Question about Samsung LE40R74BDX 40 in. LCD Television
Tv has white dots all over it. It was where you
Tv has white dots all over it. It was where you could turn it off and turn it back on and it would be a little clearer. Now it is the same all the time.
    Sergeant:
    Champion:
  • 257 Answers
Have you tried playing with a DVD? If it does the same, the main board needs replacing.
Posted on Aug 14, 2009
SOURCE:
I just purchased a Samsung40" 4K Ultra HD HDR LED tizen smart tv 6270fxzc it has little white dots (snowy) on the screen picture?
Take it back it is likely defective if you know for sure you have a good TV signal. Do other TV's you own have this snowy appearance (white dots)
Nov 29, 2016 | Ultra Televison & Video
Why are white dots multiplying on screen?
DLP chip needs replaced...about $200 for the chip and replace yourself. YouTube has videos on how to replace
Dec 28, 2015 | Mitsubishi WD-60735 Projection Television
Cracked screen & white dots appearing since the crack appeared
I have a Mitsubishi TV and had the same problem. There is a mirror that moves to control each pixel. When some of them fail to move you get the white dots. Google your problem and a company will come up(sorry forgot the name).,you can buy the new part from them and they have exact utube videos to help you do the repair. Took me about an hour. Part was around $150. Very rewarding feeling when you turn the tv back on with no white dots.Still dot free after two years
Mar 16, 2014 | Mitsubishi MBS73A Base for WD73C9 WD73837...
My mitsubishi 65in tv has a lot of small white dots on the screen what causes this?
projection tvs can display white dots from the dust that is on the reflector mirror your lamp shines the picture on before it is reflected onto the front screen of your tv, one must be very careful when cleaning this, may be worth a service man doing it for you
Mar 07, 2013 | Televison & Video
Light bulb
White dot for DLP Projector TV is not because of the light buy. It is caused by aging DLP chip ( DMD Chip.) Your TV DLP Part should be the following image:
Check the post how to place it diy
May 04, 2012 | Televison & Video
I have got two white dots that have appered on the screen
is your problem like this?
if it small like this DMD BOARD
if its smaller try to clean the back of your tv..
Dec 26, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White dots in plasma tv
The only thing you can try is to adjust the tiny control on the Y board, if you want to try do this. Open the set , set it up so you can watch it with the back off. now looking at the back on the left side you will see a circuit board larger connected to a smalled one or two that go to the screen edge . on the larger board look for a few small controls, mark their positions with a dark sharpy then turn each a little while looking at the dots to see if one makes them better or worse. If one control effects the dots try to center it for the least amount of dots, if no effect is observed when a control is turned return it the original position that you mark before starting. if the dots do not clear either the Y board is bad or the whole scfreen is defective.
gd lk
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Aug 15, 2009 | Televison & Video
I have white dots on the screen of my hsl4266wx/xaa?
If these dots are only seen when the picture is on I would look for the Optical Block to be causing it. Are the dots in the same place each time you turn it on?
Jul 17, 2009 | Samsung HLS4266 TV
How to fix flashing dots xbox 360?
It could be the cable port needs resetting. On the TV unplug the tv and on the xbox disconnect the cord and turn off the xbox and unplug it. Then put the different cord on and plug the 360 back in.
Jul 09, 2009 | Microsoft Xbox 360 Console
White dots and black on my screen
Are these dots moving with image or stationary under a moving image. This is a key identifier
Jun 23, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung LE40R74BDX 40 in. LCD Television Logo
151 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
