Home | Bosch | 24 in. SHU66C05 Stainless Steel Built-in Dis... | Dish washer is sel...
Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
Problem for Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
Dish washer is seldom used , maybe twice a year.
By brianandpam1 on Aug 14, 2009
Dish washer is seldom used , maybe twice a year. Notice during a drain cycle that the pump makes a squaling noise.This happens only after the load of the water has pass through the pump. The dishwasher is a boush,is there impeller style pump? Maybe dry rot ?
Best Solution
posted on Aug 14, 2009
Helpful)
scspriggs
Rank: Guru
Rating: 91%, 599 votes
The pump impeller is probably plastic -- if so, dry rot is out.
Most likely the pump shaft is just dry from lack of use. More use will probably wet it enough to stop the squeal.
Charlie
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thanks . I have already started running it more frequently. Brian " - brianandpam1
Popular Solutions for Bosch 24 in. SHU66C05
Questions and Unsolved Problems for Bosch 24 in. SHU66C05
Do you recommend Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher?
Answer
Answer
I found that by initially disconnecting the pipes and cleaning them out (without the usual... (More)
Answer
our bosch dishwasher had some water on the floor . I think it's coming from the bottom seal of the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch 24 in. SHU66C05...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
