Question about Samsung TX-R2678WH 26" TV
Hdmi cable is there a specific hdmi cable i need to use to hook up an hd dvd player? will the 28awg  male to male work?
    President:
  • 1,284 Answers
Should be no problem...As longs as its a HDMI cable you are good to go.
Posted on Dec 01, 2007
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
How to Hook Up a Receiver to an HDTV
Things You'll Need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
I bought a dvd player i also i have direct tv not sure if cords are hooked up correctly
Read ur DVD player owner manual?The DVD player have a HDMI hub.Used a HDMI cable to hook up the DVD player are the easiest way.The Satalite Direct Tv is working,fine on ur tv right?So don't worry about it.
Sep 30, 2010 | Maxent MX-27X1 27 in. HD-Ready LCD...
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
May 07, 2010 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
What type of HDMI cable do I need to connect my DVD player to my HD Sanyo TV?
Make sure DVD player and TV have HDMI ports at back to hook with HDMI cable.
HDMI cable has standard plugs on both ends and its length can be different like 3 feet, 6 feet or 10 feet. Click HERE to buy required length HDMI cable.
Oct 23, 2009 | Philips Televison & Video
Sold as HD Ready, but hopw do I connect HDMI to it to get HD picture ?
to hook hdmi to it you need to purchase a hdmi cable and plug it into the tv and then into what ever you want for example like your cable box,dvd player,etc.once hooked up turn tv to hdmi input
May 31, 2009 | Panasonic Televison & Video
Toshiba SD-480EKB DVD player
HD is not HDMI. An HD disc needs an HD DVD player.
Mar 19, 2009 | Televison & Video
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
I'm trying to hook up a PC Monitor to a DVD Player. 15 pin on the monitor and component and HDMI options on the DVD Player. What adapter / cable do I need? Thanks, Paul
I would try Ebay .. sounds like ya need a DB15 Female to HDMI Male.
OR a DB15 female to DVI male plus a DVI female to component/HDMI
The link below should give ya some idea...
http://search.ebay.com/DB15-Female-male_W0QQcatrefZC6QQdfspZ32QQflocZ1QQfromZR40QQftrtZ1QQftrvZ1QQsabfmtsZ1QQsacatZQ2d1QQsaslcZ2QQssPageNameZRC0021QQ_trksidZp1638Q2em120
Jul 28, 2008 | Televison & Video
Samsung TX-R2678WH 26" TV Logo
69 people viewed this question
Jerry Greenberg
Jerry Greenberg
