Back to:
Tags:
D-Link DI-624M Router
Setting up a wireless router (by 2 users)
posted by yasminj on Nov 30, 2007
I have a desktop computer with internet cable modem connection. I intend buying a laptop with wireless facility so that I may use the laptop within my apartment a few feet away from the desktop.
If I need to connect a D-Link wireless Router to my cable modem, how do I set up the router? I have never used a router so far.
yasjyasp@gmail.com
A reply to the above address would be much appreciated.
Jack S.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Apr 15, 2008
having trouble connection
Best Solution
posted on Nov 30, 2007
Helpful (85)
charles007
Rank:Wiz Wiz
Rating: 84%, 59 votes
first you have to check the ip address of the dsl modem you used and see to it that it is not the same ip address of the router to avoid conflict. the default ip address of dlink router is 192.168.0.1.if in case your dsl modem has the same ip address with the router, you have to change firs the ip address of the router before connecting the router to your dsl modem.
next you need to know your internet connection whether it is DYNAMIC or PPPOE, depending on how your internet provider configured your modem. for PPPOE connection, you have to know the USERNAME and PASSWORD that your provider provides you.
good luck.
carlmali007@yahoo.com
Rating Locked! (?) yasminj has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on setting up a wireless router:
I don't want to Accept this solution
Can you Help with these Routers problems?
Routers
after u save thr running configuration at...
Routers
no he podido configuarar la segiridad
Routers
i tried portforwarding using portforward.com guide. but...
Routers
connecting 3 mobile internet dongle to draytek 2800vg via...
Routers
I have seen "condor" in some place, but i don't...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
