Question about RCA 32F531T 32" TV
RCA pix tearing horizontal lines
Starting problem Dead TV. RCA 32F530T, chassis ATC113CD4. I Replace flyback # 257807 along with the H-O/P XSTR (2SC5148).
> Problem fix. Everything work fine, except i have hatching or tearing lines at one or two places on the screen depending on the white level (contrast), always in half screen area on the top. Same symptom with video and RF input.
>I replace the flyback 3 times with different part # (not original RCA flyback) and suppliers, 257807, 257805 and ACME-2632 (replacement for RCA #261163). Still have exactly the same problem with 2 tv set. I checked parts in the horizontal and vertical circuit, DC supply, everything looks good.
See pictures.
Any suggestion? Bulletin note?
Someone saw that before?
Thanks
Pierre
  • 2 more comments
  • Cailloux Nov 30, 2007
    Additional info: RCA 32F530T TV year 2004 (not 32F531T).
    Original RCA flyback NLA. Use original Horiz output transistor Toshiba 2sc5148.
    If i lower the vertical height, tearing lines disappear. No error code in service mode.
    Ear low noisy flyback.
    See pictures (on one picture, lines appear suddenly and disappear).
    Any suggestion? Bulletin note? Jungle ic? Damper diode failure? Flyback incompatible???
    Noisy horizontal lines appear suddenly and disappear rapidly
    Tearing horiz lines, compress vertical height
    Closeup, white box on black screen
  • Cailloux Mar 25, 2008
    SEE SOLUTION ON RCA TEARING LINES FOR MODEL 32F530T
    http://www.fixya.com/support/t125724-tv_...
  • Cailloux May 25, 2008
    SEE SOLUTION 1, RCA TEARING LINES FOR MODEL 32F530T Chassis ATC113CD4 AT THIS PAGE BELOW
    Genius:
  • RCA Master
  • 1,691 Answers
Get an ESR meter and check all the electrolytic capacitors in the set! I am sure you will find many decoupler and coupling capacitors that are on the edge or too high in ESR.
Jerry G.
Posted on May 25, 2008
  • Jerry Greenberg
    Jerry Greenberg May 26, 2008
    I would not be surprised if you find at least a few dozen caps or more when you finish with the ESR meter!!!
    I've had this many times in older sets. The time to do the work costs more than the parts!
    Jerry G.
SOURCE:
I need a transformer
Hello
It is not clear from your post, that which transformer part number you wants to know. Anyway I'm hereby send you the part numbers of it two main transformers.
[1] Horizontal Ouput Transformer, or Line Output Transformer or Flyback transformer [HOT or LOT or FBT]; Part number is (257807)
[2] Switeched Mode Power Supply transofrmer [ SMPS transformer]: Part number is (257807)
OK.
Dec 16, 2010 | RCA F36650 36" TV
My tv. proscan mod. ps50700 won`t turn on
The PS50700 uses the 195 series chassis. The most common cause of the set not starting up is a shorted flyback (high voltage) transformer. Sometimes a shorted flyback will also cause the horizontal output transistor to short too. These parts need to be tested and/or replaced by a tech familiar with the RCA 195 chassis.
Aug 17, 2007 | Proscan PS65000 65" Rear Projection...
Dead TV
on that model it may be the flyback or the Horizontal output or Both. Comon on that chassis. Let me know if you need more assistance.
May 23, 2008 | RCA P52960 52" Rear Projection Television
Buzz When I plug the tv in I get a buzzing sound and the power button does not light up and there is no picture or sound.Could it be a tube?
quietlove,
I will guess you remember tube sets from our parents days !
They stopped being Mfr'd in 1972 !
Best solution for your set = replace horiz transformer and
transistor with RCA part # 's 257807 & 237470................T.
Nov 26, 2007 | RCA 32F530T 32" TV
42H83 Occasional shutdown
Check convergance amp ic and loose connections to the yokes.
Nov 17, 2007 | Toshiba 42H83 42" Rear Projection...
Switch mode power supply not switching and buzzing when powered up.
Common failure " buzzing " cause = bad flyback transformer
& horiz output transistor = replace both at same time.......
part # 's 257807 & 237470 RCA only No sub's.........T.
Oct 31, 2007 | RCA 32F530T 32" TV
Tv will not turn on with remote or when I press the power button on the tv.
The P52960 uses the PTK195 series chassis. The most common cause of that set not starting up is a shorted flyback transformer. It is quite easy to test and replace the flyback transformer in that chassis, but that should be done by a qualified tech experienced in RCA projection sets.
Sep 18, 2007 | RCA P52960 52" Rear Projection Television
Won't work
It sounds like something in the high voltage (flyback) circuit failed. If any little thing shorts in these RCA's they will not start up. Stargazer
Apr 15, 2007 | RCA 32F530T 32" TV
TV won't turn on
32F530TCD4
I received this solution:
"This was apparently caused by using replacement flybacks. Add a .001uf cap ([email protected]) from RL03 (the side away from the FBT) to ground. This will shift the picture a little then compensate a little with parameter 15."
In my case, i used an other flyback the HR8934 from Diemen to get a more stable picture without blooming, and add a 440pF (two 220pF capacitor in parallel) instead of .001uf to eliminate the tearing lines.bfde541.jpgac61dec.jpgdda8fac.jpg.
Dec 01, 2006 | RCA 32F530T 32" TV
RCA 32F531T 32" TV Logo
605 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
