Question about Motorola Mobility RAZR V3i Cellular Phone
Cannot turn on bluetooth - Motorola Mobility RAZR V3i Cellular Phone
  • tabz Dec 23, 2007
    my phone cant recieve images and music via bluetooth, what seems to be the problem?
  • Anonymous Dec 25, 2007
    When trying to recieve ringtone via bluetooth I get a connection interupetion. The sender gets a "unsupported media type" message.
  • 24 Answers
U should go to settings then conectivity then bluetooth then setup then switch on
Posted on Nov 30, 2007
How do I turn on the bluetooth on my Z T PAD
You must turn on the tablet's Bluetooth radio before you can enjoy using any Bluetoothy peripherals. Here's how to activate Bluetooth on an Android tablet:
  1. Open the Settings app.
  2. On some Samsung tablets, touch the Connections tab.
  3. Ensure that the master control next to the Bluetooth item is set to On.
    Slide the icon to the right to activate.
    When Bluetooth is on, the Bluetooth status icon appears. It uses the Bluetooth logo.
To turn off Bluetooth, repeat these steps, but slide the master control to the left, to the Off position.
You'll also find a Bluetooth switch in the tablet's Quick Actions.
Dec 20, 2014 | Tablets & eReaders
Tip
How to turn Bluetooth on and off on a BlackBerry Tour
The BlackBerry Tour comes with Bluetooth capability, but in order to connect to a Bluetooth device, you have to enable the Bluetooth functionality. When you're not using a Bluetooth connection, disable Bluetooth to avoid other devices from connecting to your BlackBerry.
- To turn Bluetooth on:
From the main home screen, press the BlackBerry button (to the left of the trackball) to go to your Home folder. Scroll down until you see the antenna icon for Manage Connections and click on it. A pop up list will appear; find Bluetooth on the list and click it to put a check in the box next to it. "On" will appear next to Bluetooth, and the Bluetooth icon will be displayed in the upper right corner of the screen. Your BlackBerry is now in Bluetooth mode, where it can connect and pair with other Bluetooth-capable devices.
Bluetooth can also be turned on from the Options folder, under the Home folder. Select Bluetooth from the list and when the screen comes up saying "Bluetooth: Disabled," press the BlackBerry button and then select Enable Bluetooth. If you've previously paired your Tour with other Bluetooth devices, the list of those devices will appear.
- To turn Bluetooth off:
From the home screen, press the BlackBerry button. Scroll down to Manage Connections and select it. In the list that appears, click Bluetooth to uncheck it and disable Bluetooth functionality.
You can also turn Bluetooth off by clicking Options in the Home folder, selecting Bluetooth from the list of options, then pressing the BlackBerry button and choosing Disable Bluetooth.
on Jan 14, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Tip
How to turn Bluetooth on and off on a Samsung Intensity
Like many other cell phones, the Samsung Intensity (SCH U450) is Bluetooth-capable. Turning Bluetooth on and off on the Intensity is easy to do, as is configuring the phone's various Bluetooth options and setting up new connections.
To turn Bluetooth on, press the Menu button (the round button in the upper center of the numeric keypad). On the main menu screen, select the Settings & Tools submenu in the lower right hand corner. Then scroll down to item #3 (Bluetooth Menu) and select it.
If Bluetooth is currently disabled, the option in the lower left corner of the screen will say "Turn On." Press the left option button to turn Bluetooth on; you'll see a box pop up that says "Bluetooth power on." Now you can pair your phone with other Bluetooth devices, either by initiating a connection (choose Add New Device from the Bluetooth menu, or if you've paired with the device before, select it from the list of devices) or by making your phone discoverable (click the right option button, select Discovery Mode, and turn it on).
To disable Bluetooth, go back into the Bluetooth menu and just hit the left option button ("Turn Off"). A box will appear that says "Bluetooth power off."
If you're not sure if Bluetooth is on or off at any given time, just look at the status bar at the top of your Intensity's main screen. If you see the Bluetooth icon -- a sharply-angled white "B" on the blue background -- then Bluetooth is currently enabled.
on Oct 16, 2010 | Samsung SCH-U450 Cell Phone
How do I pair speaker with phone
turn both phone bluetooth and speaker bluetooth off. then turn them back on. the speaker's light should be flashing indicating its searching for a device to pair with. as its flashing make sure your phones bluetooth is visible and searching. they will pair and your phone will tell you and the speakers light should quit flashiing and just remain on.
Oct 20, 2014 | Audio Players & Recorders
I click 'turn adapter off' on bluetooth icon in task bar and now i cant transfer using bluetooth anymore. when i try to send file using bluetooth, message appear like this "bluetooth device not found....
you was torn off your bluetooth, go to control panel> bluetooth device and you can enabled your bluetooth device tthere
or use shortcut key Fn+F3 to turn on or turn off your bluetooth device
i hope this helpful
thank you for using fixya
Feb 08, 2011 | Acer Aspire One PC Notebook
Cannot turn on bluetooth on nokia e90. error received: cannot perform bluetooth operation.
