Question about Epson Stylus CX5400 All-In-One InkJet Printer
Epson stylus photo RX580
When I scan documents the scanner puts them in a pdf file that I can't edit what gives?
  • Anonymous Mar 23, 2014
    I have been scanning a ton of photos and the last one I scanned gave a number out of order to the file and now won't scan. Is there some kind of limit for scanning? How do I get it to scan again?
    Thank you!
    Scholar:
  • 103 Answers
When you see the File Save Settings window, you need to select the location, name, and format of the scanned image file you want to save.
  1. In the File Save Settings window, specify the file folder in which you want to save your scanned image. Click the My Documents or My Pictures radio button (Windows XP or earlier versions), or the Documents or Pictures radio button (Windows Vista or Mac OS X).
  2. If you want to select another folder, click Other, then click Browse (Windows) or Choose (Mac OS X) and select the folder. If you want to save your image on the desktop, simply click Other.
  3. Specify a file name prefix with an alphanumeric character string. A 3-digit number is automatically added to the file name, but you can change the Start Number if you like. If you are scanning multiple images at once, each image will receive a different 3-digit number.
  4. Select a file format. Depending on the format, the Options button may be available for making detailed settings.
  5. The check boxes at the bottom of the window give you these options:
  • Overwrite any files with the same name: Select this option if you want to reuse the selected file name and location and overwrite previous files with the same names.
  • Show this dialog box before next scan: Select this option if you want the File Save Settings window to appear automatically before you scan in Home or Professional Mode. If you deselect it, you must click the File Save Settings button to open the window.
  • Open image folder after scanning: Select this option if you want Windows Explorer or the Macintosh Finder to automatically open to the folder where your scanned image is saved when Epson Scan finishes scanning.
6. Do one of the following, depending on the currently selected scan mode:
  • Home or Professional Mode: Click OK. Epson Scan starts scanning.
  • Full Auto Mode: Click OK, click OK again, then click Scan. Epson Scan starts scanning.
The scanned image is saved in the file and location you chose.
For more information click here
Posted on Dec 23, 2007
SOURCE:
Can't edit a scanned document
What format did you save the document in? Different scanners use different default formats.
Open the document and try "save as" a .pdf file,then you have a chance of editing it with any of the freeware pdf editors you can google and download.
It's also possible to import it to Office Word and edit it there,if you have the pdf plug-in for Word.
Aug 09, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Epson stylus photo rx580 a printer error has occured see your documentation
Press the stop/clear button then press the maintaince button(spanner) and the ON button all at the same time in that order.That will reset it.
Apr 16, 2010 | Epson Stylus RX580 InkJet Photo Printer
DVD/CD Epson RX580 will not print
You need more than the printer driver.
Scanner driver
Epson print CD
Download the rest from here.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=72106&prodoid=63059193&infoType=Downloads&platform=All
Feb 08, 2010 | Epson Stylus RX580 InkJet Photo Printer
Epson Stylus Photo RX500.
hi there.. seems, a hard job huh? transfering it from 1 folder to other.
try this , open epson scan program, goto home mode. click preview, click scan, it will open file save settings window where you can select where to save your picture, under location , look for the folder where you want to save it, if its not on the list, select other then look for the folder or for your appleworks, once you found it, click ok, it will scan and save directly to the appleworks.
i hope this one works for your.
pls come back and give me a vote. I would really appreciate that,thanks in advance. good luck.
Feb 06, 2010 | Epson Stylus RX500 All-In-One InkJet...
The drop down menu does not give the option to have the picture scanned/saved jpg format which is necessary for certain sites such as shutterfly
Please follow the steps below to scan and save a Multi-Page PDF with Epson Scan.
1. Launch Epson Scan from your START, (ALL) PROGRAMS, EPSON SCAN.
2. If prompted, select your scanner model. Epson Scan will now launch.
3. Click the drop down arrow next to SCAN, select FILE SAVE SETTINGS.
4. Select PDF for IMAGE format. Click OK.
5. Click SCAN. Click OK to proceed (if prompted).
6. Once the image has scanned you will be prompted to click ADD PAGE or DONE.
7. Click ADD PAGE to scan more documents.
8. Once you have scanned all your documents, click DONE.
9. Your documents will now appear in the EDITING PAGE window. Click OK.
10. The multi-page PDF is now created.
Jan 16, 2010 | Epson Perfection 4490 Photo Scanner...
OCR
To scan a document for editing purposes, you will need OCR (Optical Character Recognition) software. OCR software is not included with your model.
OCR software interprets the scanned document for editing purposes. The Epson driver alone only scans documents as image files and is not capable of this interpretation.
Some reputable OCR software programs on the market are:
Omni Page Pro
ABBYY FineReader Pro
Presto! OCR 4.0
Please understand that Epson has NOT tested our products with these programs. They do not know if these programs are TWAIN compliant and will import directly from our scanners. I recommend that you contact these companies for full compatibility information if you are interested.
Jun 01, 2008 | Epson Stylus CX9400 Photo Printer
Epson 4490 Photo - multiple PDF pages
Hi. Yours probably scans as soon as you have a document in and you double-click, right? I went through this. Double click on the Epson Icon. Make sure the mode preference at upper right is changed to professional. It may start scanning and you have to wait until it's finished to scan again. When you start in professional mode, it brings up a rectangular menu--you probably didn't see this one before (I didn't before changing to professional mode). Now press scan. This gives you a "file save" choice. Chose the location you want. Under the location choice is the Choose Document type option--this is the second key--save as PDF. Now it will bring up that add a page, edit or save file. Professional mode, save as PDF.
Dec 15, 2007 | Epson Perfection 4490 Film / Flatbed...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
205 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
