Question about JVC GR-D33US Mini DV Digital Camcorder
JVC Camcorder Model # GR-D270U
The camera has a constant error that says "unit in safeguard mode" and asks that I eject and reinsert the tape. How can I fix this?
  • 2 more comments
  • frogsisme Mar 21, 2008
    I have removed and reattached the batter, but it is still in safegurad mode, don't know what else to do??
  • DVR doctor Apr 28, 2008
    I got the same error 01 plus a tape stuck inside won't eject. Probably because it's in safe mode, right? I reinstalled the battery a gazillian times, often waiting as long as two hours before reinstalling it. I even get the error on the power cord with no battery installed. I tried "Wack a Mole" like you do for some Handycam errors. Now what, wait for a meteorite to strike it? Thanks JVC for Junky Video Crapt.
  • Sandyann Jun 14, 2008
    i am getting unit in safeguard mode and to eject and replace cleaner tape in my JVC GR-D270U. I've done it several times, but still getting it.
  • jpell Feb 19, 2009
    im getting the same error message, and the tape is stuc inside the camera and wont come out. granted the camera undertook a faal off the back of a snowmobile doing 60mph but still i dont understand why at least the tape wont come out. all i need is the tape, and suggestions?
I thought this was a camera issue, but it ended up being a tape issue. So it shouldn't matter if you have the same model of the JVC mini camcorder as I did or not. Anyway, the tape has a tab that "locks" the tape to keep from recording over it accidently. I moved that tab and it started working. If your tape is stuck in the camera, you may have lost the tape already. Try to get it out of the camera without damaging the tape or the camera...more importantly the camera. You may have to take it to a professional to prevent damage. If you get it out undamaged, check to see if the tape is locked or not. Move the tab and try the tape in the camera again (unless you're afraid of it getting stuck again). In that case, try it in another camera. That's how I discovered that this was a tape issue rather than a camera issue...because I tried the same tape in a different camera and got the same error message. Don't despair if your tape comes out with part of it sticking out or crumpled, as long as it's not broken, you can salvage it. Even if it's broken, you can probably salvage the majority of the tape by taping it back together (call a professional, you may need special tape for this), just don't touch any of the undamaged tape or pull it out of the cassette too far and all you will lose is the damaged portion. I actually couldn't see the tab well enough to tell if it was in locked or unlocked mode since it's so tiny and my close-up vision is getting blurry, but I moved the tab to opposite of what it was and that seemed to do the trick. My mistake was in trying to save money with the cheaper tapes...next time I'll spend a little extra for the better tapes to avoid all this headache. Hope this helped. Have a great day!
Posted on Apr 08, 2009
    Scholar:
  • 48 Answers
On page 51 of your manual, it states that an error has occurred and recommends resetting it by removing your battery, waiting a few minutes to clear it, and then resuming. If that doesn't clear the issue, then it may need servicing.
J. DeRuvo
Digital Camcorder HQ
Posted on Dec 04, 2007
SOURCE:
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
My JVC GR-D77OU Mini DV Digital Camcorder is giving me the next messages: eject en reinsert tape. unit in safeguard mode. After ejectirn and reinserting the video tape it still does the samething. I have...
Remove the battery and or the power supply (plug), leave it out for a few minutes, then reattach. This should solve your problem.
Let me know if this helps....
Jan 03, 2009 | JVC GR-D370 Mini DV Digital Camcorder
Unit stuck in safeguard mode
I can't find e setup for sony
camcorder
Dec 30, 2008 | JVC GR-D270 Mini DV Digital Camcorder
I think youre talking about safeguard mode.
Here is the manual if you don't have one:
http://resources.jvc.com/Resources/00/00/94/LYT1354-001A.pdf
See page 51. There should be an error indication number as well.
Jun 19, 2008 | JVC GR-D290 Mini DV Digital Camcorder
Safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
Aug 07, 2007 | JVC GR-D240 Mini DV Digital Camcorder
JVC GR-D33US Mini DV Digital Camcorder Logo
1,411 people viewed this question
Top JVC Video Cameras Experts
Ekse
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
