Question about Logitech QuickCam Pro 5000 Webcam
Vga webcam and headset
The webcam works fine on skype but no picture on msn
    President:
  • 8,637 Answers
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 14, 2009
SOURCE:
How to get Skype to recognize my internal webcam on Asus x53e
Also check the Audio Settings for the MicrophoneTHEN click on Save.
Apr 06, 2012 | Computers & Internet
Webcam
You both have to be in the same program to use your webcams.
You cannot hear her msn - this is probably a failing on her set up (mic)
She may have a laptop with a built in mic and she needs to nominate her webcam mic as default so that msn/skype software can locate it.
I suggest you both follow these instructions
Audio
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Configure to MSN
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Configure to Skype
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
May 07, 2010 | Logitech Webcam
Hi ihave an acer aspire 5600 .My webcam works with other aplications but not on skype and msn.Could you please help me?
Before you can use your webcam in any chat program you have to configure it to that program
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Start Skype.
Click 'Save'
Click Save
WINDOWS LIVE MESSENGER ( MSN)
Open MSN
Click 'Open Menu'
Set your speakers
Click 'Next'
Click 'Finish'
Feb 09, 2010 | Logitech Quickcam Chat Webcam
I cant see with my webcamera!
have you updated your dirvers? there could be a later version on the manurfactur's (soz bad s.p) website...
i had a logitech webcam that had to re-install the drivers everytime i unplugged it from the pc. i ended up getting a new webcam..
it also could be the programs skype and msn not reading the webcam when the other view program is open as it only works for one program @ a time....
Jul 05, 2009 | Microsoft LifeCam VX-1000 Webcam
My webcam does not work on msn
first you need to know that if you used xp ...and upgraded to vista ...you need to find a compatible driver for your web cam too ...if your web cam used to work just fine on vista ...and its just the msn issue ...just reinstall the latest MSN messenger and it should be enough ...also verify the proxy servers on the messenger preferences..and set 'em to fit the kinda conexion you use...
but I suspect a problem with the program settings ...so the easy way is just to install the latest messenger(MSN) available for vista ...and it will be ok
May 17, 2009 | Logitech QuickCam Pro 5000 Webcam
Camera will receive but not send video
Hi, can you tell me a bit more, like are both computers using same ops system and same cam software such as msn messanger live for example? Or is it skype you are having an issue with?? Just a little more detail and we solve this together!
Aug 10, 2008 | HP VGA Webcam
Toshiba Satellite A 215 - Webcam Doesn't Work
sir my all softwares r installed properly & im using vista stater. my web cam is not able 2 b detected
Jun 30, 2008 | Toshiba Satellite A135-S2276 Notebook
Acer crystal eye webcam (aspire7720-6155)
First is a good sign that if you click the Icon form the webcam software, and you see your picture. This indicates that the webcam drivers were installed correctly.
You will need a software that support the webcam to be able to use it. You can Try Skype (http://www.skype.com/), or MSN Messenger (http://im.live.com/).
Those programs will detect your webcam and will enable video chat, that way you can use your cam to communicate with others.
Hope this helps..
May 01, 2008 | Acer Aspire 5610-4648 Notebook
Webcam and Live Messenger
I can use the webcam on Skype but when I close Skype and open Instant Messenger I get a message that the webcam is unplugged or being used by another application.
Oct 28, 2006 | Labtec 961307-0914 Webcam
Logitech QuickCam Pro 5000 Webcam Logo
200 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
