Question about Epson LQ-2180 Dot Matrix Printer
Not printing this printer was printing fine until it started this behaviour.well i tried to uninstall the printer software and tried to install again but the problem persisted.the printer reports that there is no paper when i try to print yet it was working fine and nothing happened to it.i thought and put the paper there but it still complains of the problem so i dont know what .some one told me could be the paper sensers but i'm not good at hardware of printers so thought you could helpi tried to change the printer port which was originally LPT1 and i put LPT0.when still things dint work i decided to put the port back(LPT1) but this time they were telling that it is not a valid port.so now i'm stack yet i need the printer to work.please assist me.thanks.
    New Friend:
  • 159 Answers
The paper sensor came in the left of the printer you can see it maybe stuck
Posted on Mar 22, 2008
Zebra GK420t flashing red after every print
It sounds like you have tried all the right things and are on the right track.
(You must be logged on as an administrator or a member of the Administrators group in order to complete this procedure. If your computer is connected to a network, network policy settings might also prevent you from completing this procedure)
here are a couple of simple suggestions to try for a quick fix
Try this...
Rollback or update your driver
Click on Start, open Printers and Faxes then push the F1 key on your key board.
This will open the Help and Support Center.
Now type in drivers in the search bar, this should bring up most of the information you need to update your printer drivers.
Not getting anywhere...
Try this... Unplug the printer and any other additional device connected to your PC.
Check that you have the original installation CD for the printer, then
Uninstall all the printer software
Restart your PC and DO NOT plug the printer back in yet.
Install the printers software from the CD.
It should get to a stage in the installation and ask you to plug the printer in, do this now. after that just follow the instructions on the screen and you should be up and printing again.
You may need to restart your computer after installation is complete, its OK to leave the CD in the player (unless you are instructed to remove it) and leave the printer plugged in at this stage.
There are a lot of variables, other options and other ways of doing this, so if you have the patience keep reading up on it and trying different things.
good luck
Feb 07, 2014 | Zebra Gk420t Direct Thermal/thermal...
Got to work this morning and the thermal printer had continuously printed the previous days manifest until it had run out of labels. I inserted new labels and it started to print the manifest again. I...
Uninstall the printer and restart the computer once installed reinstall the printer from the CD that came with the printer or get the latest software / pilots from the printer's web page
Jul 21, 2011 | Datamax E-CLASS DMX-E-4203 Label Printer
I downloaded the software for the HP PhotoSmart C4480 on my Mac but when I try to print I get an error message that says Operation Could Not Be Completed client-error-not-possible. Is there a way to fix...
Are you sure that you downloaded the correct file ?
Please check to make sure.
If you did, then let's try uninstalling it and installing it again with a clean install.
>Turn off the Printer and unplug it from the computer.
> Go to Start/Control Panel>Install.Uninstall and scroll down until you find the printer software.
>Highlight it and Uninstall it.
>Turn off all running programs including your internet and virus control.
>Go to the file that you downloaded. It should be an 'exe' file. I always save mine to my desktop, so that I can find them. ( If you cannot locate the file you will need to download it again and save it to your desktop this time)Click on the file to install your software. When it is installed plug your printer back in to you PC and restart your PC.
Be sure to restart you virus control if it does not start automatically.
Try a print.
Please let us know if this works for you. Thank you.
Dec 21, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Catridge block
The issue you have described regarding your printer is mainly due some dirt on the printer drum, As most of the issues like this get solved when you clean the Drum, However before you start troubleshooting your printer you should try few steps to check where actually the issue lies is it the Drum or the cartridge or is it with the driver software or even with the document file software program that you are trying to print form, so try these steps below to know where the issue lies here is what you need to do,
Try to scan and print a document, by using the copy option on the printer control panel directly (Check if the print is good, if so then the issue is with either the printer driver or the document software you are trying to print).
If you find that the print output is the same which means the printer again printed a complete black page try to clean the Drum of the printer with a soft dry cloth. Please make sure that you completely disconnect the printer power cord and leave the printer powered off for sometime before you remove the printer cartridge
and clean the Drum.
Alternately you can also try the old cartridge if you still have it with you just to check if the print out is fine with it, with this we can isolate the issue as we will come to know that the Toner cartridge is gone bad and you can then replace it.
However if you find the copy was fine then you can try printing a test page and check if its good. (If you find that if the test page prints okay, then try printing any other document form a different program however if you find that the test page looks like the same I mean if it is completely black then you can try to uninstall the driver and reinstall it again).
