Question about CD & DVD Burners
Install a ricoh 1232c network scanner
I am trying to install a ricoh 1232 multifunction printer/scanner/copier to a network. The printer is working perfectly but it wont pick up the scanner. I am using the network twain driver found on ricoh,s website.
0 characters
1 Points
Why my printer will not print?
I'm not sure what might be exactly your problem but some time ago I wanted to extend the cable from my paralell por to my scanner and realized that even if the cables joined perfectly, the scanner didn't work.
So I went to a computer store and wanted to buy a longer cable but salesman explained me that it shouldn't work for my scanner because pins were different. Your problem might be this.
Look for a GOOD computer technician and ask him if this is the problem and if he can adapt a cable from PCI card to printer.
Jul 05, 2015 | Rimage Prism Plus Thermal Disc CD/ DVD...
What does Canon Pixma MG8220 error 6C10 mean?
Go to the Canon homepage, go to error messages, query that specific error.
Aug 03, 2014 | Canon PIXMA MG8220 - Multifunction ...
How can i Solve the Error E100
Found from another site..
Check the following:
1) Drum unit
Is the drum unit installed in host machine?
NO : Install the drum unit.
2) Connection
Is the connection of the connector (J908) on the BD detection
PCB, connector (J907) of the laser unit, and connector (J102) on
the DC controller PCB normal?
NO : Correct the connection.
3) Laser/scanner unit, DC controller PCB
Try replacing the laser/scanner unit. Is the fault corrected?
YES : End.
NO : Replace the DC controller PCB
Hope this helps!
Jun 24, 2014 | Canon Service Manual For Ir 600
What is meant by spooler failed to load a plug in module?
It seems that your printer intend to get a piece of program for use but failed to get it. I would suggest you re-install the printer driver to see if it is still the case.
If the problem persists, the printer itself may need to be repaired (either hardware or software).
Jun 08, 2014 | Epson L200 Original Continuous Ink Tank...
When printer is on but can't do any proccess than what i do?
You need to click on 'control panel' and find 'fax and printers'. If your printer is listed designate it as the primary printer. (make sure it's even listed....and you have the drivers for the printer name and model)
May 10, 2014 | Epson CD & DVD Burners
Error code 5030
What that means is that there is an internal hardware failure in this printer and it's actually gonna require a service. It's actually an internal hardware failure that's going on within the printer. You would have to contact the Canon tech support USA and they will be able to give you further guidance on what to do.
Jan 04, 2014 | Canon PIXMA MG8220 - Multifunction ...
Install epson ink without cd installer
You can download the Epson printer drivers from their support WEB site. Please click on this link and select your model printer to download :-
Mar 30, 2013 | Epson L200 Original Continuous Ink Tank...
General error L200, what is solution? I try to turn off and switch again...It Error again..
Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes, turn the printer back on. but not working printer.
Sep 30, 2012 | Epson L200 Original Continuous Ink Tank...
EPSON L200 PRINTER will not power on
make sure all leads connecting to your printer have dust free secure seating
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you
might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver disable uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope it helps
Jun 13, 2012 | Epson L200 Original Continuous Ink Tank...
Cannot find drive for 7w036-a01
Hello there:
if you are unable to get it from the manufacture of the device please go to and download this 100%freee driver utility, it will update and install any of your drivers and help install drivers for things that you cant get drivers for I.E printers
scanners/ mice/ speakers ect.ect and it is totally free ok?
best regards mike
Aug 17, 2009 | Dell (7W036) DVD+RW Burner
CD & DVD Burners Logo
177 people viewed this question
Top CD & DVD Burners Experts
Brian Sullivan
Brian Sullivan
Are you a CD and DVD Burner Expert? Answer questions, earn points and help others
