Question about Lexmark X2350 All-In-One InkJet Printer
Lexmark X2350 paperjam/top cover sensor problems
I have a lexmark x2350. I installed a new printer cartridge but after i replaced the cartridge would not go back to normal postion and would not print. the computer kept giving the top is pen messages. I rechecked the cartridge to make sure there was no tape or anything else covering it and it looked fine. I replaced and same thing as before. So I powerd down computer and printer and brought both back up.I then tried to print an alignment page the paper started to feed but would feed crooked. I checked for FOD but could not find any and replaced the paper. tried printing again and this time the printer keeps saying there is a paper jam. I have looked all over the internals and have found no paper jams. My next resort is to replace the cartrdige that was installed. but if anyone else has had this issue or knows of a fix for it let me know. thanks
  • Tamie White
    Tamie White Mar 26, 2008
    I've replaced a new ink cartridge & now the paper won't feed properly. When it does catch, it pulls it crocked the right & then nothing. My lexmark all-in-one was working perfectly before I changed the ink cartridge & now I can't even get it to load paper. I've turned off the power, checked it for lose objects, even tried different paper. Does anyone have a solution to this problem?
I thought I got all FOD out of my printer, till I turned it up side down.
Pencils apparently find the x2350 very comfortable.
Posted on Jan 22, 2008
Installed a new color cartridge and it won't print and makes a funny noise when I push the on button. Can't get the cartridge to come back to the middle to check it.
Posted on Apr 02, 2008
SOURCE:
Lexmark x2350 scanner only scans a black page
Try to open the printer cover and remove the print cartridges from the printer. Close the printer. Then, unplug and re-plug the printer into the power source to reset it. When the printer turns on, reinsert the cartridges. Try to scan again.
Aug 16, 2011 | Lexmark X2350 All-In-One InkJet Printer
How to install a new ink cartridge in Lexmark 2350 printer/scanner
Perhaps the Lexmark X2350 User's Guide will be able to help you. Just click on this link to download: http://bit.ly/bNOTdZ. Scroll to Replacing the print cartridge, Page 52, for the instructions on how to install your new ink cartridge.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source.
Sep 15, 2010 | Lexmark X2350 All-In-One InkJet Printer
Lexmark X2350 does not recognise the replacement cartridge as a genuine part even though it worked for a time
It must be a genuine, original, lexmark cartridge otherwise it will always give you problems. the cheaper versions and the refilled cartridges will always give you problems. the originals cost more but they are worth the money
Jul 26, 2010 | Lexmark X2350 All-In-One InkJet Printer
How do i install the lexmark x2350 printer had not come software
nodevice.in/driver/X2350/get32636.html www.nodevice.com/driver/X2350/get32636.html www.siliconguide.com › DriversPrinterLexmark
Jun 24, 2010 | Lexmark X2350 All-In-One InkJet Printer
X2350 All-In-One InkJet Printer: How do I change the ink cartridge in a Lexmark x23...
Here's the User's Guide for your reference. Just click on this link: http://www.lexmark.com/publications/pdfs/2007/2300/2300-en.pdf . Scroll to Maintaining the All-in-One, Page 52, for instructions on how to change/replace the cartridges on the Lexmark X2350. In some cases, even when the printer is on and the cover open, the carrier doesn't position to the center. Unplug the printer from the power source. With the cover open, hold the solid white tape in the middle inside the printer. Other end of it is connected to the carrier. Slowly drag the carrier to the center loading position. Load the cartridges. Close the covers. Plug printer back to the power source. Hope this helps.
May 07, 2010 | Lexmark X2350 All-In-One InkJet Printer
Where is the ink cartridge on the lexmark x2350
open the cover while power is on. the cartridges will slide to the middle where you can reach them
Jul 13, 2009 | Lexmark X2350 All-In-One InkJet Printer
Location of ink cartridge in my lexmark x2350
The cartridge is enclosed in the cartridge carrier.
Here is a link to the Setup Sheet that shows installation of the cartridge. This is a PDF file.
X2350 Setup
Here is also a link to the User guide where it is described better. (Words AND Pictures) :-)
X2350 User Guide
Nov 07, 2008 | Lexmark X2350 All-In-One InkJet Printer
Lexmark X2350 cartridge #1
since you have bought the printer second hand, you will probably not have the installation disc which contains the drivers ( software to run it ) ..... and this is more likely to be your problem rather than only the cartridge/s ...don't worry drivers are available as free downloads, here is one such link for you
http://www.driverstock.com/Lexmark-X2350-driver-download/12-26-5476/index.html
Jan 09, 2008 | Lexmark X2350 All-In-One InkJet Printer
Lexmark x2350
I had the same problem. Put a new cartridge in and now get the error. Lexmark support couldn't fix the problem so they tried to give me 20% off on a new one. yeh right!
Nov 29, 2007 | Lexmark X2350 All-In-One InkJet Printer
Lexmark X2350 All-In-One InkJet Printer Logo
387 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
