Question about Logitech QuickCam Pro 4000 Webcam
Changing the base on my logitech 4000 cam?
It has two bases one thats flat and one that will curve onto any surface. There are no instructions as to how to change the base and I remember having one before and breaking it trying to do it! Please advise
  • 589 Answers
It unscrews like a camera from a tripod. Just give is a 'twist'.
Posted on Jan 08, 2008
How to put base of tv together and attach to tv
Depends on your TV, but usually it comes with screws that you... Well... Screw on after fitting the base onto the TV. Instructions should have come with your TV on how to do this.
Nov 30, 2013 | Televison & Video
I cannot remove batteries from Logitech cordless optical mouse EX100
Possible that the batteries have leaked and stuck , if so use some degreasing spray like WD40 on the base of the terminal connection , let it soak a bit and then try to pull off the battery use a bend flat rod or screwdriver.
Once removed you must clean the surface and see if there is damage on the unit. If so clean and wash before new battery is replaced.
Oct 17, 2011 | Logitech Cordless Desktop EX110
I can not get the base off
Follow the below instruction on how to the base off your Toshiba LCD TV;
  1. Turn off your Toshiba TV if it is on.
  2. Unplug your TV from the wall and any other devices (like DVD players or Blu-ray players) that it is connected to.
  3. Put a blanket, towel or some other kind of soft object down on the floor (if you have hardwood floors and not carpeting in your home).
  4. Set your Toshiba TV down onto the soft surface with the screen facing downward toward the floor.
  5. Use a flat-head screwdriver to remove the two large, plastic bolts on the rear of the TV stand's base. These bolts are holding the stand onto your Toshiba TV. Set the bolts aside.
  6. Use your hand to pull the base off of the Toshiba TV. You will now be able to set your TV completely on the ground. Put the base (as well as the accompanying bolts) aside for safe-keeping, in case you ever need to use them again.
I hope the above helps.
Good luck.
Feb 02, 2011 | Toshiba REGZA 52RV530U LCD TV
Haw to remove the base from sharp LCD TV 56 in
I find this guide about how to remove the Base of an LG LCD TV. Things You'll Need:
* Table or other flat surface
* Soft cloth or towel
* Phillips screwdriver
1 Unplug your LG LCD TV from its power supply and unhook any other cables from the TV.
2 Lay a towel or a soft cloth onto a table or another flat, supportive surface.
3 Lay the LG LCD TV face down on the towel, which will protect the screen from being damaged.
4 Use the Phillips screwdriver to remove the four bolts that hold the base in place. The bolts are located in the center of the TV near the bottom.
5 Slide the stand out from the bottom of the TV.
6 Press the protection cover, which is supplied with the TV, into the spot on the TV where you removed the base until you hear it click into place.
7 Re-insert the four bolts you removed into the holes on the back of the TV and tighten them with the Phillips screwdriver.
I hope this help; remember to rate this answer. Good luck.
Sep 30, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Installing web cam on ubuntu system
installing a logitech web cam on ubuntu linux based system
Apr 24, 2010 | Logitech Webcam
Need drivers for logitech web cam pro 4000 vista operating syst
you browse logitech and download your driver
Jun 29, 2009 | Logitech Webcam
I cannot remove the plate to pute the other plate on
Here's a copy of the manual instructions...
Detail Sanding
Your tool is equipped with a teardrop base which allows you to use it on large flat surfaces
and tight spots or corners.
The pad tips may wear unevenly, depending on use. The pads are designed to allow you to
interchange and /or rotate the diamond tip.
Fitting Sanding Sheets ( Fig. 2)
• Detach the two diamond-shaped tips from the sanding sheet.
If this doesn't provide enough information, take a look at the pictures in the manual at the following link:,MS550GBMS550GH.pdf
If you still have difficulty getting the base off, write back and let me know specifically what the trouble is and I'll try to help you with it.
• Hold the tool with the sanding base facing upwards.
• Place the sanding sheet onto the sanding base.
The diamond-shaped tip can be reversed and replaced when worn.
• When the front part of the tip is worn, detach it from the sheet, reverse it and press it onto
the sanding base again.
• When the whole tip is worn, remove it from the sanding base and fit a new tip.
Tip of the Sanding Base ( Fig. 3)
When the sanding base tip is worn, it can be reversed or replaced.
• Remove the screw.
• Reverse or replace the worn part.
• Fit and tighten the screw.
Finger Attachment ( Fig. 4)
The finger attachment is used for fine detail sanding.
• Remove the screw.
• Remove the diamond-shaped tip holder from the sanding base.
• Fit the finger attachment onto the sanding base.
Contour Holder Attachment (Fig. 5)
• The contour sanding pieces are for sanding curved surfaces and grooves.
• Remove the screw.
sanding base.
• Fit the contour holder onto the sanding base.
Fitting and Removing a Contour Piece (Fig. 6 & 7)
• Choose the contour sanding piece profile most suitable for your application.
• Place one end of the contour sanding piece into the recess at
the front end of the profile holder.
• Push the other end of the contour sanding piece until it clicks
into place.
To remove the contour sanding piece, push it forward then pull the rear end out of
the profile holder (fig. 7).
Fitting a Sanding Sheet Onto a Contour Sanding Piece (Fig. 8)
• Align the sanding sheet with the contour sanding piece.
• Press the sanding sheet onto the contour sanding piece, making
sure that the sanding sheet follows the shape of the profile.
Mar 23, 2009 | Black & Decker MS550GB Mouse 5 Amp Detail...
I want to take off the base of my flat screen tv.
lay tv down on a flat soft surface remove 4 philips screws on back on either side of signal brd inputs base will pull out of bottom
Oct 15, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Problem Siemens Gigaset 4000 and 4200
If you had a storm, and the only handset that works shows line in use, then your base has gone bad and needs repair. The reason the phones are flashing base 1 or something to that effect is because they don't see the base anymore, which typically means no phones will see your base, so its odd that one phone is actually seeing the base. Either way, you can try re-registering the phones to the base, but if you get the line in use after they register (if they will register), then your base is bad. If they won't register, your base is bad. For additional assistance you can go to
Jun 15, 2008 | Lands Phones
Logitech Quick cam Pro 4000
downlod web cam Logitech Quick cam Pro 4000 winxp
Dec 08, 2007 | Logitech QuickCam Pro 4000 Webcam
Logitech QuickCam Pro 4000 Webcam Logo
51 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
