Question about Epson LQ-2180 Dot Matrix Printer
I cannot print with epson lq-2180
Well the printer was working fine and after some time next day i got a message from my brother that the printer says i should specify the correct port to print to.
the computer is using win-98 and when i went to the printer properties i found out that the port was LPT1 and i tried all it was not working and when i tried after some time it told me that the printer had been put offline but still i could not even print a test page.
so after some time it was telling me that user intervation is needed.
i uninstalled the printer and installed it again and the same problem.
now it was telling me that i should put paper yet i had loaded paper in the printer and there were no problems of paper jam.
so when i try now to use another port it does work and tell me that i should lord the paper into the printer yet the printer has paper.
so i change the port to LPT0 and when it dint work i tried to put back LPT1 and now it tells me that it is an invalid port.
will be greatful to be helped.
thanks in advance
SOURCE:
SOURCE: lq-2180 continous blinking
lq 2180 printer front pannel led's all are blinking after turning on the printer
Posted on Mar 15, 2008
printech
  • 159 Answers
SOURCE: not printing
the paper sensor came in the left of the printer you can see it maybe stuck
Posted on Mar 22, 2008
  • 110 Answers
SOURCE: Epson LQ-2180 continuous printing problem
An Emulation driver will fix everyones problem... Do this:
1. Click on "Start", then "Control Panel" and then "Printers and Faxes".
2. In the left hand column choose the option "Add Printer". The "Add Printer Wizard" comes up, click on "Next".
3. At the "Local or Network Printer" screen choose "Local" and remove the check from "Automatically Detect".
4. Click on "Next".
5. At the "Select Port" screen choose the appropriate port (usually LPT1: recommended printer port).
6. At the install printer software screen choose "Epson" under "Manufacturer" and LQ-1050 for the printer, then click "Next". If you wanted to install the Windows universal driver, choose "generic" under "Manufacturer" and choose "Text Only", then click "Next".
7. At the printer name screen choose "Next".
8. When asked if you would like the printer to be default make the appropriate selections and then click "Next".
9. Finally click on "Finish". You may need your Windows XP installation disk.
Posted on Aug 22, 2008
SOURCE: EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Posted on Nov 24, 2008
dana_eng
  • 41 Answers
SOURCE: my printer EPSON LQ-2180 send me an error code "paper out"
Hi Soulen , This link is very interest and useful for your type of printer : http://files.support.epson.com/pdf/lq2180/lq2180pg.pdf
and also for driver open this link : http://www.driverstock.com/Epson-LQ-2180-driver-download/23-26-3157-53410/index.html
Posted on Jan 22, 2009
Brother MFCJ870DW Cuts Off/Chops Off/Truncates Left Side Return Address By About Half An Inch On #10 Com Envelope, Suddenly Started Happening
Check carefully that you have specified it to use the # 10 and that the format does not include a wide margin. If that fails, try printing the Return address 'right justified' and see what happens.
Feb 01, 2014 | Office Equipment & Supplies
Error message: No TR Roller Install the transfer roller
Hi
This error has already been noticed by Brother and they have a fix for this issue. This message will appear on your Brother machine if the ground clip is not present on the Transfer Roller Assembly. The clip can become dislodged due to a paper jam or removal of the Transfer Roller assembly.
To check the fix from Brother visit this link--
Brother TR Roller Install error removal Pictures
Please get back to me if you have any queries.
Daniel Scott
Jun 22, 2010 | Brother MFC-9420CN All-In-One Laser...
NO CONNECTION (LAN) on Brother MFC-440CN
I had the SAME problem. I have 3 pc laptops and 1 Mac. The Mac could still print, but the pc's were hosed. I called BrotherUSA and this fixed the problem!
Go to your printer and after making sure it's connected to the network with the Ethernet cable, go to Menu > Print Reports > Network Config. This will print a page that shows your printer's IP address. We need to config that address in your Printer, Fax and Scanner settings in Control Panel.
Go to Control Panel > Printers & Faxes. Right click on your printer > Properties > Ports tab. Click Add Port and select Standard TCP/IP Port. Click New Port and click Next on the wizard. Enter the IP address of your printer in the first field (the second one will auto-fill). Click Next and Finish. Printer's done!
Right click on your PC-FAX in Printers & Faxes and Properties. Click on the ports tab and just check the box that you just created for Standard TCP/IP Port. Click OK. Fax is done!
Go back to Control Panel and select Scanners & Cameras. Right click on your printer/scanner > Properties > Network Setting tab. Select the Specify your machine by address radio button and, if it's not already in there, enter the IP address of your printer. Click OK. Scanner's done!
This will work as long as your router is running. You may need to repeat this process after a power outage or if you need to reboot your wireless router. Not too bad, though! I just wish everything was as easy as a Mac!!!
Jun 25, 2009 | Brother MultiFunction Center MFC-440CN...
