Question about Samsung ML-2510 Laser Printer
Debris in Gearing
I recently purchased a Samsung ml-2510 and it has worked fine until i attempted to print and it made a very loud grinding noise. I checked for paper jams there was none after the loud grinding, the printer would stop the green light was still on meaning no paper jam or any other problem. I took the toner out to all the removable pieces to see if anything was jammed or debris I could see. As a last chance, I shook the unit and heard something loose. When I plugged it back in put everything back in it worked fine. I have tryed to take the casing off but am not sure exactly how to get to the debris. I would like to know where all the screws are to remove the outer casing to remove the debris so this doesn't happen again. Thanks.
  • 84 Answers
Check google for service-manual icq 475653626
Posted on Jan 04, 2008
SOURCE:
My Samsung ML-191x 252x Series printer has a orange light, what does that mean? Also it's not printing and making weird noises.
orange light means that one of the printer cartridge is getting finished. The time it gets red that menas its totally empty.
Jan 31, 2013 | Samsung ML-2510 Laser Printer
My samsung ml 2510 wont print. seems to start up ok, although it had been taking a little longer to warm up recently
hello problem is your toner cartridge change the toner cartridge and try to print.then warming up is became ok.
Jan 13, 2011 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Printer will not work with Macbook Pro - OS X
try to use the Generic drivers and not the Samsung ML driver for your model. In the drivers list type in GEN and it'll show up.
Dec 12, 2009 | Samsung ML-2510 Laser Printer
About 2 years ago, I purchased a Samsung laser printer, model number ML-2510. It performed very well until about a month ago, when I put in a new cartridge, number ML-201003/SEE which was different from...
/SEE is the cartridge for the European version of the printer, /XAA is the version for the U.S. I can't imagine why it doesn't work, but there's a reason for the European designation..
Jul 20, 2009 | Office Equipment & Supplies
Driver for Samsung ML-1640 for WIN98SE
I got the same problem. It seems they did not develop specific drivers for win98se. However, I found that you can print using the drivers for the old Samsung ML-2510. Win98se drivers for that printer can still be downloaded from Samsung website. I've been using the 2510 drivers with the 1640 printer for a couple of months, and worked fine so far. It seems very little change in electronics from the 2510 to the 1640 model.
You need also Virtual Printer Port for USB from microsoft.
Jan 07, 2009 | Samsung ML-1640 Monochrome Laser Printer
CRU Fuse Error
xeregtei bna aa nadad ogooch pls
Sep 30, 2008 | Samsung ML-2510 Laser Printer
Samsung ML 2510 printer won't feed paper
I have experienced the same problem . . . a little earlier this evening. I took all the inner components out, took apart the toner cartridge, I thought that the gearing was very hard to turn on it and on the inside of printer, paper feeding etc... and that is wear the loud noise is coming from. Out of desparation, I shook it to hear if anything internally was loose and there was and still is, I would not say its the best solution or by any means a permanent but you may be able to dislodge the debris from the gearing and be able to print. After it was dislodged from my printers gearing it has worked again. Though I believe it's temporary. I am looking for a guide or how-to on opening the printer casing to physically remove the debris. If you know of a guide let me know and I am sure it would help you too.
Nov 25, 2007 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Laser Printer Logo
575 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
