Question about Microsoft Windows 98 for PC
Network printer problem
Unable to share the printer indtalled on xp machine, When access the printer ,receive an IPC$ dialog box.
XP machine is in domain & win98 machine is in workgroup. Previously, it was able to share the same printer but now from any 98 machine unable to share the same printer.
Pls advice me what to do ?
Thanks & Regards
Makarand Patwardhan
    Genius:
  • 1,601 Answers
1. How are these two computers networked? Through a router, or by a crossover cable?
2. Is the network workgroup the same on both computers?
3. Have you tried turning off any firewalls or rerunning their workgroup setup?
4. Remember, to share the printer the host computer must be on. Is it?
5. Did you right click on that printer and choose share this on the network? Also: the lack of a login prompt is probably the problem. To see,
> click Start and see if there's an entry saying "Log off <username>" or
> just "Log Off". The first one is OK, and the second one indicates a
> problem. If there's no user name, click "Log Off" and log back in
> with a user name. If that makes Samba access work, here's a likely
> permanent solution: run the registry editor, open this registry key:
> HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Curr entVersion\
> Network\Real Mode Net
> and delete the value named "AutoLogon". This web site explains how to
> do it:
> http://www.wown.com/j_helmig/nologon.htm#AutoLogon
Posted on Nov 30, 2007
SOURCE:
Tip
How To Enable File And Printer Sharing In XP, Vista, and 7
Verify File and Printer Sharing for Microsoft Networks is Installed by following these instructions for your particular OS:
Windows XP
1. Log in as the administrator or as an account that has administrator capabilities.
2. Open the Control Panel and click Network And Internet Connections.
3. Below "Pick A Control Panel" Icon, click "Network Setup Wizard."
4. On the Welcome screen that displays, click Next and then click Next again. The wizard displays the Select A Connection Method dialog box.
5. If your host computer connects to the Internet through a residential gateway like a router, access point, or base station, select the second option and click Next.
6. The following prompt is for your computer’s description and name. Accept the default answers and click Next. Do the same for the Workgroup Name prompt.
7. On the File And Printer Sharing screen, select the Turn On File And Printer Sharing radio button and click Next.
8. When the process is complete, the You’re Almost Done dialog box displays.
9. Select Just Finish The Wizard; I Don’t Need To Run The Wizard On Other Computers and click Next.
Windows Vista
1. Click Start, right-click Network, and then click Properties.
2. In the Network and Sharing Center window, under Sharing and Discovery, click the down arrow next to File sharing.
3. Within the File sharing settings, click Turn on file sharing, and then click Apply.
4. Next, click the down arrow next to Printer sharing.
5. Within the Printer sharing settings, click Turn on printer sharing, and then click Apply.
Windows 7
1. Click Start, open up Control Panel, then click on Network and Internet, then click on Network and Sharing Center.
2. In the Network and Sharing Center window, click on Change advanced sharing settings.
3. In the Advanced Sharing Settings window, you will need to change the settings for the Home or Work, and Public profiles.
4. Turn on File and Printer Sharing for both Home or Work, and Public profiles.
5. Click Save Changes and close this window.
on Jul 14, 2010 | Computers & Internet
Unable to access worldbook
i think that the folders that u can access in XP machine are encrytped from Xp operating system ... if the color of the folders or the files is changed to green or blue ..then ur folders are encrypted ...if it is the case, the restrcitions have to be considered..so u can decrypt and then access from vista...hope this helps...
Aug 18, 2009 | Western Digital 500GB My Book World...
I have an canon pixma mp480 connected to a windows xp home computer. It work fine. I shared the pinter to the network. I got the windows xp connected to that shared printer, but the windows vista computers...
Is the printer connected via USB to the XP computer?
How did you map the shared printer (ie; what port)
When you're on a Vista machine, go to Network, find thw XP computer, explore, can you access the printer through this method? I need to know if Vista machines were set up with this printer on Local Port or Connected to this machine.
Jun 19, 2009 | Canon Pixma MP480 All-In-One InkJet...
Network access denied
Follow the steps to Sharing the files
Your computers are already connected to a network — i.e., they’re all already able to browse the Internet using the same router..
1 : Open the Network and Sharing Center window by clicking on the Windows orb in the lower left corner, and then either right-clicking on Network and selecting “Properties”, or opening the Control Panel and double-clicking “Network and Sharing Center.
