Question about Tally T2250 Matrix Printer
Abot error message in tally 2250 printer
Printer giving error message "error304" while on the printer
    President:
  • Tally Master
  • 2,022 Answers
Pls reinstall the printer driver
bye
Posted on Nov 30, 2007
SOURCE:
Tally 2250 gives eject error single
The paper path on the 2250 has changed to the single sheet feeder, I guess you are using tractor fed paper loaded into the standard front tractors, if this is the case you can change the paper path to Tractor 1 in the following way;
1.Power the printer off and disconnect the printer from the computer system.
2.Press and hold down the SETUP button, and power the printer on. Keep the SETUP button held down whilst the printer initialises (this unlocks the printer menu)
3.When the printer has finished initialising release the SETUP button.
4.Make sure that the printer is in Offline mode; press the Online key, if necessary.
5.Remove any paper that may be loaded into the printer.
6.Press the SETUP button
7.Press the button under PAPERPATH (button 3)
8.Press the button under TRACTOR 1 to select the tractor feed
9.Press the ONLUE button to exit the menu.
Dec 13, 2011 | Tally T2250 Matrix Printer
Tally 2250 gives error +0017
The error message given by the 2250 would be longer than given in the question. The whole error message gives an indication of what might be causing the problem. Some things you may wish to check include; Check the print head is free to move and is not jammed Check the carriage shaft is clean and free from any sort of lubricant Check the timing strip to ensure this is in possition and is not dirty or warn Check the paper path to ensure the paper is free to feed through the printer.
TALLY 2250 HARDWARE ALARM WITH 000000128 305
you req to diagnose the initializing of tally 2250 printer. most of case initializing problem occured, aga gears coming out is the main problem
Oct 08, 2010 | Tally T2250 Matrix Printer
Tally 2250 driver
you can get it from DASCOM's support pages: support.dascomeurope.com
Jul 05, 2010 | Tally T2250 Matrix Printer
Tally 2250 Matrix printer
tally printer give hardware alarm on every problem gear aliment is very important in tally cheak for function sensor
Jul 21, 2008 | Tally T2250 Matrix Printer
Printer head hot
hot, as in temperature reading? now, that's a cool printer..means it's running to fevered of a duty cycle..need to give some time out between print jobs.
Feb 19, 2008 | Tally T2250 Matrix Printer
T 2250
tally t 2250 give hardware alam
code +03211 ne -007000 000000 128+0304
Jan 19, 2008 | Tally T2250 Matrix Printer
Tally T2250 Matrix Printer Logo
223 people viewed this question
Top Tally Office Equipment & Supplies Experts
Thomas F. Schneider
Alexey Krenvalk
Alexey Krenvalk
Clive
Clive
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
