Back to:
Tags:
PC Laptops
Generic problem for all PC Laptops
Malfunctioning keyboard Sony Vaio PCG K415S
posted by crumpetta on Nov 30, 2007
I have a malfunctioning keyboard. Some keys got damp and don´t work. I hid my PC for a couple of weeks behind a chair!!!!
Does anyone know where I can buy a replacement keyboard?
Sony won´t supply me with one. They want the laptop sent to Madrid at huge expense.
Muchas gracias,
A
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 15, 2008
Helpful (85)
geminii_lady
Rank:Guru Guru
Rating: 86%, 19 votes
Ebay or somewhere similar is your best bet for getting a 'used' and therefore much cheaper replacement. Just type in the make/model of your machine..
Most Keyboards are pretty easy to replace and if your not sure how to do it, run a search on the web or post on here with your specific model etc. If its put together anything like my Sony all you have to do is remove a bit of trim above the keyboard (carefully) and there are 4/6 screws holding the keyboard in place. Remove these and the keyboard just slides out. Then it's just a matter of disconnecting the ribbon and reversing the order to put it all back together.
Good luck, J
Rating Locked! (?) crumpetta has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Malfunctioning keyboard Sony Vaio PCG K415S:
I don't want to Accept this solution
Can you Help with these PC Laptops problems?
IBM ThinkPad T20 2647 PC Notebook
I have a old ibm t20 using windows 08. It worked great and...
HP HP Pavilion DV5234US 15.4" Entertainment...
my computer cant detect audio again
HP Pavilion ze2000 PC Notebook
Hello, please i need to recover ma system (HP Pavilion...
PC Laptops
toshiba satelite a100 model psaa5a-01h00t will not play...
PC Laptops
I am having bsnl broadband connection with Siemens C2110...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
