Question about Seagate (ST3300601CB-RK) (ST3300601CBRK) 300 GB Hard Drive
Hard drive How to set the little plastic piece on the back of both hard drives. One, master is in computer now [plastic piece is on the far right now ]. New one to be a slave. Thank you.
Dear Friend
See the hard disk label, thir only they given the Jumper settings.
regards
Balachandra.R
[email protected]
Posted on Nov 30, 2007
SOURCE:
I want to add a hard disk drive how master and selave
These are called jumpers. The jumper settings on each brand of hard are different There will be a diagram on the hard drive that will tell you where to place that little plastic piece and what pins.
The only thing you really need to know is the Acronyms:
MAS - Master SLA - Slave CS - Cable Select
You may need to go into your bios and modify the settings so the motherboard can see it. If you do end up having this problem let me know and I will walk you through it.
Nov 25, 2010 | Computers & Internet
My second internal hard drive isn't showing up under my computer, but show in bios, and add harware Maxto 4R060J0 60gb
Your 2nd. hard drive needs to be set up as a slave or master, this is done by the jumper in back of the drive. If you have a cd drive as a slave when connecting with the ide ribbon & are connecting the new drive on a different ribbon it needs to be set as master drive. A little more info on your prob. will help answer your question. When you see the drive in bios, does it say master or slave?
Lee
Dec 18, 2009 | Maxtor Hard Drive
External hard disk problem
Yes, it is very easy solution.
Just change your jumper settings, kindly set jumpers as a slave drive I assure that your Hard disk will be shown in drives.
Goo Luck
Nov 25, 2009 | Computers & Internet
Dual Boot
I am assuming they are both internal hard drives, If this is the case, on the back of the hard drive itself, there will be a set of pins with a little plastic connector in between two of them. This connector selects the role of the hard drive.
You want to set the Hard drive which has the operating system installed on it to MASTER and set the hard drive you want to use for extra space as SLAVE.
This tells the computer which hard drive to actualy boot from. It is not possible to run to Operating systems at the same time.
Nov 18, 2009 | Dell Dimension 2400 PC Desktop
When I attempt to log on to my computer, I get message "Loading personal settings", but it immediately changes to "Logging off"...I can't even log on.....HELP!!! I am using an emachines w4685....
My Name is ArmyMason, I am here to help you. Are you seeing any flash of Blue Screen before it reboots? If not it sounds like you have a boot virus. If you can't boot to Safe Mode best the way to fix this is to pull out the hard drive and put it into another computer that has up to date Antivirus. On the hard drive are pins with a little plastic piece attached to them above that should be a diagram SL = Slave, MS = Master, CS = Cable Select. Depending on the Setting the persons harddrive that is in the computer you are about to put that Hard Drive into depends on the setting you need for your Hard Drive. So remember or right down the setting of your hard drive. If there hard drive is set to Master set your hard drive to slave. If there hard drive is set to Cable Select set yours to Calbe select. With the computer off and unplugged, locate the cable that the hard drive is connected to and take your hard drive and connect it to the second connector which is in the middle of the cable. This is where all slave hard drives go. Note: Dont worry you wont infect the host computer with a virus, because its not an active partition. <--- techy info... Now boot the computer and once the Hard Drive is detected run the Antivirus program on that drive.
There are other solutions, but this is one way you can remove the virus without having to format your computer and start over. If its a Blue Screen please make a post with blue screen issues so that we can figure out exactly what the error is.
Feb 24, 2009 | eMachines W4685 PC Desktop
DVD drive dont work
If you have Two cd/dvd drives make sure one is set to master and one to slave to do this on the back of the dvd drives is what looks like a piece of plastic there will be two rows of 4 pins for master the plastic piece should on the right hand side next to the long slot for slave move it one pin away from the long slot keep me posted please
Jan 13, 2009 | Samsung (SH-S162L/BEBN) DVD RW Burner
Cdw dvd sh-m522c
please have a look to your jumper setting...
if you didn't got your dvd driver after jumper sittings then reply to this thread.
Nov 21, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Dvd rom wont register
thats maybe due to the data cable thats the flat cable that transfer the data from your motherboard to the dvd in the back of your hard drive and the back of your dvd there are some pins and a little block made by plastic . that is call a jumper and thats what does the settings for your drivers and on top of the hard drive it has a diagram to set them the dvd has that one to but is on the back next to the power conexion so your hard drive needs to be set as master and if they are using the same data cable the dvd needs to be set as slave
Dec 27, 2007 | ASUS P4SGX-MX Motherboard
Load a new hard drive
Hi Dutshy1,
On back of the hard drive did you move the jump on your main hard drive and set it to Master and your secondary hard drive set to Slave.
Where the jumper is suppose to go is printed on the sticker on top of your hard drive.
The jumper is the little plastic thing on the back of the hard drive connecting two pins together next to the power port and where the IDE cable is suppose to connect.
let me know if that works.
-Daniel
Nov 06, 2007 | EliteGroup 661FX-M Motherboard
Seagate (ST3300601CB-RK) (ST3300601CBRK) 300 GB Hard Drive Logo
85 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Argospete
Argospete
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
