Question about JBL GTO755.6 Car Audio Amplifier
Powering the unit
I have connected the unit directly to a 12volt car battery, the protect LED comes on briefly then goes out. There is no sign of life, what am I not doing right? The units is intended for a Quad cycle and initially to be powered by car battery then hopefully either Li-on or leisure batteries.
Dave
    Problem Solver:
  • 6 Answers
Please check battery voltage dont drop below 10.8volt,
when trying to power up.
Posted on Nov 30, 2007
SOURCE:
Kenwood VR 605 power light flashes
CHECK FOR CLEARED COOLING VENTS & FOR PROPERLY WORKING COOLING FANS. THIS WILL CAUSE SHUTDOWN OF THE UNIT. IF ITS ALL CLEAR, YOU PROBABLY HAVE A POWER SUPPLY ISSUE.
Dec 10, 2013 | Kenwood VR-605 Receiver
My MTX continues to draw power even when the key is not in the ignition. What can I do?
It sounds like you have constant 12volts applied to your remote turn on lead. The amplifier will have 3 connections for power:
1. 12volt constant
2. chassis ground
3. 12volt switched power - this wire should come directly from your head unit. It only sends 12 volts when the radio is on allowing to amp to power up only when the radio is on.
Dec 22, 2010 | MTX JackHammer JH600 Car Audio Amplifier
Is the brutus amp blue led light suppose to stay on when the car is off?
No. The LED should be off when the radio is off (amp turns off as well)
1. 12volt constant
2. chassis ground
Dec 22, 2010 | Hifonics Brutus BXi 1206D Car Audio...
My 4 channel amp keeps going into protect mode when i power on,its not a imminet light,but it blinks once then dies out,plz help
Remove all speaker inputs and outs and just have your 12volt battery, ground and radio remote connected and power up the amp. If it turns red instantly, then the amp is shorted/blown. If it stays green, then install your speaker inputs and outs one at a time. make sure your amp is on while your doing this. if the amp goes into protect mode, take note of which wire it was for it's most likely shorted. Fix that shorted wire and the unit should stay on.
Apr 13, 2010 | Car Audio & Video
On this advice given by skinnman 33, it says "check your ground." How do you do that? I am experiencing the same problem with the led protector light coming on. It will play for about 3 minutes or so and...
When we say, "check your ground" all we mean is to look at the ground wire that connects to the amp and make sure it's adequately grounded. What I do is bolt it to a car seat bolt, that is the best ground you can get(called chasis ground). Try that and if you're still experiencing issues, troubleshoot it by removing one signal wire at a time. signal wires are the speaker and auxillary wires. Sometimes a short on these wires will cause the amp to go into protect mode. If you removed all your signal wires and all you have left on the amp is the remote, power(12volt battery) and the ground and your amp still goes into protect mode, then there's a short in your amp. good luck
Nov 21, 2009 | Lanzar VIBE286 Car Audio Amplifier
Se198wfpf lcd does not stay on screen briefly
It could be the high-voltage inverter board, I case of a faulty backlight (one of the tube flickers) the board would protect itself by powering off. Try changing one of the CCFL tube.
Oct 29, 2009 | Dell Computers & Internet
Brand new Amp, LED Protection lit up
If you have a good ground and 12+v on both the B+ and remote terminals, it's likely a DOA amp. Return it to the place of purchase for repair or replacement.
Jun 10, 2009 | Visonik V204XT Car Audio Amplifier
POWER SWITCH DOES NOT ILLUMINATE GPS SCREEN WITH 12VOLT PWR.
bjw122266 Have you tried holding the power button down for about 10 seconds or so?
Dec 29, 2008 | Navigon 2100 Portable GPS Receiver
My amp is not powering up anymore
take the amp out the trunk and connect directly to the battery, use a jumper wire for the remote from the constant power 12volt , if the amp fail to turn on it may be damage. check the fuses and look for any burnt connection.use a test light to test for power at the connection.
Aug 30, 2008 | MB Quart RAA1000 Car Audio Amplifier
JBL GTO755.6 Car Audio Amplifier Logo
93 people viewed this question
Top JBL Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Dalynn Turner
Marvin
Marvin
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