2 : If your network type is “Public,” you need to change it to “Private”:
  1. To the right of the network name and location type, click Customize.
  2. In the Set Network Location dialog box, click Private, and then click Next.
  3. In the Successfully set network settings dialog box, click Close.
3 : Under “Sharing and Discovery” in the bottom half of the Network and Sharing Center window, you need to turn all the settings from “Off” to “On” by clicking on the down arrow next to each setting, clicking on “Turn on …”, and clicking on “Apply.” But see some pointers below:
  1. For the “Password protected sharing” setting: you may want to leave this “On” or turn “Off” at your discretion. (I turned mine off.)
  2. For the “Public folder sharing” setting:
    1. If you want to share the public folder so that other computers on the network can access the Public share to open files, but not create or change files, click Turn on sharing so anyone with network access can open files. This is the default setting.
    2. But if you want to share the public folder so that other computers on the network can access the Public share to open files and also create or change files, click Turn on sharing so anyone with network access can open, change, and create files.
4 : You’re done with the Network and Sharing Center window. Close it via the “X” button.
5 : Click the Windows orb at the lower left corner of your computer, and click on Computer
6 :
n the Computer window, navigate to the folder containing the file(s) or folder(s) that you want to share — e.g., “Pictures” or “Documents” or a specific file or folder within. Note: don’t open the folder itself that you want to share — just navigate to the folder that contains this folder.
7 : Right-click the folder that you want to share, and then click Share. The File Sharing window is displayed. (Click picture for a larger version.)
8 : If you have password protected sharing enabled: Use the File Sharing window to select which users can access the shared folder and their permission level. To allow all users, select Everyone in the list of users. By default, the permission level for a selected user is Reader. Users cannot change files or create new files in the share. To allow a user to change files or folders or create new files or folders, select Co-owner as the permission level.
9 : If you have password protected sharing disabled (like I do): Click the drop-down arrow inside the blank field in the File Sharing window, and select the Guest or Everyone account. Click “Add.” Then for that new account, click on the down arrow under “Permission Level” to change it to Co-owner (if you want anybody to read and modify files) or leave it at “Reader” (if you want other computers to just read but not modify your files).
10 : Click “Share”, then “Done.”
CRITICAL NOTE: If you selected “Everyone” when sharing a folder, you’re also making its contents available to any computer that joins this network. Many households, including mine, have wireless Internet via a wifi router. If you don’t have WEP encryption turned on, then I could just drive up and park on the street near your home, open my laptop, let it join your network via your wifi, and then nose around through your files. It’s particularly important that you have WEP encryption turned on for your wifi network.
Feb 18, 2009 | SAMTRON 55V 15" CRT Monitor
Password on shared documents on a workgroup
Password Protect Folders in XP
To password protect a folder built into Windows XP (for other Windows flavors, there are some freeware/shareware programs out there).
If you have a log in password for your account, this can be used to protect folders from other users. If not, you need to creat one. Your hard drive must be formatted using NTFS (which it probably is unless you're dual booting with another operating system). Here's what to do...
Right-click the folder that you want to make private and choose "Properties" (or Alt+Double-click). Go to the "Sharing" tab and check the "Make this folder private" box.
Click Apply . If you do not have a password on your account, a box will pop up asking if you want to assign a password. This must be done if you want to make the folder private, so click Yes . You will need to use your password to log on to your computer from then on.
Type in a password then confirm it. Click the "Create Password" button then close the Password window.
Click OK in the Properties dialog box.
Now anyone else logged on to your computer can't access that file without knowing your password.
Dec 02, 2008 | Microsoft Windows XP Professional
Unable to share printer
You need to go into the machine that manages the printer and allow the access denied machine access or to share printer. You may have to run the network setup wizard in order for the machines to recognize each other.
Jun 23, 2008 | Dell Inspiron 1501 Notebook
Network printe on vista
Accessing a Shared Printer To access a shared printer from a computer running Windows Vista, do the following:
  1. Click Start, and then click Network. The Network window displays a list of computers in the workgroup of the computer.
  2. Double-click the name of the computer containing the shared printer that you want to access.
  3. Right-click the shared printer that you want to access, and then click Connect. Alternately, you can double-click on Printers to see just the list of shared printers, and then right-click the shared printer that you want to access, and then click Connect.
After you have connected to the shared printer, you will be able to print to this shared printer as long as the printer and the computer sharing the printer are turned on.
please note that in network the computer that has the network printer if it is running XP may take as long as 15minutes to be recognized.
Apr 09, 2008 | Samsung ML 1610 Laser Printer
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
Can't access to another computer on same network
Turn on file and printer sharing for microsoft networks. Find it in network connections. Right click your connection, then select properties. You must also provide at least one file or folder to share before anything will be seen on the networked pc's.
Oct 31, 2007 | Linksys WRT54GX2 Wireless-G Broadband...
Microsoft Windows 98 for PC Logo
125 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