Here is how you can uninstall the driver and reinstall it.
  1. Click on start, point to control panel and click on control panel.
  2. Click on Add/Remove icon and select the printer driver and click o remove.
  3. After the un-installation wizard is complete close all the windows and disconnect the printer form the computer.
  4. Insert the driver disk in the Disk drive and install the driver.
Note: Do not connect the printer to the computer until the installation wizard asks you to do so.
If the document prints fine, you will then have to check the setting of the software programe that you were trying to print form earlier or even you can try to uninstall and reinstall the program to fix the issue.
Jul 16, 2010 | HP OfficeJet Pro 1170c InkJet Printer
When I install the D7260 printer using the CD-Rom supplied it works fine. Then after a few days only the top two or three lines of the first page are printed and, after a long pause, the sheet comes out....
Many issues are caused when the HP Photosmart is connected to computer using a USB cable before the HP Photosmart software is installed on the computer. IF you connected the HP Photo smart to your computer before the software installation screen prompts you to do so, you must follow these steps.
Troubleshooting common setup issues :
1) Discoonect the USB cable from the computer.
2) Uninstall the software (if you have already installed it.)
3) Restart you computer.
4) Turn off the HP Photosmartm wait one minute then turn it on.
5) Reinstall the HP Photosmart software.
If your installation is incomplete, or if you connected the USB cable to the computer before prompted by the software installation screen, you might need to uninstall and reinstall the software. Do not simply delete the Hp Photosmart application files from your computer. Make sure to remove them properly using the uninstall utility provided when you installed the software that came with the HP Photosmart.
To uninstall from a Window computer and then reinstall
1) On the Windows taskbar, click Start, Settings, Control Panel (or just Control Panel).
2) Double-click Add/Remove Programs (or click Uninstall a program).
3) Select HP Photosmart Driver Software, and then click Change/ Remove.
Follow the onscreen instructions.
4) Disconnect the HP Photosmart from your computer.
5) Restart your computer.
Note : It is important to that you disconnect the HP Photosmart before restaring your computer. Do not connect the HP Photosmart to your computer untill after you have reinstalled the software.
6) Insert the HP Photosmart CD-ROM into your computer's CD-ROM drive and then start the Setup program,
7) Follow the onscreen instructions and the instructions provided in the Setup Guide that came with the HP Photosmart.
Nov 09, 2009 | HP Photosmart D7260 Printer
Can not install Lexmark X5150 all in one drivers
Try uninstalling the printer software again in safe mode, and use the manufacturer's uninstall command if there is one. (It will be in the Lexmark program group on the Start menu if there is one.) If not, you can try uninstalling through the Control Panel Add or Remove Programs icon. Then restart the computer and try a fresh reinstallation. Don't connect the printer until the installation program tells you to. Some brands and models don't install correctly if the hardware is connected before all the necessary software is properly installed.
Dec 01, 2008 | Lexmark X5150 All-In-One InkJet Printer
Have a Dell Inspiration 1501. Installed Lexmark 5200 printer software some time age. Did not try to print until today and cannot get it to print. It will copy. Help
Disconnect printer from computer
Cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
Reboot & reconnect printer (swap cables if not detected)
If still not working, Uninstall the printer and install the printer again but
doing this:
1) Uninstall the printer,
2) Delete all the printer folders created during the last installation. (Usually in folder "Program Files")
3) In the computer registry (start >> run >> regedit.exe) Delete all printer paths
4) Reboot your computer
5) Re-install the printer again.
This will fix your problem.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 19, 2008 | Lexmark Office Equipment & Supplies
Erratic Printing
I had the same probleme, norten anti virus was clasing with the hp software. I suggest that if are using norten uninstall norten and see if this makes any differance. There is a special norten uninstall application called NO NORTEN.
Apr 26, 2008 | HP LaserJet 1020 Printer
Epson stylus rx560
try uninstalling the driver and disconnect the usb cable then reboot computer.
re-install printer driver.
Jan 22, 2008 | Epson Printer
Unable to re-install printer/software
see this problem of printers not printing is to much try and do this disconnect the printer from the system then connect it again then try and instal it again.
Dec 11, 2007 | HP LaserJet CM1015 All-In-One Printer
Epson LQ-2180 Dot Matrix Printer Logo
69 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
