Question about Acer Aspire One PC Notebook
Dell inspiron 9300 laptop monitor problems
My laptop only has about 6 inches of viewable space (on a 17 inch monitor) The rest of it is black with lots of vertical multi colored lines running thru it. Also parts will garble on it. I am hoping against hope it is not the monitor since I have been laid off and can not afford another one. Maybe an inverter or cable?? thanks in advance!
  • 1 more comment
  • 0018 Feb 25, 2008
    i have the same problem, and im thinkin it is the cables needing to be reseated but i dont know how to reseat them please help. thanks
  • RSTRADA Feb 19, 2009
    colored lines running vertical on the screen on my 9300 also
  • punchout Mar 19, 2009
    i have the same problem too but what's weird is when i install the driver for my video card it'll expand my screen display to full screen covering all 15". but when i try to play games then it'll shrink back to having the black boarders. i'm not sure if it's my graphic card or not cause also when i'm booting up, my bios, startup screen are all small. only when it's fully booted with the video card drivers install that it'll look normal. i have no idea what's going on.
    Problem Solver:
  • 30 Answers
Hi Friends,
Problem with
Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
12sd1
Posted on Jul 19, 2010
    Sergeant:
  • 324 Answers
Hey Chuck!
Sure sounds like a monitor problem. Wouldn't be the inverter. You could sure try to reseat the cables. One end or the other may have come a little loose. (He sez, with hope in his heart!) . Have included a link for you to get a copy of the service manual, just in case it would be of use to you.
http://support.dell.com/support/edocs/systems/ins9300/en/index.htm#online_documentation
If it is the monitor, you might try to hook up an external monitor, so that you could still use it. That would kinda defeat the portability function of the laptop, but would make it usable.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Posted on Nov 30, 2007
SOURCE:
How to fix a black screen on a dell inspiron 9300
Hook this up to an external monitor and see if you get video. The key combination to activate the external port, normal key that is, [FN]+F4. You may find that you have accidentally hit that combination and turned your monitor off. There are usually 3 positions for the monitor. Monitor and External, Monitor only, and External only so you may have to push the combination a few times. If the external monitor works your problem is your LCD and your best best is to take it to a shop and find out exactly which part is bad unless your familiar with how to open up the laptop and replace parts. If the External monitor does not activate, your only choice is to take it in or replace it. The video card on the motherboard has gone out if the External monitor doesn't come on.
Jul 02, 2010 | Dell Inspiron 9300 PC Notebook
Bluish green colour vertical line is coming in my
Your laptop screen has been faulty. you can checked it from service center.
Nov 13, 2009 | Dell E173FP 17" LCD Monitor
I have laptop dell inspiron 9300 it 17 sreen , it has a white verticle white line about on the middle about inche 1 1/8 wide hohow to fix? thank you...very much
Unfortunately, there is no way to fix it.
This line called "Tab Separation" of LCD.
You'll need whole new LCD display.
Very very common problem.
Apr 29, 2009 | HP Pavilion zd8000 Notebook
Laptop black screen during boot, then normal in Operative System
is it affecting your pc
you can change the bootup display time if you want
but I would leave it as is if your system is not affected by it
Jan 20, 2009 | Dell Inspiron 9300 Notebook
Dell Inspiron 9300 VGA output to 46" Sony LCD problems
Assuming that you have Audio already functional, the solution is to set your system to "Clone" rather than "Extend" video. Right click on desktop > properties > settings > click on second monitor > uncheck extend monitor box (below). Click ok, press Fn + F8 to Clone.
Jan 11, 2009 | Dell Inspiron 9300 PC Notebook
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Dell Inspiron 8100
Try updating your VGA drivers from the manufacturers web site.
Feb 02, 2008 | Dell Inspiron 8100 Notebook
Dell lcd monitor with vertical lines
You have a filter problem, check power supply for bad capacitors.
Mar 24, 2007 | Dell E173FP 17" Flat Panel LCD Monitor
Acer Aspire One  PC Notebook Logo
1,804 people viewed this question
Ekse
Alun Cox
