Question about Sansui DTV2760 27" TV
Black out; R342 Burts, Horizontal Ic Damage
I have a terouble of my sansui tv model BT-s129MX.. My tv Automatically shutoffand when i open i see resistor 342 burts and i cannot see the color code for me to identify the exact value of it
pleasev help me
  • joel_cnn Dec 03, 2007
    I already changed the horizontal IC but everytime i change it always been damage...can you please spicify the resistor value of R342 and other resistor in HV section of the PBC. BT-S129MX
    Thank you...
  • mohammedqass Oct 15, 2008
    i have asome resistore damage in televsion and iam cant read value
    please gave me block diagram for SANSUI BT-S129mx
    thank you
    Genius:
  • 1,694 Answers
Search and obtain service literature....
What part # and location is horiz output TRANSISTOR ?
.........T.
Posted on Dec 19, 2007
SOURCE:
Sansui SV-2110K, Channel lock
Click here and try to download the user manual to your Sansui TV, and refer it how to make a factory reset to your tV. If it do not help you, the main system memory IC might be faulty, and should be replaced.
May 14, 2012 | Sansui Televison & Video
TV MODEL :SANSUI HARD ROCK 21'' PROBLEM : TIME TO TIME ONE HORIZONTAL LINE COMING WITH BLACK SCREEN
Hi The problem of your teevision is what we called the vertical line problem.The problem is in the vertical section of the board.There are many of cause of that problem.First is either loose connection,the circuit at the vertical section have cold solder so its need to resolder using soldering iron.Second,it maybe no vertical supply,its better to check the 12 volts dc supply of vertical ic output.if thers no supply in the ic,there a open resistor near the flyback.try to replace.Third if theres no loose connection and have a voltage supply the problem is either leaked capacitor or deffective vertical ic output. Commonly in that problem is the loose connection,try to resolder the verical section.
Jul 12, 2011 | Sansui DTV2760 27" TV
My sony trinitron 32" tv just went black and the
Hello
Six blinks of standby light in Sony TVs denotes the absence of horizontal oscillation.
No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
In most cases the Ic is foud defective. anyway check its soldering points for any loose contact, or bad solerings. Check the line drive transformer, a very little transformer soldered directly to the main printed circuit board, very close to the horizontal output transistor. Check its primary winidngs for open. If it gets open no horizontal drive signal will be present at the base of the horizontal output transitor, that also may the cause of horizontal stop.
Nov 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Solid white horizontal line
Horizontal line WITH SOUND is only vertical output stage problem.horizontal line without sound is osc problem.So kindly verfy that.If h line with sound then
check vertical ic and ver supply voltage.
Aug 02, 2010 | Sansui DTV2700 27" TV
Screen goes to a thin horizontal line
You have bad grounds on the vertical IC and bad cap at 35volts 100mf. Resolder the IC and replace the cap. Also there are two other caps you should look for...50volts 1mf, they need replaced too!
Oct 03, 2009 | Sansui DTV2760 27" TV
No vertical deflection -Horizontal line on tv
check or re solder the ic of vert. defl.
Jun 09, 2009 | Sansui 27" TV
Burst R342 and i cannot read the value of R342: Black out
hi joe, u will have 2 get the diagram from a book stores for ur model..thats the only way out,..or the manufacturer can help u with the R342..
Nov 30, 2007 | Sansui DTV2760 27" TV
Horizontal White Line
Sounds like something is getting hot causing voltage loss or drive pulse loss to the vertical IC. Maybe you have a bad solder joint. Try tapping the circuit board around the vertical section. A capacitor could be heating and opening up. Stargazer Also you might try using circuit cooler spray and make the problem show up.
Apr 19, 2007 | Sansui TVS2750 27"
THERE IS A VERTICAL LINE ON SCREEN BUT I HAVE SOUND.... WHAT CAN I DO? PLEASE REPLY...
sansui tv model no-(FUI21EYE)
corma ic no-(8823CPNG4PB8)
PLEASE INPUT THE SERVICE CODE
Apr 02, 2006 | Daewoo DTQ-27S2FC 27" TV
Sansui DTV2760 27" TV Logo
416 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
