Ducted aircon error code
I have a mitsubishi heavy ind ducted system and have an error code 48
unit 00 system wont start
  • 86 Answers
1. check cirkit board.
Posted on Mar 17, 2008
What does the error code E04 mean on a ducted email aircon system
BLOWN FUSE IF IT IS QUICK IT WOULD INDICATE A SHORT, IF IT IS SLOW COULD BE A BAD MOTOR STARTING TO DRAW HIGH AMPS.
Dec 10, 2014 | Heating & Cooling
Error code p5 on Mitsubishi ducted mini split
Use Bing or Google and search for the error code and your brand of a/c unit...there are answers and sometimes videos to every problem out there if you search.
May 18, 2013 | Heating & Cooling
I have a Daikin split system ducted aircon. temp on 22degrees.turns off error code flashes E5, and a picture of a spanner
E5 Outdoor activation of compressor over heatprotection or motor lock
Check condenser coil. If dust blocked-clean it.
Check out door fan motor is working. If not replace capacitor or motor.
Check compressor-gradually amps increasing-replace capacitor.
Check for gas pressure. No gas also gives over heat compressor.- Leak test and rectify.
Jan 16, 2011 | Heating & Cooling
It is a ducted Airconditioner When started after few minutes it stops and a control panel indicates: check P08 with kind regards annurag anurag@maluxme.com
Code P8
Error detail Abnormality of pipe temperature.
Inspected unit Indoor.
Check may be icing in your indoor coil due to evaporator coil /air filter blocked- Clean it.
Short of gas or gas leak. Call repairman to find out the leak & arrest to recharge gas.
Helpful?
Dec 25, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Hi I manage a rental property in Mawson lakes with a ducted Mitsubishi R/C air conditioner, model number PUHZ PAR21 MAA (BP100VHA) The new owner has been unable to access the service manuals etc as the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Sep 14, 2010 | Mitsubishi MS12TN Air Conditioner
TRYING TO FIND THE RIGHT DUCTED AIRCONDITIONER COLMAN. FOR 1995 TRAILER
The upper unit doesn't matter ( the actual ac unit on roof ) it's the lower control unit (inside at ceiling) that you need to change to use either ducted or non-ducted system. Any RV dealer can supply that, probably have it on the shelf. Just make sure you write down the model number and serial number, off the bottom of the upper unit, so they can match lower unit to it, for ducted system.
Apr 14, 2010 | Dometic Rooftop RV Air Conditioner
Error message 35 Hi brivis ducted heating
I had the exact same problem and called 1300brivis. They told me that the error means the thermister needs to be replaced. My unit is also out of warranty but they are still going to come out and fix it.
Apr 12, 2010 | Heating & Cooling
What is the difference between ducted roof air and non ducted.
Non-ducted units blow the cooled air out louvers on the unit. Ducted units discharge into a duct system like your home furnace. (Or RV Furnace (heater)).
Apr 10, 2010 | Dometic Rooftop RV Air Conditioner
Our Mitsubishi FDC506HES ducted air conditioner keeps shutting off on hot and cold after about 10 minutes and flashes and the comes up with the error code E3.It will heat for those 10 monutes before it...
Try to reset the error by disconnecting the circuit breaker for 10sec. and "on" again then operate the unit. But if wont work may there some parts that are defective that trigger the error E3. Replacement of pars is needed for this problem.
Sep 22, 2008 | Mitsubishi Heating & Cooling
Heating & Cooling Logo
279 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Marvin
Marvin
