Question about Motorola Mobility MOTORIZR Z3 Cellular Phone
MOTOROLA Z3 NOT CHARGING
THIS IS MY SON'S PHONE AND IT WONN'T CHARGE FULLY!
I THINK HE MAY HAVE PULLED OUT THE USB PLUG WHILE IT WAS STILL PLUG IN (DATA TRANSFERING)
IT WILL CHARGE FOR 3-5 MINS TILL IT SWITCH IT SELF ON, THEN STOP'S CHARGING 1 MIN LATER BATTERY FLAT UNPLUG USB CHARGE THEN REPLUG AND REPEATS AGAIN.
    Brigadier General:
  • 7,752 Answers
Have the firmware reflash on the phone this should correct the issue that you have had with the phone.
Posted on Mar 28, 2008
SOURCE:
Why won't my Pride Go-Go Elite Traveller batteries charge using a trickle charger? The batteries are new, but my charger quit working.
Hi Robert , can you clarify what you mean by a trickle charger ?, any chance of a photo of the charger ?
using a standard gel battery charger , the charger will charge the batteries in question and once fully charged, the charger will trickle charge the batteries.. This is a standard operation and recommended by battery makers...
Regards
Rob
Jan 09, 2016 | Pride Health & Beauty
Charging solution
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 06, 2012 | Motorola Mobility WX160 Cell Phone
My Samsung Captivate won't take a charge. It works on the both house and car charger but as soon as I take it off the charger it shows zero charge left and quickly shuts down. When I leave it on the...
I want to let you know that the battery of your phone is bad.
Please, replace it with a new battery.
Please, when you want to buy your battery, make sure you buy it from samsung shop because there are many shops selling fake batteries.
Thank you and God bless you for contacting FIXYA.
Sep 02, 2011 | Samsung Captivate Cell Phone
Even if i connected the charger its not charging
First Option:
Second Option:
Jan 03, 2011 | Nokia 7610
Battery discharge quickly, I have replaced new batteries and module control and problem still exist.
Don your charger is probably not charging the batteries. When you charge your chair overnite the charger should have a red and green light showing charge complete. When you first plug it in the lights should be red and yellow. If you are getting a red and green light when you first plug it in then there is a problem with the charger or with the charging circuit to the batteries. You should have a charger port on the battery box try plugging the charger into that port and see if you can get the batteries charged. When you do you should have a red and yellow light on the charger changing to red and green when fully charged. Hope this helps
Nov 07, 2010 | Pride Go Chair Travel Power Chair
My phone is not charging up when I plug it into the charger
First Option:
Secend Option:
Aug 17, 2010 | Motorola Mobility C118 Cellular Phone
Won t charge
Download Motorola Phone tools and get a new battery for your phone.
The batteries go bad about once a year, sometimes longer.
if this helps you please leave a vote on fixya
May 21, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Phone not charging
seems that the port or the battery may be damaged .try to check it
Aug 10, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Battery charging problem
Seems like it may be your wall charger.
I would inspect your connectors (both charger & phone) as well though (for dirt or debris).
I would also suggest using Motorola's wall chargers, the products seem to charge best with them rather than the after-market knock-offs which also seem to damage the phones connectors on some models.
May 13, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Motorola Mobility MOTORIZR Z3 Cellular Phone Logo
345 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
