You have two choices about remote cable:
1-connect it direct from car's acc or sound itself (everytime you turn the key to on amp will be on too(.
2-Connect it direct from ACC, but put a switch between acc and amp(you will be able to turn it on only when you need it).
Do you have the remote on from the head unit hooked up. If there is nothing to tell the amp to turn on it wont. You can bypass this to see if the thing works by using a jumper wire from the power wire to the remote on. I don't suggest leaving it like that though cause it will drain your battery over time. You need to hook the remote on to a power source that is only on when the radio is on. Like a power antenna wire.
