Question about E-Machines eMachines Desktop PC
EMachine no power
My eMachine T-2692 failed to power up when I pressed the on-off switch (could hear the normal click though). I thought it might be the power switch. eMachine, now Gateway, suggested I assure wires were secure inside. I removed the Green+White lead from the switch to where it connects to the motherboard but found there were (3) connector pins for the (2) wires & now I don't know which (2) of the (3) pins to reinstall the Green+White lead to. eMachine gave me the board diagram but it doesn't agree with my motherboard. I'd appreciate any assistance you can give.
Next step will be to determine if, in fact it is just the power switch or more serious. Any hints here too?
  • 2 more comments
  • richbrfl Dec 05, 2007
    Thanks! First I have to determine where to plug the Green and White wires to. There are three pins (arranged horizontally) and only two wires and I didn't realize that when I removed them. (The schematic eMachines[Gateway] sent me had different connections than my motherboard has.)
    Any thoughts on this? Thanks.
    Rich
  • richbrfl Dec 08, 2007
    OK, did guess at the correct pins to connect the power light wires to & jumped the power switch connectors. Unfortunately, it was still dead. Thanks for your assistance though.
  • richbrfl Jan 09, 2008
    Hashbrown:
    I took mine into a local store and they tried switching the power supply but it didn't work on mine either. They believed it might be the motherboard. Mine went after we had a few weeks of thunderstorms thought I had mine plugged in thru a battery backup/power surge unit.
  • Steven  Moore
    Steven Moore Dec 18, 2008
    I have the same problem with mine accept it is a t-2484. Bought a new power supply hooked it up but still no power. Had a friend to look at it he built his own computer.He took the switch off to test it but it test good. Bought a new computer but would like to fix this one if I cn fix it myself. I took a course on pc repair but this computer is tricky to fix.
    Problem Solver:
  • 5 Answers
Ok for a start the power switch is not green and white that is the power led, you need to look for a red and black wire normally marked on the connector and motherboard as pwrsw or pswitch.
if you believe it to be the switch unplug the connector and jump the connection on the motherboard using the reset switch or a jumper, or not recommended but have done this myself many times using a flat blade screw driver very carefully and touch the 2 pins to complete the circuit.
if it doesnt power on then its more than likely it is the power supply but the motherboard being faulty could also cause this to happen.
the problem i have found with emachines is that its difficult to get replacement power supplys
Posted on Dec 05, 2007
The best bet is to look for the same machine and ask them how they are connected. And if you find out please let me know too, since I have done the same mistake and looking for help. But my model is 2958. As far as I know Black/white is the power switch.
My machine died, I have replaced the power supply but it still didn't turned ON, But there is a small green diode close to the CPU fan that is lit all the time. .
Posted on Jan 09, 2008
  • jmdaddyman58 Aug 26, 2010
    I have this same issue... replaced power supply but still no power, although the small green diode close to the CPU fan is lit when power plugged in whether power supply is on or off.
    Still can't get PC to power up.
SOURCE:
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
Emachines t2042
Whenyou plug in the power cord is there any lights whatsoever on the laptop, wherethe plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the computer is trying to boot or may have booted,but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static ChargeBuildup. Remove the Power Cord, then Press and Hold the power button for30 seconds. After 30 seconds plug the power cord back in and hit thepower button to see if it boots. Maybeyour memory is bad or the memory slot is bad.Removethe Power Cord, Open the Case and remove one of the memory chips. Set thechip aside then try rebooting the computer. If it boots, then you knowthe memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and tryrebooting. If it fails take the chip out and set it aside, then put theother chip in and try booting it in both slots. If it boots, just toverify that the chip set aside is bad, mark an x on it and put it into the openmemory chip slot and try booting.