Hi, There are a million reasons why this might happen (Nokia bluetooth is without doubt the flakiest thing on the planet). One thing that has worked for me on two different Nokia phones (particularly to solve the "continuous scanning" problem when trying to turn bluetooth on, is actually just to navigate to the bluetooth menu; turn it OFF (get the "bluetooth OFF" message) and then to turn it ON. Basically the firmware gets confused and this resets it.
Aug 28, 2010 | Nokia E90 Smartphone
How to active E500's bluetooth?
Hi tran_dat_syc.
After researching all the information online, I found the steps to enable the Bluetooth Device in the Computer.
Please follow the below steps to enable the Bluetooth Device in the Computer:
1) From the Today screen, tap the iPAQ Wireless icon located
in the Navigation bar at the bottom of the screen.
2) On the iPAQ Wireless screen, tap the Bluetooth icon.
3) When Bluetooth is turned on, the Bluetooth LED on the front of your Pocket PC flashes blue.
4) To turn off Bluetooth, tap the Bluetooth icon again. When
Bluetooth is turned off, the Bluetooth LED turns off and no
incoming or outgoing Bluetooth connections are possible.
5) Battery Saving Tip: Turn Bluetooth off when you are not using it.
For more information regarding to the Bluetooth Device, please refer to the User Guide mentioned below:
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00267893/c00267893.pdf
Please open the link above to view the User Guide.
Please refer to page 114 to 136 to view the detailed information to use the Bluetooth Device in the Computer.
Hope this helps.
Please feel free to ask for further questions.
Aug 21, 2010 | Computers & Internet
Acer Travelmate 5620 bluetooth button won't turn on
Do you actually see the Bluetooth device in device manager? Normally if it's not turned on it won't appear in device manager. The next thing I can think of is that if the Bluetooth module was not turned on when you loaded the drivers then they won't work.
And lastly the module may have come lose or unseated from the slot. Are you absolutely 100% sure there's Bluetooth hardware on this laptop? Is this built-in or a USB dongle?
If built-in have you turned it on? Acer uses a slide switch to turn Bluetooth and Wireless LAN on and off.
The first thing you probably need to establish is whether the laptop has a Bluetooth module fitted. Plenty of Acer laptops support Bluetooth in some markets and not in others and actually have slider switches to turn Bluetooth on/off but don't have the Bluetooth module fitted.
Does the unit say that it supports Bluetooth on the sticker attached to the front of the laptop? The models that have Bluetooth typically have this listed on these and will also list it on the packaging that came with the laptop that lists its specs. If it doesn't mention it odds are it's not fitted.
Acer laptops have the Bluetooth buttons, but not always have the Bluetooth Module. Check the bottom white sticker for a Bluetooth symbol under the laptop. If you do not see it, there is no Bluetooth. Also, if you press/move the Bluetooth button, and the light doesn't turn blue, there's no Bluetooth module with your laptop (only the button), so your laptop did not come with Bluetooth.
Also, you can add Bluetooth, but you need to be able to take the laptop apart to a certain extent, such as taking off the cover (top portion), keyboard, and maybe the speakers. The Bluetooth should have a 4pin, 6pin, or 8pin Bluetooth Cable connected to a Bluetooth module. You need to purchase the Bluetooth module, and install it, but you need professional help for that.
In case your laptop won't have a Bluetooth module fitted. The switch doesn't mean anything, it's present on all Acer laptops whether they have Bluetooth fitted or not.
You can buy the module as a spare part from Acer and fitting it is easy however buying a cheap USB Bluetooth dongle will be a cheaper option.
Thank You for contacting Fixya.com
Feb 02, 2010 | Computers & Internet
How di I pair my motorola H720 bluetooth to my ,
On the PHONE
Turning on and pairing a Bluetooth device
To turn on and pair a Bluetooth device, perform the following steps:
1. At the Home screen, press the Menu key.
2. Touch Settings.
3. Touch Wireless controls.
4. Touch Bluetooth to select the check-box and turn on Bluetooth.
5. Touch Bluetooth to select the check-box and turn on Bluetooth.
NOTE: The device searches for Bluetooth devices and display a list under Bluetooth devices.
6. Touch the Bluetooth device that you want to connect to.
7. If required, enter the PIN and touch OK. the Pin/passkey: 0000
On Bluetooth headset
Step A - ENSURE HEADSET IS IN PAIRING
MODE
Power on headset by sliding the Power switch
towards the microphone to initiate easy pairing. After a few moments, the indicator
light will be steadily lit in blue to indicate headset is in pairing mode.
Select OK.
Oct 25, 2009 | Apple iPhone 3G
Turning on bluetooth on a z525a
The Sony Ericsson Z525a features bluetooth. To turn it on, enter the main menu and go to CONNECTIVITY, BLUETOOTH and there turn bluetooth on. Now that the bluetooth is on you can send music files to your phone via bluetooth.
Dec 13, 2007 | Sony Ericsson Z525a Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
55 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
