Question about Cell Phones
How can I set repeat incoming text alert tone till text is read.
My Nokia 2680 gives incoming text alert tone when text first arrives but doesn't give reminders if text not read straight away. How can I get it to repeat alert tone every x mins till I read it.
  • 1 more comment
  • shells2641 Aug 18, 2009
    Sorry but this fix doesn't work! I still only get the initial alert tone when text received. No follow up alerts!
    Is it possible to change the time delay between alerts in which case it might be preset for 24 hrs for all I know?
    Thanks for trying anuway !!
  • shells2641 Aug 20, 2009
    Ok, can you explain how I set time delay. I can't find anything in settings that refers to time delay.
    Likewise with changing text tone to ring tone ??
    Help please.
  • shells2641 Sep 01, 2009
    Hi Snuggles75. Despite trying all you suggest I can't make the mobile do repeat alert tones. Maybe the mobile software doesn't give this facility ? Can anyone who has a Nokia 2680 give me some help please?
    Thanks in advance. Chris
  • 97 Answers
This should be in sound setting its absending you want set it on
Posted on Aug 14, 2009
  • snuggles75
    snuggles75 Aug 20, 2009
    you could try time delay see if that works or can you not set text tone as a ring tone
SOURCE:
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
Can i make any of my ringtones be the tone for incoming texts and also, can i use animated wallpapers that actually move?
you can download animated themes at www.mobile9.com and www.zedge.net for your e71 phone. as for the ringtones, yes, you can use these tones to be the the incoming tones of your text messages. go to setings, profiles, general,choose personalise, message alert tone and choose your favorite aac or mp3 tone to be your message alert tone.
Nov 02, 2010 | Nokia E71 Smartphone
How do i put phone on silent
User profiles
This is used to set up the different ways of incoming call prompts in various situations. Use
the up/down key to choose this option and click the left functional key to enter. There are
many modes of setting available and the default setting is the general mode.
To switch to a new user profile, use the direction key to select the target mode and click
“OK” to enter. Then select “activate” and click “OK” to confirm. Your phone will give an
“activated” prompt, indicating that the user profile is active. The “headset” mode does not
require activation; your phone will automatically switch to the “headset” mode if a headset
is connected to your phone, and back to the previous mode when unplugged.
You can also customize each user profile setting for your preference, the following
operations are available:
(1) Ring tone settings:
Incoming calls: Enter “user profile”, select “personal setting”, and set up the ring tone.
Power on: set up the music for power on.
Power off: set up the music for power off.
Message: set up the message ring tone when a new message arrives.
You can also download ring tones online.
(2) Volume
This allows you to set up the volume for ring tones and keypad tones. There are 7 grades
available. Enter this function and use the up/down key for testing and adjusting.
(3) Alert type
This is used to set up the alert type for incoming calls. Please select the suitable alert
types in different situations.
Mar 25, 2010 | Cell Phones
I have a ring tone stored in my files how can i move it to use it for incoming tex alert
you may try to do these steps.  1.  press menu 2.  select settings 3.  select phone profiles 4.  press and select the >> (double arrow) normal profile or what ever profile you have chosen. 5.  beside the normal mode you will see there a drop down list, a box with down solid arrow  6.  press that box and it will give you the least of options 7.  select new messages 8.  under new messages settings you will have a list of options,  9.  select and press message alert tone and browse for the files stored in your memory card. 10. press save and exit the setup.  >> you don't need to copy or move the files you want as text alert tone for it will move automatically once you assigned it as message tone.  >>to check if your files has been moved, from your menu, press my files, filter your files through drop down list, select phone memory, it will give you the list of files there.
regards.
Mar 05, 2010 | Samsung Jet S8000 Cell Phone
Nokia 5800 beeps repeatedly on calls
It is something with the key lock of your phone. If you don't want to phone to give a beep for you then change the settings from your profile and find there the settings for warning tones and keypad tones.
Nov 09, 2009 | Nokia 5800 XpressMusic Smartphone
Not working ringer
menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
Jul 03, 2009 | Nokia 3100
Mp3 message tone alerts are truncated on k800i
I use sony ericsson K810i, tone alerts donot play till the end of the songs, it plays only about 1 minute to 1.5 minutes to the max and the same repeats. Sony is just like this...
Mar 28, 2009 | Sony Ericsson K800i Cellular Phone
Boss moans at the VOLUME of my message alert
Try to go to Userprofiles --> General --> Customize --> Tone setup --> Message tone.
Thanks,
Mar 26, 2009 | Nokia N73 Cellular Phone
Nokia N73.Incoming message alert gone..No tone,vibration,message envelope
Follow this steps in the given order -
1) Switch off your phone
2) Remove memory card
3) Switch on your phone
4) Ask a friend to send you a message. Now you will hear the tone
5) Switch off, insert the memory card & switch on again
6) Ask someone to send a message again. It will work
Nov 07, 2007 | Nokia N73 Cellular Phone
Cell Phones Logo
1,095 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
