Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
Strict NAT I have the N wireless Router part fd8233-4 and when the xbox 360 is connected the NAT is strict. How do I change that to open
  • 1 more comment
  • Jroberts71 Dec 09, 2007
    I have the same problem and I'm unsure how to check the settings in the solution that you posted. Any help would be greatly appreciated.
  • BADBOY2 Dec 12, 2007
    i have the same problem this sux..even customer support cant help me..theyre pointing fingers at each other..one guy told me call micrsoft the other said call belkin..any one got easy fix?
  • jgreen125 Jan 23, 2009
    I am having the same problem. I can't even get a hyperlink to the NAT page from the home menu. What should I do?
Ok this is how its done. Open your DMZ on your router interface click enable. The IP address you'll have to enter the last digit. This IP address digit is found on your xbox, look under your xbox network setting an get the last digit of IP address an this will only set your xbox to open. bang thats how u fix it. Very simple. any Q's am @ murdock_theory@yahoo.com
Posted on Mar 05, 2010
Here is what I believe the correct solutions are:
1. You can set the xbox with a assigned IP and place it in the DMZ for the router.
2. Or you can edit the port forwarding on your router. There are notes on the xbox live forum. In short. port 3074 TCP & UDP forwarded to your xbox IP address.
Rerun your Xbox network tests and see if you get the OPEN instead of STRICT. This will resolve any Xbox Live connection issues.
Posted on Dec 09, 2007
    Scholar:
  • 70 Answers
NAT is just an IP translation table. Typicallly on your side of a router (private side), IP addresses are assigned at the request of the device (Xbox). The router has what is called a DHCP server which does the assigning. This has nothing to do with security. Well, not entirely true as NAT supplies some Internet protection in itself. Using a DHCP address means your address is NOT looking directly at the Internet as most businesses do.
Since you use the word open, I am taking it for granted you are talking about wireless security. Networking Authentication is done either OPEN or shared.
Here are a few things to check:
Make sure router and Xbox are set for the same type of security, WEP or WPA.
Choose 802.11G for the Xbox.
Make sure the Wirless Network name are the same (SSID)
Same radio channel (0-11).
The Workgroup should also be the same
If unsure how to set these, please reply and I'll send more detailed instructions.
Personally,
I would totally disable the WIRELESS security unless you have really sensitive information that you transmit. It is just more software that gets in the way.
Hope this helps.
Jeff
Posted on Dec 01, 2007
If you click "NAT" on the home page of the belkin routers interface, it hyperlinks to a page that doesn't even have the option to disable NAT. i called belkin and they said to manually assign the ip address and do the whole dmz thing, which doesn't work cause everything stops working. even the xbox live test won't work. sonext i did the the whole tcp udp thing and got all the port numbers and still it will come up with strict. ther has to be something or some way that i can disable the NAT.
Posted on Jan 31, 2008
2 Suggested Answers
  • 11 Answers
SOURCE: xbox 360.......strict NAT
http://support.microsoft.com/kb/908874
I hope that this will be able to help you. It lists the necessary ports and the Microsoft knowledge base solution for this problem. If this is not a help please comment back and I will try my best to help again
Posted on Mar 25, 2009
How do I change the NAT type from strict to open so i can play xbox 360 I have a Belkin 3D54 router
There are several things you need to configure in order to change your NAT to open. Here's a link to help you out:
http://support.xbox.com/en-us/pages/xbox-live/troubleshoot/connection-issues/nat-type-strict.aspx
It has steps that can help resolve your issue.
Mar 27, 2011 | Belkin Office Equipment & Supplies
My NAT typ on xbox live is set to strict i want to change to open
Put the IP Address of your Xbox 360 in the DMZ on your router. Anything in the DMZ is free of all firewall restrictions and all ports are open to this device. Once you place the Xbox 360 in the DMZ your NAT will be Open.
Thank you for using FixYa!
Mar 01, 2011 | Belkin Basic Wireless Router
Xbox 360 - Thomson Router TG585 v8 Strict Nat limits who you can connect to. As you can imagine this creates a problem when trying to connect to friends. Kindly, devliver a simple step by step on how to...
OK, i too have had this problem and i have solved it via this website. This thompson modem is also referred to as... o2 wireless box II/III the website link is
http://www.unofficialguidetolive.co.uk/faqs/62-my-nat-is-strict-or-moderate
Search for the specific (o2 wireless box II/III) modem and follow tthe simple instructions onscreen.
Jan 01, 2011 | Video Game Consoles & Games
XBOX 360 strict NAT problem
Make sure you also open the ports on your router. IF you have all the appropriate ports open and still have strict NAT, it's more than likely your ISP and you should give them a call.
Jan 07, 2010 | Microsoft Xbox 360 Elite Console - Black
How do i change my xbox nat settings from strict to open
I have this router and have just enabled the NAT settings from Strict to Open:-
1. Log into router's IP address (192.168.1.1) and enter password. Select "Advanced Setup".
2. Click on Advanced on left hand menu and select UPnP
3. Check all three boxes in window and click on Apply
4. Close router configuration window and run XBox test again. Worked for me!
Dec 30, 2009 | Microsoft Xbox 360 Arcade
Strict nat settings
go to security tab on the router interface and deselect NAT button.
Jul 03, 2008 | NetGear WGT624 Wireless Router
Xbox Live Strict Nat
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
May 05, 2008 | Microsoft Xbox 360 Elite Console
Strict NAT?
If you call microsoft, and tell them that your NAT is strict, they will tell you specific ports you will need to forward. (For Free). If you arent sure how to forward ports, call up your routers manuafturer, or send me another message. I have forwarded my ports as well.
Apr 20, 2008 | Belkin Wireless-N Wireless Router with...
Change NAT to open
Ok kids... all you hve to do is log in to your belkin 54g at http://192.168.2.1
Find out what ip address your xbox is using and then Click on the DMZportion of your settings on the left hand side of the page.
Enter the xbox's ip address and click the enable box.
Click apply.
Your NAT will now be OPEN!
Cheers!
Mar 24, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
Nat / strict
First, why are you connecting to your laptop? Second, reset your modem and router. I doubt you need to open ports that are not normally open...but if you think you need to do more, access the router and open the ports manually.
Nov 27, 2007 | Microsoft Xbox 360 Console
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
1,677 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
