Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
No water kenmore 596.52673 refridgeratorI have no water to icemaker and door dispenser. I confirmed good water presure to refridgerator inlet valve. can filter prevent flow? filter is relatively new. Thanks
  • 19396 Answers
SOURCE: Icemaker not getting water
Check that the solenoid activating water to icemaker is working and that cubes are not getting stuck inside the icemaker.
Posted on Aug 21, 2008
  • 58 Answers
SOURCE: Kenmore Refrig with Filters water and ice dispenser- water is dripping when not in use, no flow when activated
valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
Posted on Oct 31, 2007
  • 298 Answers
look inside the ice maker and see if the shut off leaver is stuck.
maybe a chunk of ice stuck in it. thanks for rating ;-)
  • 958 Answers
SOURCE: Kenmore Coldspot 10650522100 - water not getting to icemaker
look and inspect closely why the water is not going down the ice tray. maybe the soft hose to lead the water down to the tray is kinked or broke.
check also if there are still ice in the tray, they could have not dropped yet that is why water is just overflowing on the tray.
tnx 4 using fixya,
Posted on Sep 19, 2008
  • 98 Answers
SOURCE: replaced icemaker with new one but still not working
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs
Posted on Apr 01, 2009
  • 103 Answers
SOURCE: Kenmore 106 50522 water leak from Icemaker
Hi: Usually if the ice maker malfunctions that bad it will keep running and flood bad. If your defrost drain is plugged it will puddle water. Without knowing how much water you see it is tough for me to say precisely. Does the ice bin have a big block of solid ice or cubes? If cubes I would guess it is the defrost drain at the bottom of the fridge. If the drain is clogged the water wont get to the pan to evaporate. If the defrost water has nowhere to go it will puddle. This would produce more water on the floor in a humid area than a desert like I live in. If so look at the bottom of the freezer in the back below the metal panel. Usually there are slots above it. There will be a hole at the bottom of a shallow rectangular funnel. Turn off the fridge and put your food in a cooler. Pour some warm clorox water in the hole, a fairly strong solution. It should eat out the mold that grows in the base of this non refrigerated line. If something like a frozen pea got in the line you might have to use a pipe cleaner to snake it out. Good luck with this, Jeff
Posted on Jun 01, 2009
0 characters
1 Points
How do i fix ice maker
Could be 2 different problems. Inlet water valve is a dual valve (2 halves). 1 half feeds water to the door dispenser, the other half fills the icemaker. The icemaker half could be bad or blocked up with sediment causing a no fill situation. 2nd problem could be the icemaker itself which sends power to the inlet valve when it needs filled. Usually the inlet valve fails first but you need to test and see.
Apr 14, 2015 | Refrigerators
Kenmore coldspot model 5155 2101 we just replaced the ice maker. I can fill it with water, it freezes and dumps but does not refill. the water dispenser on the door works fine
From what you are stating this is a dispenser refrigerator with 1ce/water through the door. This type refrigerator has a dual sided water inlet valve. It looks like the half that fills the icemaker may be bad or may have the power connector that came loose. This is the part on the back that the house water line connects to. It should 2 wires going to each of the 2 coils (total 4 wires). If wires are connected, I would say 1 coil is bad and the valve needs replaced. Since you already replaced the icemaker that rules that problem out.
Apr 12, 2015 | Kenmore Refrigerators
Ice maker not making ice, but water dispenser working, just changed filter
If you changed the filter than water may not have made it to the icemaker yet. If you have givin it 24hrs than check these.
There are only 3 things that will prevent an icemaker from not making ice.
1) Temperature in freezer. Most icemakers require that the temp in the freezer is at a minium of 6 degrees. If the thermostat in the icemaker is not reading this temp or below it will not let the icemaker call for water to make ice.
2) Icemaker. Is the arm on the icemaker in the correct position. Most models the arm should be down to operate and up to be off. Faulty icemaker. The internal components of the icemaker may have went out.
3) Water inlet valve. If the silinoid for the icemaker on the inlet valve is stuck it will not allow water to the icemaker. Over time inlet valves wear out.
Troubleshooting- Check the temp in freezer. If not 6 degrees or below you have another problem with your freezer. If at 6 degrees or below and you have ice and water through door unplug fridge, switch the two hoses from the inlet valve (NOT Possible on all inlets so check to make sure you can remove the hoses by pushing in on the cylinder that hose feeds into and pulling hose out) Switch the hoses than press the water through door feature. If you get water inlet valve is good. If you dont have ice and water though door than have your inlet valve tested. If inlet is good and temp is good replace icemaker. If you have any questions or need further assistance please respond. Thank you
Aug 01, 2011 | Whirlpool Refrigerators
I have a kenmore side by side icemake & filtered water and their is no water coming out now.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Feb 03, 2011 | Kenmore 53642 / 53644 Side by Side...
The water dispenser on the door works, but the ice maker won't make ice
Pour about 1/2 cup of water into icemaker . If it dumps the cubes after freezing , but doesn't refill with water , then replace the water inlet valve ( part that wall water line connects to on fridge ). If the icemaker does not dump and holds the frozen cubes , replace the icemaker . Also check the fill tube at the icemaker to make sure it is not frozen closed , due to a seeping water valve , and make sure the coils are clean beneath refrig of dust , lint , pet hair , etc.
Aug 28, 2009 | Kenmore Refrigerators
No ice
you can feel for water in ice maker. if not then verify inlet valve function. water inlet valve for ice maker side could be seized up
Jun 22, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Connected water supply and confirmed good water pressure. cannot get water to dispense or icemaker to make ice.
Hi, When you push the water switch in the door, do you the inlet valve humming? Is it possible that the wires came off the inlet valve?
If you remove the inlet valve from the cabinet and unhook the large size tubing that leads to the water dispenser, you can engage the dispenser lever in the door and see if water comes out.
I hope this helps you. Please let me know if I can assist yyou further.
May 31, 2009 | Refrigerators
Maytag side by side fridge water dispenser not working
there are two water inlet valves on the back of refrigerator, one for icemaker the other for water in door. the valve for the water inlet is plugged or the soelinoid coil is bad. replace faulty valve, usually about 20 to 30 greenbacks at the appliance parts store
Apr 09, 2009 | Maytag MFI2568AE Side by Side French Door...
I have a kenmore 106.52603100 side by side refridgerator. A few days ago we found water in front of the unit on the floor, it appeared to have come from the ice maker and it is now not working, no water is...
First thing to check is if the water inlet tube is blocked with ice or not. Often this is the case and people have their icemakers replaced with no luck. It the tube is not frozen with ice, then check the arm that turns your icemaker on and off. this should be in the down position. There may be a reset button on the front of the icemaker.
There is one solenoid that control water to the icemaker and a different one that supplies water to the dispenser. Often the Ice solenoid will quit. If you are good with an electronics meter, you can test the resistance across each solenoid....they should each measure the same. If one reads open or much less then the water supply valve is bad.
Nov 29, 2008 | Refrigerators
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
19 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
John Tripp
John Tripp
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
