Unfortunately, the printer does not actually measure the ink in the carts, but measures how many droplets called for. The carts may actually be full, but the printer now thinks they're empty. Most likely the black ink needs to be "charged" because you've cleaned out the pipe. I don't know what to do to charge it, and you'll likely need new carts.
Ink Carts do act finicky at times. Especially Canon carts.
In many cases, the ink carts have a small fuse built into the back of the cartridge that opens up if the cart has been removed for any reason. Replacement Carts come with the fused portion reset, thus when you insert it into the printer, it works great. If the cart is FULL, it still may not be observed as full or new by the Printer itself. Best way is to use a new cart, not necessarily a Canon Brand. Use an inexpensive company like https://www.carrotink.com/canon-pgi-5-cli-8-combo-10-pack-ink.html
I guess you d used generic ink carts?! If yes, the cart holder needs replacement due to ink that has stained the led control. The ink has made a short circuit. The error can only be deleted by replacing the whole cart holder!
1. Took out the color ink cart and clean the copper contacts of the ink cart with cotton swab, make sure that you do not touch the silver nozzle .
2. Try new ink color ink carts as someime this issue came up when the ink carts are about to finish up.
3. Replace the ink carts and do not us a refill ink.
This could be to several reasons: 1# The black cart contains blue ink-> Change to a brand new cart.
2# The cart assy has a bottom that is a foil. Sometimes this foil leaks. Ink will mingle: You need a new cart assy.
Run the cleaning cycle twice after inserting a brand new bk ink cart and print out a test print. If you still see blue instead of bk the assy is leaking. BTW the bk is darker than blue (or better cyan). You must see bk! So it seems to be the prob with the right ink....
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart).
If you have used thirdparty carts, there could be a prob due to construticon or ink quality.
In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink.
DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Did you use third party ink? If the ink is pigmented the filter in front of the printnozzels is clogged and cant be cleaned any more.
What you can try is to buy a brand new original brother ink cart and do the cleaning 3 times. After that do a testsheet printing. In case its OK, your lucky and it was a problem of the cart. If you cant see any blocks (with the original ink used!!!) the printhead is crashed and has to be replaced (BTW: Its cheaper to buy a new mfc)!
Do use only dye ink for brother printers!!!
