Problem with Canon PC-940 Black and White Copier
Canon ir2016 system error E007
7 Solutions
How can i resolve this problem?
I dont know what it is?
Should i call Service engg for this?
  • View Previous Comments...
  • avatar
    Keegan kapepe my photocopy canon ir2016 7 is showing system error
    Feb 27, 2013
  • avatar
    kidanG system error E007
    Nov 30, 2008
  • avatar
    kidanG my iR2016 displays "system error E007, would you please help me repairing it?
    Nov 30, 2008
  • avatar
    Guest Mon copieur IR 2016 affiche Erreur système E007. aidez moi à la depannez ou envoyer moi le manuel de dépannage des codes d'erreur.
    Aug 27, 2008
  • avatar
    dquao i recieve system error E007 on my cannon IR2016J photocopier what could be the problem and how do i solve this
    Aug 14, 2008
  • avatar
    Guest may machiner endcate error e007. help me how to remove it
    May 21, 2008
  • avatar
    shukuta i have the same problem system error E007 how can i fix it
    Apr 07, 2008
  • avatar
    Mustafo I have the same problem, "systme error E007". Please let me know if anybody knows how to resolve this problem.
    Mustafo
    Mar 01, 2008
6,920 people viewed this problem
  • 25 people found this problem to be helpful.
  • 1 person is following this problem.
More Insights on Fixboard
7 Solutions
This solution has been voted best by the Fixya Commnunity
Canon ir 2016j photo copier displayd system error E007.
how to solve this problem?
This is not good. You have a bad fixing film,on your fuser unit. You may have to call your service rep.
Checking the Network Connection
If the machine supports a network feature, check the network connection following the procedure below. 1) Press the following keys to display the service mode screen: Additional Functions Key > 2 Key > 8 Key > Additional Functions Key 2) Select "# REPORT" using the + or - key, and then press the OK key. 3) Select "REPORT OUTPUT" using the + or - key, and then press the OK key. 4) Select "SPEC LIST" using the + or - key, and then press the OK key. 5) When "SPEC REPORT" is displayed, check that "BDL-IMAGE" is set to ON. MEMO:
"SPEC REPORT" - TOTAL MEMORY: 128MB BDL-IMAGE (600) must be set to ON. - TOTAL MEMORY: 256MB BDL-IMAGE (1200) must be set to ON. 6) Contact the system administrator of the customer to make network settings. System Settings
Additional Functions Available Settings 1. SYS. MANAGER INFO SYS. MANAGER ID, SYSTEM PASSWORD, SYSTEM MANAGER 2. DEVICE INFO DEVICE NAME, LOCATION 3. MANAGE DEPT. ID OFF(*), ON; REGISTER DEPT. ID (PASSWORD, PAGE LIMIT SET., ERASE), PAGE TOTALS (VIEW PAGE TOTALS, CLEAR ALL TOTAL, PRINT LIST), PDL JOBS W/OUT ID (ON(*), OFF) 4. MANAGE USER ID OFF(*), ON 5. NETWORK SETTINGS TCP/IP SETTINGS: IP ADDRESS AUTO. (OFF(*), ON; DHCP, BOOTP, RARP), IP ADDRESS, SUBNET MASK, GATEWAY ADDRESS, USE LPD (ON(*); PORT NO., OFF), RAW SETTINGS (ON(*); PORT NO., USE BIDIRECTIONAL, OFF), USB HTTP (ON(*); PORT NO., OFF), SET IP ADD RANGE (OFF(*), ON), RX MAC ADD SET. (OFF(*), ON) SNMP SETTINGS: USE SNMP (ON(*): PORT NO., OFF), COMMUNITY NAME 1, COMMUNITY NAME 2, SNMP WRITABLE 1 (ON(*), OFF), SNMP WRITABLE 2 (ON, OFF(*)) DEDICATED PORT: ON(*), OFF ETHERNET DRIVER: DETECT (AUTO(*), MANUAL), DUPLEX (HALF DUPLEX(*), FULL DUPLEX), ETHERNET TYPE (10 BASE-T(*), 100 BASE-TX), MAC ADDRESS VIEW IP ADDRESS: IP ADDRESS, SUBNET MASK, GATEWAY ADDRESS STARTUP TIME SET.: 0(*) to 300 SEC. 6. COMMUNICATIONS TX START SPEED: 2400 to 33600(*) bps RX START SPEED: 2400 to 33600(*) bps MEMORY LOCK SETTI: OFF(*), ON (PASSWORD, REPORT PRINT, MEMORY RX TIME) R-KEY SETTING: PSTN(*), PBX (HOOKING, PREFIX) 7. REMOTE UI ON(*), OFF 8. ACCESS TO DEST. RESTRICT NEW ADD. : OFF(*), ON FAX DRIVER TX: OFF(*), ON 9. CHECKING THE LOG ON(*), OFF 10. USE DEVICE USB OFF(*), ON *: Factory default
  • avatar
    Andin Aeristino Muliadi Removing the Fixing Unit
    1) Remove the two screws [1], and then detach the inner cover [2] at the upper front.
    2) Remove the screw [1], and then detach the heater harness cover [2]. Disconnect the connector [3].
    3) Disconnect the two connectors [1], and then release the fixing unit harness from the wire saddle [2].
    4) Raise the delivery upper guide [1]. Remove the three screws [2], and then remove the fixing unit [3].
    RATE ME PLS!!!!!!!!
    Sep 22, 2009
Voila la solution detalis sur dns sous line
praparer par moi meme
bonne chance mes Amis
pour telecharger clicer sur le line au coper coller dns l'adress de votre navigateur internet
http://www.speedyshare.com/files/21483515/Erreur_system_E007­.pdf
I asked how to solve error 700 on ir2016j damn it any body there to help
Reinstall the drivers and try once later u can contact them ...
Canon 2016j E019 plus it says replace the toner how can i solve it plz help me
  • avatar
    abh_tariq plz remove the drum unit ,remove the waste toner ur problem will disapear
    Nov 18, 2010
Add your solution
Full Name
Top Canon Copiers Experts
Canon tech CROATIA
  • Solutions: 1219
  • Level: 3
  • Achievements: 1
Chris Coughlin
  • Solutions: 1218
  • Level: 2
  • Achievements: 2
Paul Pettit
  • Solutions: 270
  • Level: 2
  • Achievements: 1
Expert Badge
Are you a Canon Copier Expert?
Answer questions and help others.
Users Who Viewed This Problem Also Viewed:
See More PC-940 Black and White Copier Related Problems
Unsolved Problems:
See all Canon PC-940 Black and White Copier Problems
Loading... Loading...
