Sony HDTV Convergence Issue
Hi!!! I have a convergence problem on my TV (auto focus and manual convergence adjustment did not fix the issue) and I think, based on many messages and postings over the internet, the convergence IC is bad on my TV set. Can you please advise me the Part Number of the Convergence IC that I must buy to replace the bad ones?
  • Bigg E Feb 24, 2008
    Hello. I also have the same problem. The convergence seems to be fine, when t.v. first turns on although after a few moments the convergence bows and auto reset as well as manual convergence does not work. Any solutions??
  • Anonymous Feb 01, 2009
    Sony KP57WS510 rear proj TV with double image
  • 4 Answers
I have the same issue, on my 60pp9202. It works some times, and then its ok. If I leave it on, it will be ok, until it gets turned off.
Chuck
Posted on May 09, 2008
No, You will not solve the problem with only changing the convergence IC, associated resisters may also be required.
Beside of that, after spending time to get parts and replace the ICs, you need to make and adjustment the color lines (about 14 lines)
This adjustment without experience will take you about 3 to 4 times and 4 hours each to get thing right (if you areskillfull, most of people failed this adjustment).. The total time spend for this problem would take you full 24 working hours.
I successfully adjusted one set of my big TV (95%, need more more round)), on another set one I failed.
Posted on Dec 18, 2007
Can I manually adjust the convergence on a Sony KP 57WS500
that model has an auto focus so if thats not correcting the issue then the ICs will need replacment. The sony type 1 convergence repair kit from www.tvrepairworld.com should solve the issue.
Feb 22, 2011 | Sony KP-57WS500 57" Rear Projection...
Sony rear projection tv will no longer focus. tried flash focus & manual focus
Convergence issue. The sony type 1 convergence kit from www.tvrepairworld.com should repair that issue. The kit contains the parts and CD with instructions.
Dec 31, 2009 | Sony KP-57WS500 57" Rear Projection...
Convergence issue
You would have to go into the service menu to do fine convergence adjustments - The best way to approach this is to get a service manual - available online $ at servicemanuals.net - Also double check all the 3.9 ohm resistors near the convergence IC's
Nov 06, 2009 | Samsung HC-P4752W 47" Rear Projection...
Focus issue after replacing convergence IC's
pull the fron grill off the set then remove the cardboard covering the hole that is in the front of the set you will find a square box that has 6 controls on it adjust the focus for the red, blue and green crts, do not adjust the three marked screen control.
Sep 10, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony projection TV colors out of alignment
Solution:
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com.
They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Feb 02, 2009 | Sony KP-51WS510 51" Rear Projection...
Red Covergance Issue
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in or warped.
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
Its a fairly easy fix.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Jan 27, 2009 | Sony KP-46WT500 46" Rear Projection...
Convergence issue
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, pico fuses, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 06, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
How can I do Auto Convergence on my 52" TV
The auto convergence should run automatically when activated, If it doesnt you will need to replace the convergence board.
May 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Model Sony 61HS30
no, if touch focus didnt correct it, you will need to replace the convergence ICs
Mar 20, 2008 | Sony KP-46WT500 46" Rear Projection...
Televison & Video Logo
342 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
