Question about HP Pavilion zd8000 Notebook
Keys not working
Keys randomly not working at exact intervals of 3 seconds . any ideas?
  • ermanno Nov 30, 2007
    1 It happens on all applications
    2 Doesnt matter how fast I type
    3 Dont know yet
    4 About 1/3 of a second every 3 seconds (approx)
    5 I have an external mouse plugged in and it works fine (the problem is with the touchpad as well)
    6 No
    thanks for your efforts!
  • ermanno Dec 04, 2007
    Oh My gosh!!! Problem solved!! Thanks so much Iufan! I had this problem for ages, but never occurred to me that it started happening right when my battery died! As a matter of fact my battery is completely dead (doesnt charge) and I have been wanting to replace it for a while, but always kept it inside. Had NO CLUE that that was the actual cause! You guys are AWESOME. I posted the same issue on techguy.org a LONG time ago and nobody ever replied! THANKS AGAIN!!
I was having the same problem just the other day. The problem with my machine was the battery was dying. Take out your battery and only have it powered on by the AC unit.
Can't guarantee it will work with yours, but worth a try!
Posted on Dec 01, 2007
    Problem Solver:
  • 9 Answers
Here's a few things that we need to cover before determining the next step:
1. Does this occur in all applications or just one?
2. How fast are you typing?
3. Is the issue reproduced in the BIOS?
4. How long does the keyboard lockup last?
5. Have you tried plugging in an external keyboard to see if the problem follows to that as well?
6. Does it happen on battery only?
Let me know the answers, and we can go from there! :-)
Posted on Nov 30, 2007
  • Mike Watson Dec 03, 2007
    hmmm... almost sounds like a resource problem, like the computer all of a sudden gets distracted by something, crunches some data and then goes back to allowing information to be typed. Can you please boot the computer into Safe Mode and test the keyboard again. (Turn the computer on, tap F8 when you see the HP splash screen, choose safe mode) If it works fine in there, then there is something running on your computer causing the problem, if it continues then we may need to consider options like windows repair/recovery. Let me know. Thanks.
    VeeDubber
SOURCE:
Nikon f3hp shutter is getting stuck for random intervals of time
Water damage to the shutter speed dial, or poor contact in its flex connector, can cause this.
Nov 11, 2014 | Nikon F3HP 35mm SLR Camera
How to reset a service interval indicator on a 2003 mini one
Resetting Oil Service Light on your 2002 - 2006 Cooper and Cooper S Hatchbacks, and 2005 - 2008 Cooper and Cooper S Convertibles:
1) Press and hold the trip button
2) Insert key and turn to position 1
3) Watch for RESET to appear
4) Release the button, then press & hold it again
5) Wait for the RESET to flash
6) Release the button, and then press & release (once only)
7) Service interval should then be reset to next interval
If that didn't work, try this:
1. Push the Trip Button
2. Turn ignition key to position 1 and 51A will appear to left of mileage
3. Release trip button
4. Wait 3 seconds
5. Push trip button
6. Wait (5-8 seconds) for RST to appear in left corner
7. Release trip button
8. Push trip button
9. 15000 will appear as new service interval
10. Release trip button
Or this:
1. Press and hold the trip odometer button.
2. Insert car key and turn it to the fi rst position (not the second position).
3. You will see 51A come up in the trip odometer area.
4. Release, then press and hold again.
5. Watch for the word "RST" to appear on the Odometer indicator.
6. Release, then press and hold again.
7. Wait for the "RST" message to fl ash.
8. Release, and then press & release (once only).
Jul 01, 2014 | 2004 Mini One
I have a 2006 Infiniti g35. The fan takes about 10 to 20 minutes to start blowing air out of the vents. Does not matter what setting it is on. Once the fan starts the system works perfectly. Only time I...
I have the exact same issue.
I brought it to the dealership and they expect the problem to come from the AC control unit.
800$CA piece + 2hours (which in fact take 20 minutes to hook).
The does the exact same thing!
We still have this issue so if you figured it out, please let me know.
[email protected]
Jean
Nov 05, 2010 | 2006 Infiniti G35
Garmin GPS 276c appears to download at random time intervals while driving my vehicle such as 19 seconds, 8 seconds, 8 seconds, 9 seconds,19 seconds. Is this normal for the default setting for this...
Sounds like you have the unit set on non road use and or sonar. Please go here and see what you need to do. This does require a lot of reading but without knowing exactly what the unit is set on this is the best I can do.
CLICK HERE'
May 07, 2010 | Garmin GPSMAP 276C GPS Receiver
Flashing alarm light after battery change. Car wont start,
System operation
System arms 5 seconds after switching ignition OFF. Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. If LED flashes rapidly at regular intervals for approximately 1 minute, then flashes at irregular intervals: Key code not recognised. Remove key and try again.
Programming
When
System malfunction: LED illuminates for 1 minute, then flashes at irregular intervals. Key(s) added or replaced.
NOTE: Replacement keys MUST have blue mark. Keys with red mark are NOT compatible with this system.
How
NOTE: Programming method using vehicle keys can be deactivated using diagnostic equipment.
Obtain 2 programmed keys (A and B). Insert key A into ignition switch. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key A. Insert key B into ignition switch within 5 seconds. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key B. Within 10 seconds: Insert key to be programmed into ignition switch. Turn ignition switch to position II. Wait 4 seconds. Switch ignition OFF. Wait 5 seconds. Start engine. If engine does not start and clock LED flashes: Switch ignition ON. Wait at least 20 seconds. Switch ignition OFF. Repeat programming procedure. Repeat above procedure to program remaining keys. Keys can also be programmed using diagnostic equipment
Mar 08, 2010 | 2000 Ford Focus
My speakers keep muting themselves at random
I am having the exact same problem. Has this been resolved yet?
Feb 12, 2010 | Bose Companion 3 Computer Speakers
TV turns off at random intervals.
99.9 % this problem comes when x'tal malfunctions just heat the x'tal of CPU and see if it works replace the x;tal.
Aug 07, 2009 | Sony KDF-E55A20 55 in. LCD Television
Remote key fob will not work-battery replaced
VW/AUDI/SEAT/SKODA
Remote Control Programming (1997 ON)
Procedure
1. Switch Ignition ON and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second
key.
3. Using the remote control press the Unlock button once, and the horn
will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding
procedure. The remote control will now be programmed.
NOTE : When performing programming on additional remotes the procedure
is the same, except you press the unlock button 2, 3 or 4 times for the
different remote.
For example : If programming 2 remotes press the unlock button twice with
a 1 second interval between each press, repeat for 3 and 4 remotes.
5. Switch Ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote
control.
Remote Control Erasing (1997 ON)
Procedure
key.
3. Press the remote control unlock button 5 times in 1 second intervals.
A short horn will sound.
4. Wait 6 seconds and press the unlock button once to activate memory
erase.
5. Switch ignition OFF, all remotes are now erased.
Dec 24, 2008 | 2004 Volkswagen New Beetle Convertible
Gateway 7405 GX Fully shuts down at random intervals
It sounds like a thermal shut down when the processor over heats,one thing it might be is that the heat sink is not seated properly on the processor.When removing the heat sink make sure you have thermal paste to place between the processor and heat sink.That should give you a good starting point.
Jul 28, 2008 | Gateway 7405GX Notebook
HP Pavilion zd8000 Notebook Logo
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
