat that and your white screen issue should be fixed)
Posted on Jan 25, 2008
SOURCE:
I have my nokia 3660 phone when i turned it on white screen display no nokia logo display. i tried to turn off and on several times only white screen display, i tried to reformat it in phone and reprogram...
Try to hard reset it.
Turn phone off, then press and hold 'star key' , 'green call key' and 'number 3 key' all at the same time and power on phone. Release all buttons when you see 'formatting' mesaage.
Sep 19, 2010 | Nokia 3660
Sharp pda yo-370 will not turn on
okay this is what you gotta do unscrew the back of your PDA and you will see your two batteries and some stickers, in between the batteries there is a rectangle. take your screw driver and push the little bars inside the rectangle back. this will unlock your screen. if it still doesn't work hold the on button and press reset this will delete everything but also turn it on. if it still doesn't work throw PDA at wall, save up money, and get an IPad.
Apr 03, 2010 | Sharp YO-270P
Dell Axim x50v PDA turns on when screen is tapped
If your PDA turns on when u press buttons if u go to settings u choose if u want it to turn on for any button or just the main button
Aug 06, 2009 | Dell Axim X50v Pocket PC
Slow respond
The best solution to these problems is hard resetting your device. A hard reset will bring your PDA to it's factory default state, so your PDA will be as fast as it was when it was brand new. But this process will erase all your stored data (Such as adress book, messaged, appointments, tasks, pictures, ...) so you should consider having a backup of your PDA to your PC with a backup software before you hard reset your device. So later when you hard reset, you can recover the personal data with this backup file and continue using your PDA faster.
To hard reset your PDA, you must press the on/off button and reset button at the same time (reset button is a small button that needs to be pressed with your pen, and usually it is located in the bottom of the PDA). And later, wait a couple of minutes and the windows will be reinstalled and load up with the starting page of the screen alignment. After you completed all the settings, you can recover your data from your backup file (from PC).
Apr 03, 2009 | O2 Xda IIs Pocket PC
Doesn't go past start-up screen
when started and on the blue screen hold the power button down shutting it off restart it and a black screen pops up go down to start in safemode with networking that should work
Feb 15, 2009 | Dell Axim X51v Pocket PC
I was trying to move an address list from the computer to my hand held and suddenly it has Please Wait on the screen of the hand held and it will not turn off or do anything
try to hard reset
It is some time very important to Hard reset a PDA for example if you want your PDA to be factory default or or operating system corruption etc the following are the information, how to do a hard reset on every PDA as different PDA manufacturer have different methods.
To hard reset, press and hold the power button and press in on the reset button (reset hole) on the back of the unit for about 2-5 seconds. Release both buttons and you will see a confirmation screen asking you if you would like
Dec 31, 2008 | Computers & Internet
don't worry just change yur display ic ......
Aug 08, 2008 | O2 Xda IIs Pocket PC
AUDIOVOX CDA 100 AM/FM/CD setting clock
SETTING THE CLOCK - AUDIOVOX CDA-100
  1. Turn the vehicle ignition and radio "on".
  2. Press and hold the Time/Frequency Selector button approximately 2 seconds until the time display begins flashing on the display panel.
  3. Within 5 seconds after the time display begins flashing press the Manual Down Turning button (<<) to adjust the hours and the Manual Up Turning button (>>) to adjust the minutes to the correct time.
  4. Five seconds after the last hour or minute adjustment is made, the time will be set in the unit and normal operation can resume.
Contact Audiovox.com or 1-800-688-3135 and they will email (PDA) or fax a copy of the manual.
Oct 17, 2007 | Audiovox AM/FM/DVD/CD/MP3/WMA Receiver...
Hello First of all please inform me if the pda displays ONLY a white screen. Are there any characters on the screen or something like this? Does a soft-reset or a hardreset helps solving this problem ?(please try these first). I will be able to assist you better if I know the answers to these questions. If you need more informations on how to do hard/soft resets please inform me. You may also find these informations in your device's user manual. Good luck and please reply with more informations.
Sep 07, 2007 | Acer n310 Pocket PC
The Screen is back and it won't charge
Hello, it isn't that simple as a broken charger. Try the following thing. Connect battery to the PDA, check that the battery LID is connected FIRMLY to the body (there is a contact there that woun't allow the PDA to start if the lid isn't connected properly, you may want to check it too, look carefully for a small black thing and check that it can be pressed). Then connect the pda for half hour to the charger, even if no light or amber led is flashing. Then make a master reset as showed here and connect the PDA to a usb sync cable with your computer. Press simultaneous the soft reset and the power button, then press only the soft reset button. The PDA should start. If not, there is a problem with a DC converter component on the mainboard or the connector I was talking about before. Even if the charger is broken, your PDA should power on from USB cable. Good luck, feel free to ask further questions and always remember to rate replies received from this site :)
Feb 27, 2007 | HP iPAQ H2210 Pocket PC
i-mate Pocket PC Logo
503 people viewed this question
Top i-mate Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
