Question about Pioneer DEQ-9200 3-Band Car Equalizer
Confused between deq 7600 nd 9200
Pls help which one i should go for
  • 83 Answers
Probably DEQ 7600, XD
Posted on Nov 30, 2007
SOURCE:
Upon installing deq 9200....a humming sound exist as i pedal my gasoline
Check your ground wires. Power and audio need to be ran on opposite sides of the vehicle. Try re grounding the radio the a new location. make sure all grounds are connected to bare metal.
Feb 17, 2011 | Pioneer DEQ-9200 Universal Audio Processor
I have a Pioneer DEQ-7600 and every so often I have to tap my dash board in order for the display lights to come on the front of the unit, like it goes in and out every so often, thanks Nick
Nick i believe that you have a simple ground loop problem. To fix that you'll need to run a ground wire from your EQ to the body of the car. (the shorter the wire,the better the ground)
Find the ground wire (black wire) coming out of your EQ. Splice a wire into that wire,and then connect that wire to the black wire coming out of your Head Unit,and that should solve your problem.
Feb 11, 2011 | Pioneer DEQ-7600 15-Band Car Equalizer
My pioneer deq 7600 keep resetting it wont memory
do you have the yellow wire going to a constant power source??
Sep 24, 2010 | Pioneer DEQ-7600 15-Band Car Equalizer
I have a deq-9200 one day it just shut off, I've tried everything, fuses , etc.i dismounted the central part (not the display) and noticed there was a liquid that leaked. Any suggestions?
Check the capacitors near the leak source if they vent ie swell on top then it is possible they have split causing fluid leakage they will not be far from leak on pcb replace the ones that look swelled
Jan 06, 2010 | Pioneer DEQ-9200 3-Band Car Equalizer
I have a Pioneer DEQ-9200 DSP Audio Processor
are your power wires and your rcas on oppsite sides this may be your problem
Oct 27, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
I'm searching for a visual diagram to show the power hook up on the Pioneer DEQ 7600. I need a description of each wire and how to connect.
go to crutchfield.com and type in your model.on the right side of the screen it lists whats in the box.from there you can print a diagram.
Sep 06, 2009 | Pioneer DEQ-7600 15-Band Car Equalizer
DEQ 9200 does nothing but blink
check your remote and ground source make sure remote power have enough ampirage for signal source that can cause it to blink
Jun 28, 2009 | Pioneer DEQ-9200 3-Band Car Equalizer
Need wireing diagram for pioneer deq 7600 4pin plug
I need to see a diagram how or how to setup my equalizer and reverb to my amp all pioneers old stuff sg60 and sg540
Jun 28, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
How to change the color display and brighten it up for a Pioneer deq-7600?
Here's a link to the manual in english...
http://akamaipix.crutchfield.com/Manuals/130/130DEQ7600.PDF
I read thru it, and no mention of how to do it. I do believe it can tho.
Jun 07, 2009 | Pioneer DEQ-7600 15-Band Car Equalizer
Pioneer DEQ-9200 3-Band Car Equalizer Logo
495 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