How to switch from "offline" status to "online" status
I was also facing the same Problem, I solved it by following these steps
First I noted down the IP address from the Printer, Menu > Network > Wlan > Tcp/IP
then on my pc
1.Point to Printers and faxes 2.add new printer 3.a welcome window appeared click next --select local printer attached to this computer do not check automatically detect............. then click "Next" 4. Point to Create a New port then select HP Tcp/IP Port 5. a Welcome page appears again click Next 6. Now is the time to Write the IP address you noted earlier from the Printer also check Always print to this.......... 7. now by clicking ok or Next it will take some time to load another window 8. Now at the bottom left of this window you will find two options i selected the "custom" option, another window appeared click ok and wait for few seconds, when that disappear click Next Click finish and wait.......... 9. Here You go another window appeared Point to the Manufacturer Brother and then select the model MFC6490 10.Click Next and Point to KEEP THE EXISTING.......... or whatever option you like.. Now its easy follow the on screen steps untill you are asked to PRINT A TEST PAGE
NOW YOU ARE CONNECTED AND ONLINE AND ENJOY....
BUT HAY THE OTHER DAY I FOUND THE SAME PROBLEM "YOUR PRINTER IS OFFLINE" DON'T WORRY, i SOLVED THAT TOO 1--GET TO PRINTERS AND FAXES 2--SELECT THE PRINTER WHICH IS ALREADY INSTALLED AND SAYING " OFFLINE " 3--RIGHT CLICK AND POINT TO "USE PRINT ONLINE" THERE YOU ON FLY AGAIN!!!!!!!!!!!
THANKS MUHAMMAD IMTIAZ KHAN
Apr 02, 2009 | Brother MFC 6490CW InkJet Printer
Brother 8860DN won't work on Cisco switch
Go to the menu settings on the machine itself. Cycle through the options until you find the network settings. Make sure the device has network on and set the connection to DHCP on. save or back out and then restart the machine. It could also be a problem with your Cisco switch and the IP address ranges that the printer and switch have. You may need to specify an address in the printer settings to allow access through the Cisco switch.
Nov 22, 2017 | Brother MFC-8860DN Printer
Brother MFC-490cw stopped working
I would think so! Here's how to contact them. They will need your model# and serial# of your printer:
7777 North Brother Blvd.
Bartlett, Tennessee 38133
1-877-BROTHER (877-276-8437)
901-379-1215 (fax)
M-F, 9:00am to 8:00pm Eastern Time
Jan 10, 2009 | Computers & Internet
Brother HL-2170W Laser Printer is 'offline" wont turn back online
I have a lap top and was having the "printer offline" problem
1) I did the triple click on the printer as in soluyion two to get the IP address which is clearly labled on the 3rd page.
2) Clicked on "Devices and Printers" in the "Start" menu
3) Right clicked the "Brother..." icon and selected "Remove Device"
4) Selected "Add Printer" on the "Devices and Printers" menu
5) Selected "Add a wireless, network, or bluetooth printer"
Nothing was coming up in the search so...
6) Selected "The printer I want isn't listed"
7) Selected "Add a printer using TCP/IP address or host name"
8) Entered the IP adress from the 3rd page of the printout on to the line "Host name or IP address"
9) Left the "Query..." box selected, clicked "next" and printer installed
Jan 04, 2009 | Brother HL-2170W Laser Printer
Error message and won't print
change the USB cable
tray to re install the usb port from device manager
Jun 29, 2008 | Brother HL 1240 Printer
Error message Out of Ink
The answer to all printer problems is to go buy a new one of the same exact model put your broken one in the box and return it for your money back. Tell the store it was'nt working correctly.Make sure you buy the new one at a store that has a good return policy. Problem solved!!
Jun 11, 2008 | Brother MFC 420CN All-In-One InkJet...
Won't scan
Hi there, this problem was posted over a year ago so I boubt you will check this but the best help I ever get is from discussion boards so I think its time to return the favor. I spent 3 hours on this one and finaly figured it out. After following all the steps on solutions.brother.com you need to fully uninstall all brother drivers and reinstall the correct drivers based specifically on your model. In this case mfc 8500. I did this and even went as far as downloading (from above website) the official uninstall tool. I then tried it again and still my driver install would bug at the "click next when connected" But when i connect my printer it doenst let me click next.
Anyways for me the answer to my problem lay in the simple answer of the usb cable i was using. I had a labtop connected to a USB connector conected to a paralell port adapter connected to the printer. I had a theory that the parallel port and usb werent communicating. Keep in mind that the before all this the printer worked fine but the scanner and email fax did not. I then diconected the paralell port from the printer and found a usb entry (weird shape not sure of the term) at the back of the printer. Looked through my cables and sure enough had the usb/weird shape usb cable. Once i connected that to the labtop like a flash everything worked. This was grueling but i hate to admit defeat to computer problems. if you read this..i hope it helps.
Get official uninstall
decompress and use it.
restart. (will not work if you dont)
Get updated driver and software package
Only Connect Usb to labtop now
Only now Turn printer/plug in printer now
Complete instalation
DONE!
Dec 12, 2007 | Brother MFC-8500 All-In-One Laser Printer
Epson LQ-2180 Dot Matrix Printer Logo
660 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
