Question about Canon PIXMA MP600 all-In-One InkJet Printer
Canon MP600 blocked print head
I Have slight streaking on the cyan colour, tried many time to clean it with the utility and then fill one cart with cleaning fluid but still no go.
Have you any suggestions and do you know if canon can supply new print heads? if all else fails.
Thanks in advance
Ian
  • 1 more comment
  • gdman007 Dec 03, 2007
    I have same problem.
  • Anonymous Dec 16, 2007
    Having problems with the yellow and cyan colour, tried many time to clean it with the utility and then fill one cart with cleaning fluid but still no go.
    Thanks in advance
  • Anonymous Dec 22, 2007
    We have the same thing happening but with black...The black cartridge used for text printing, etc....Any fix yet?
SOURCE:
SOURCE: Does not print on paper
Experienced the same problem a few months back with my new MP600 .. had to take it to an authorised repair centre where they replaced the print head .. all good since
Daniel
Sydney
Posted on Nov 04, 2007
SOURCE: Canon MP600
manleeroas, not that it will help but try a few drops of isopropyl alcohol. directions given at this link:
http://www.ehow.com/how_2078853_clean-clogged-inkjet-print-heads.html
Posted on Sep 06, 2008
ksdi
  • 34 Answers
SOURCE: smudged text
Fiend your solution direct from Canon. Here is your solution...
http://www.canon.com/printer/prob676ijt65/solution
286
Posted on Mar 16, 2009
  • 44 Answers
SOURCE: Colours stopped printing one by one - Epson R220
try a damp tissue on the bottom of the cartridge as there could be some ink dried up on there preventing the flow. ear buds work well to.
Posted on Jun 28, 2009
  • 284 Answers
SOURCE: canon pixma mp600 print problem
Don waste your efforts & $, replace the print head is the best policy.
Posted on May 30, 2010
My MP600 will not print documents. It will print a scanned document i.e. scan the doc and print from the image. It will print a webpage. It will print a copy it makes but it is blue instead of black....
If colours are faded I would recommend running several cleaning/deep cleaning cycles to try and pull through the colours. It is difficult to say without seeing the print quality, but it sounds like an issue with a partially blocked printhead within the printer.
The printing in blue would suggest to me that one of the blacks in your printer is blocked. Were all 5 colours present on the nozzle check?
Jul 31, 2013 | Canon PIXMA MP600 all-In-One InkJet...
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
Canon PIXMA MP600 printer. What should be a blue image is turning out "pink". I have followed all the checks, and get a message "nozzels not blocked no need to clean" What else can I check? Ron Knights
Try printing a full colour test chart Get the following and print them out, compare to what you see on screen. This will tell you which carts are working or not working.
You might need to run a cleaning cart through the printer. Are you using compatible carts or originals and if they are compatibles have you used them before? You may also have a problem with the print head.
http://www.hutchcolor.com/Targets_&_images_to_go/P2P_Package.zip
http://www.hutchcolor.com/Targets_&_images_to_go/RGB_Curve_Guide.zip
Both of these are royalty free and can be used over and over.
Sep 09, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Pixma ip4200 willl not print Cyan
I think the problm lies between the ink tank and the printhead. When this passage runs dry, sometimes it takes time for the ink to fill this passage again. Try printing again after a day or two.
Jul 17, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma IP5000 wont print cyan or magenta
Think you need to clean the sponge that the ink cartridges sit on in the head tray they are probably blocked with dry ink. You can remove the print head and tray by lifting the lever and gently lifting it out..... go here http://www.inkjethelper.com/
to see how to carefully clean it with compressed air. I had to do this too.
Apr 09, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Canon mp600 won't print every line
hi! there if streak came to your printed paper,try to go on maintenance menu.doing this left click crontol panel and then click your priter,on printer left click and click properties then click maintenance,on maintenance click clean,make it several time then click pattern test if this acquired quality print,if theres problem try the deep cleaning observe there are much ink to consume in deep cleaning,don,t try to clean your print head w/c not recommend on your manual,otherwise you will damage your printer head,if still streak bring this to your cannon service center to check printer head status,regads and havw a nice day thank's.
Mar 28, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma MP630 not printing all colours
Colour not printing. Check vent hole on cartridge not blocked by glue or bit of the orange tape, cleared mine with knife now works fine
Feb 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon Pixma iP6600D - ink problems
Use original cartridges. Generic or refilled cartridges tend to cause these problems.
Oct 26, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Printer colours
by blue you mean cyan cart. It could be down to the print head bein glogged up, i would do some deep cleans and make sure the machine is purging ok, If not change print head, If not it could be logic board but i have never had it with the cyan colour only megenta and black.
So printhead so clear your fault
Aug 10, 2008 | Canon i850 InkJet Photo Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
271 people viewed this question
Clive
Clive
old marine
old marine
Ekse