Jun 07, 2012 | E-Machines eMachines Desktop PC
Power not coming on
Power does not come on for the following reason, THE POWER SUPPLY is bad. Unplug the power cord, then press and hold the power button for 30 seconds. Then plug it back in and hit the power button. If you see no lights, hear no fans running, don't hear the disk drive running, don't hear the cd drive click once and don't see the light on the cd drive come on for a second or two while it clicks, then you are getting no power and need to replace the power supply.
Mar 19, 2012 | E-Machines eMachines Desktop PC
Problems with my emachines monitor. I have an Emachines monitor as my second monitor E17T4 monitor. When the machine is on sometimes it is fine othertimes the screen goes black but the power light stays...
youmight remove your graphics and check the socket for dust restart your computer this should activate the found new hardware wizard
if you run an extended desktop this will tell you if the monitor has gone bad
use a vga lead to attach it
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on
the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
i have read some reviews on your monitor
So the ex-hubby calls me with his woes - his eMachines T3124 is having problems. Seems that when he cold boots in the morning it hits the "E" splash screen and then just goes to black screen. No bios boot screen, no boot to windows. Everything sounds ok though. After a few restarts it boots ok. So, first trouble shoot is to replace the 180w Bestec power supply with a salvaged 300w Hippro from my T6420 (which was replaced with a 500w) - the one I replaced the mobo on. Works great ... for one night. Next morning I get the frantic call - now he gets nothing after the "E" splash but white wavy lines, but the computer sounds like it's running fine. Ok - ok ... think, think. First thought was maybe the onboard graphics have gone, next thought maybe the mobo is going ....
What is the next thing we do after trying a known, good power supply? Try another working montior. I had him try using a trusty older CRT monitor and Wha-Lah! After less than 3 years the E17T4 LCD monitor had failed. Most recent crisis handled. This little incident has made him realize though that he needs to burn all his picture and videos to CD. Scared him to think he could have lost them. Today's reminder? BURN your pictures and videos now! You never known when something might happen. And eMachines monitors are ****.
hope this helps
Sep 30, 2011 | eMachines E17T4W 17" Monitor
Hi my acer notebook does not want to switch on i previously had problems with the charger where it only worked in certain positions.it wont even switch on normally it would switch on the harddrive symbol...
Remove the Power Cord and battery. Press and hold the Power Button for 20 seconds. Now put the power cord back in and Press the Power Button. Did you see any lights or hear any fans running? If not, your power cord is probably bad.
Mar 04, 2018 | Acer eMachines eM2501162 Netbook
I have an emachine model 390 (possibly) which is in trouble. yesterday I found it with its power switch constantly flashing & making a clicking noise. I was unable to turn it off by the switch on the...
Hi Nicki,
Sorry, this really sounds bad, it would seem that the hard drive is shot from your description. The data may or may not be recoverable. If you get a new drive, you will have to partition it first, then set it as your Master drive, then set the old one as a slave, install your operating system onto the master drive and try to recover the information on the old drive after you have that done. If you cannot successfully recover the information that way, you most likely won't be able to get it at all unless you backed it up onto a flash or cds or dvds.
Sorry for the news but that is what it sounds like
Joe
Sep 17, 2011 | E-Machines eMachines Desktop PC
On my Panasonic model th42px75u. no power. When I press the power button, I hear a clicking sound in the power supply area. Checked both fuses. They're good.Thoughts?
Re you getting the standby red light when you switch on the power??????? If not, then I will advise you to check with another power cord which will confirm you that old power cable is defective. If so, check all the connections i.e. power plug, wall socket and the TV end. If all these are OK then the trouble lies with your switch. It is not making contact though it may be giving clicking sound. Have it changed since you have already checked the fuses.
Aug 07, 2011 | Panasonic TH37PX60 37 in. Plasma...
My Samsung TV takes up to 2 hours to come on
Replace any swolen capacitor on the power board.
Sep 01, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
2 year old E machine
Dear zmatt,
Looks like the power outlet or UPS may be at fault. Try a different outlet. That's all I can thik of.
Jul 29, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
1,111 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
