Question about Refrigerators
Hotpoint fridge/freezer top section too warm
Bought this second hand.
There is an LCD display which gives the temp. It shows the top section as being 19degrees - and it is warm in there. I have tried lots of ways to get it cooler using the buttons (I can set watches ok) but it doesn't seem to make any difference. I suspect the chip is failed ... if it is this can I get a new one and where from?
thanks
john
More than likely you are correct, if it is digital controls your problem is in the control or the thermister in that section. there was no comment about the freezer section I assume it is ok . so i would start with the thermister. usually located by the control housing. hope this helps
Posted on Dec 01, 2007
  • 76 Answers
Is it a frost free, if so is the fan coming on when you close the door? if it isn't check around behind the fridge to see if it has two compressors, if it has is the one with the tray on it running? if not, it could be the thermostat which is inside the fridge. I hope this is helpful.
SOURCE:
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
My is SxS fridge is warm on top & freezing on bottom- both sides
there is a computer board part number WR55X10942 ,if you're in front of the fridge it's on the left hand side down near the bottom,
Mar 21, 2010 | Hotpoint HSS25GFP Side by Side...
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
My fridge is a hotpoint a fridge freezer after sitting in the garage for a while the freezer is working but the fridge is not what do i need to do
fist check the temperature of fridge,should be +2-+5c.
freezer should be between -18 to -20c.it is possible that you f/f was designed to operate between +10 to +35 degrees.most are, so as you say its in your garage/shed the ambient temp is too low for it to operate efficiently,hence fridge feels warm(compared to when it was indoors.mine is in shed with a greenhouse heater.kept at +9.....
Feb 24, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Fridge not cold
you have a fan motor and blade located between the fridge and freezer. What this fan does is regulates the temp of the fridge from the coldness of the freezer. If this fan is out the fridge will be warm. The fan is losacted in the space between the fridge and freezer on the inside near you temp control switch. Look at the top of the fridge on the inside and you will see a set of vents. The fan is located behind these slotted vents. Take care in removing the plastic cover and remove the motor. Take model and serial# to an appliance parts house for proper replacement.
Hope this helped you some
Dave
Jan 22, 2010 | Hotpoint HSS25GFP Side by Side...
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Frost free fridge hotpoint
Hot mamamia,
Huuum her to give you good advice.
You said,
When i switched the fridge on it was making a buzzing noise every few minutes kept it on for 24hrs but still did not freeze it was too warm have been changing the temp of it but still nothing . It was bought 2nd hand but was definitely working as it came from family.
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
You will be fine
Bless You huuum
Please give me the best rating at fixya .com before you sign off.
Thank You
Sep 16, 2008 | Freezers
Ffa70 hotpoint fridge freezer
Adjust the temperature control for the freezer to a normal setting. Fast freeze is only for when new products are put in that need to be frozen. This locks the system into a continuous run mode and could be responsible for the freezing condition in the refrigerator section. Check the temperatures with a thermometer as the sensor for the freezer temperature could be bad causing the light to come on.
May 18, 2008 | Hotpoint FFA70 Bottom Freezer Refrigerator
Freezer cold/fridge warm
You have a defrost issue and needs to be serviced by a qualified LG technician.  The freezer fan motor is blocked by a large chunk of ice behind the rear panel of the freezer section.  You will need to remove the rear panel to get access to the fan and get rid of the ice.  This will get your refrigerator working again but this problem will return.  You will need to have your control board replaced.
May 10, 2008 | LG LRFD25850 French Door Refrigerator
Freezer ok fridge warm (15 degrees)
You have a hotpoint mistral f/f i take it in silver..
Check to see if the fan is running at the bottom on the back of the fridge its next to the compressor behind the panel ...
if the compressor is running and the fan is not then your fault is the fan..
IF the fan is running then its the sensors...
These are located in the freezer section, pull out the draws and remove the panel behind it.... six screws.......... you will c threes plugs at the top ledt hand side.. the yellow one is for the fridge the green one for the freezer.... replace both if your freezer is not working...
Also just below the freezer door there is a panel remove the panel and use a vaccumm to clean the fluff that has built up on the coils..
hope this helps if you need anymore help dont hesitate to ask...
by the way the sensors are called evap thermistors...
Jan 10, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
