Question about Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router
Fax thru pap2
Pls let me know how can i send fax thru pap2
    Novelist:
  • 173 Answers
NOTE: Set the following parameters under Line 1 or Line 2 tab, depending on what Line the fax is registered to.
Step 1:
Access the PAP2’s web-based setup page.
Step 2:
Once the PAP2’s web-based setup page appears, click Admin Login then click switch to advanced view.
Step 3:
Click Line 1 or Line 2.
fax thru pap2 - 5185-003.png Step 4:
Look for Network Settings set Network Jitter Level to high.
Step 5:
Go to the Audio Configuration section and set Silence Supp Enable, Echo Supp Enable and No Echo Canceller to no. Set FAX Passthru Method to NSE, FAX Passthru Codec to G711u and Use Pref Codec Only to yes.
5185-007.png Step 6:
Go to the Supplementary Service Subscription section and set Call Waiting Serv and Three Way Conf Serv to yes.
5185-009.png NOTE: If the above settings did not work, please power down the PAP2 and power it on after 30 seconds.
Step 3:
fax thru pap2 - 5185-003.pngttp://i.fixya.net/uploads/images/5185-003.png" alt="5185-003.png" class="h_mi" /> Step 4:
Look for Network Settings set Network Jitter Level fax thru pap2 - 5185-005.png /> 5185-005.png Step 5:
Go to the Audio Configuration section and set Silence Supp Enable, Echo Supp Enable and No Echo Canceller to no. Set FAX Passthru Method to NSE, FAX Passthru Codec to G711u and Usefax thru pap2 - 5185-007.pngOnly to yes.
Go to the Supplementary Service Subscription section and set Call Waitfax thru pap2 - 5185-009.png Three Way Conf Serv to yes.
Posted on Dec 07, 2007
SOURCE:
I just sent a Fax. Now the screen shows Status: Standby Do I need to send it again?
It would be helpful to know what model you have. But it sounds like it went thru ok and is asking if you would like to resend. In case it didnt go thru.
Oct 11, 2018 | The Office Equipment & Supplies
My linksys pap2 cannot ring the wireless set or a fax machine.
Try changing the power supply.
It could be unable to supply the neccery power...
Jan 15, 2013 | Linksys PAP2T
Hi, i have a cuestion and i hope you can help me i cant receive faxes in my Lexmary x4270 is connected to PAP2 and configured codecs etc, and this PAP2 is connected at the same time to PBX asterisk,what...
Here are some guidelines on how to receive faxes behind a PBX system:
  • First, make sure your Lexmark X4270 printer can receive faxes when not connected to PAP2 and the PBX system.
  • Ensure that your printer/fax is connected to correct Phone port on your PAP2.
  • Advise the sender to dial your number so that there is a pause before dialing the extension number to your fax machine. They could insert commas between your fax number and the extension number. It inserts a delay of few seconds each. (e.g. 1234567890,,,,,,,,,,456)
Aug 31, 2011 | Lexmark X4270 All-In-One InkJet Printer
Can I send fax thru internet
Yes you could send a Fax through Internet.You could refer many Sites :-
http://www.passtheshareware.com/fax.htm
http://faxzero.com/
You could Google the same, as there are many sites.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 23, 2009 | Symantec Winfax Pro 10.03 (winfax10.03)...
I'M TRYING TO PUT THIS IP NO192.168.1.101 BUT I'M NOT GETTING ANYTHING, CAN YOU EXPLAIN PLS
You need to know the configuration of IP addresses that your router supports. My guess is that IP is a computer on your local network.
Sep 13, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
How can send fax thru internet
You can not send faxes thru the internet unless you use a service such as E-Fax.
Faxes usually are sent via phone lines only.
If you are asking anything else then you have to be more precise in your question as it is not exactly clear as to what you are asking!
Good Luck!
Rich Lilja
Dec 04, 2008 | HP LaserJet 3055 All-In-One Printer
Fax solution
Hello!
First check with your voip service provider that they supports T.38 over SIP.
For sending fax you have to enable T.38 (fax protocoll) support in the pap2 webui.
On your fax machine set data speed to 14.400 kb.
But anyway T.38 (fax) over voip is not a waterproof solution, it can only guarantee delivery for about 85 to 95 % of sent\ recived fax's.
Make shure you have a good, fast and stable connection (try pinging the sip server ip). If it doesnt try another fax machine (f.ex Brother or xerox). If that dosent work, and you still have to get a fax service, try a online fax to mail, mail to fax solution (search google).
I can provide more detailed information and how to's if needed.
Jun 05, 2008 | Linksys PAP2
Locking a linksys pap2
Hi rajahc,
If that is the later version on PAP2 with the reset button on it, I'm afraid there's no way to fully lock it out, but if that is the earlier version without the reset button, there is a way to fully lock the unit from both web and IVR access, however you would need the so called SPC tool, this small software will enable you to generate the generic configuration file for the PAP2 so could you modify it, re-compile and upload it back to the unit via a tftp server. Its not an easy feat not to mention that those SPC tools are only issued to a few selected Linksys partners. Hope this helps
Cheers and best regards,
P.S. pls rate me, tnx.
May 09, 2008 | Computers & Internet
Fax machine is not working
is the phone line that is connected to your fax plugged into the slot marked by the "L" on your fax machine. if not make the correction. if so then plug in your phone into your fax machine labeled with a picture of a phone and see if you get a dial tone and be able to fax.
Thank You,
Mikey
Apr 06, 2008 | Office Equipment & Supplies
Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router Logo
5,725 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
