Question about Durabrand DB1200 CD Player
No wiring harness or plug
I need to know which prongs go to power, memory, speakers etc.
  • 44 Answers
Go to halfords they supply all the leads required.
Posted on Dec 03, 2007
Need to know from top left to bottom right what each wire goes to on power plug on jensen car stereo model vm9311
Hi Jeff, Thanks for the question. When wiring an aftermarket car stereo I always recommend purchasing a wiring harness that will connect into the vehicles existing harness, Then you only have to worry about connecting each wire to it's color coded counterpart. With that being said, if you do not have the stock harness I can explain the wiring colors to the best of my memory
Red = 12v Memory power
Yellow = 12v Constant power
Black = Ground
Blue/white = Power Amplifier
Blue = Power antenna
Grey = RF speaker (+)
Grey/Black = RF speaker (-)
White = LF speaker (+)
White/Black = LF speaker (-)
Purple = RR speaker (+)
Purple/Black RR speaker (-)
Green = LR speaker (+)
Green/Black = LR speaker (-)
Sometimes there is a dimmer wire also, usually orange or pink I believe
I hope this helps, & Thanks again!
Feb 18, 2014 | Car Audio & Video
I have a 2001 CRV. The replacement alternator has 4 prong plug. The one on the car has a green 3 prong plug?
Here's the problem:
http://honda-tech.com/showthread.php?t=2624894
Sounds like you have a Canadian SiR harness (all Candian 6th gen civics use a 3 wire alternator plug instead of the USDM 4 wire setup, IIRC its because the Canadian civics don't have an ELD) easiest thing to do in this situation is to reuse the original SiR alternator.
Don't know where you live or where you bought the vehicle but it's Canadian. Next time you need parts be sure and tell your supplier that it needs Canadian parts.
Oct 05, 2012 | Honda Alternator Crv 1999 99 2000 00 2001...
How many wires do you need to install rodio in truck ?
Let's see.. (1) Power (switched with ignition), (1) Power (always on to hold memory & time), (8) Speaker (2 wires per speaker), Antenna (coaxial cable). Now, the two power can be always on, but you'll have to remember to shut the radio off before you get out. You could have the radio power from a switched power source, but the clock will be wrong and all the station presets will be wiped outwhen the truck is shut off (no biggie if you're only going to listen to the CD player). You could get away with 4 speaker wires - one pair for the left speaker and one pair for the right speaker. The antenna is a must - unless you're planning on listening only to the CD player.
The rest, are optional. The power output lead is handy to turn on any external amplifier or to raise and lower a power antenna. If using an amp, you might want to use phono cables to send line level audio signals to it instead of using the speaker wires to do that - maybe use the speaker wires to drive dashboard speakers directly and use the amp to drive rear or door speakers.
In any case, I'd recommend purchasing a vehicle specific wiring harness. This will allow you to simply unplug your factory radio from the vehicle wiring. After you wire the new harness to the aftermarket radio, simply plug it into the vehicle wiring as if it were a factory radio. Easy as pie. Not cutting connectors off, crossing wires, etc. Plus, you get to plug your factory radio back in when it's time to sell - and move the aftermarket radio to your new car (after you buy the harness to connect it to the new car anyway). Some vehicles have a data bus that makes the radio an important part of the electronics for sending door chimes, key in ignition signals, etc., and require some pricey harnesses - but they are worth it in the long run. Please take a moment and rate this reply - thanks.
I hope this helps - good luck!
Dec 13, 2010 | Pioneer DEH-P6500 CD Player
My radio in my truck has soped working and I need to install a new radio. However I do not know which wires go to what speakers etc. Can you help me identify which color wires represent the speakers they...
I always would go to bestbuy or walmart to get a harness adapter kit and the radio bezel installation kit to install an aftermarket radio. Just plug it in, and the wires are all labeled for speakers, antenna, power, etc.
Nov 10, 2010 | 1996 Chevrolet Cavalier
Hi. I just need to know what the wires are at the radio. Power, memory,l/F speaker, etc. Thanks a lot! Jerry
If you are looking for harness details, click Sony Support to download installation manual for CDX-GT310 that has info of each connecting wires and if thats not what you are asking then let me know in details to provide you info.
Thanks.
Aug 22, 2010 | Sony CDX-GT310 CD Player
My name is Noah. I have a Volfenhag zx 7150 2 channel amp, and I was wondering if I could use this amp to run my mids and highs. And if yes, how would I run the wiring?
Hello violentj_1_u,
Yes, the amp can be used to power normal speakers on 2 channels.
The best way to wire the amp to a stock receiver (head unit) is to use a pair of wiring harnesses, one the standard harness that plugs into the vehicle wiring, the other a "reverse" harness that plugs into the stock receiver.
First remove the plug from the receiver and plug in the "reverse" harness. Run the speaker leads from the reverse harness to your amp inputs or to a line output converter (LOC) and RCA's to the amp. Then run the amp speaker outputs to the standard harness speaker wires. Plug the original receiver plug into the standard harness and splice the remaining wires, 12V constant, 12V accessory, ground, illumination, etc, together. Connect the 12V switched wire to your amp remote terminal.
Hope this helps.
Aug 25, 2009 | Car Audio & Video
Need to install cd player in 97 wrangler. need to know which wires are speaker ground power etc.
easiest thing to do is to go to best buy and buy a radio harness kit for $15-20 which will plug ontop of your radio harness so you don't have to splice any wires. the kit is a plug on one end and labeed wires on the other end that will tell you where everything you need is to install a new cd player in such as your power, ground, remote, and speaker wires...much easier to do then to splice and trace each wire.
Jul 11, 2009 | Wrangler Jeep Twin Stroller
Wire-ing diagram
Go to your local walmart or bestbuy and purchase a wiring harness for your car... if you need help finding the correct one. ask for help... they are only about 7 bucks... and when it comes to wiring harnesses vs straight wiring... definitely go with the wiring harness to avoid shorts which can cause fires.... and electrical issues with your vehicle.. Please Rate Answer... and i hope that this is helpful to your problem
Mar 24, 2009 | Kenwood Car Audio & Video
2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Good luck
Aduz
Mar 21, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
I am replacing the radio in a 2000 Malibu, and none of the wires for the harness are labeled. We just bought the car used and the plug has been removed. I am trying to find a diagram of the wiring for the...
Your probaly better of find the wires yourself its pretty simple.
First off you need to find the earth wire, its the wire with continuity to ground. Next you need to the wire that has power when the ignition is off, this is you constant/memory wire. Then find the wire that has power only when the ignition is on, this is acc. power wire.
Now to find which speaker wires go to which speaker. depending on how many speakers the car has there should be at least 4-8 wires for the speakers, two for each speaker.
all you have to do is get a nine volt battery an put power to the speaker wires and you should hear the speaker crackle, it wont hurt the speaker at all, if you cant get this to work just look at the wires on the speaker and match them to the ones in the dash.
hope this helps you out
Mar 14, 2009 | Corvette Chevy Malibu 90-04 Car Radio...
Durabrand DB1200 CD Player Logo
258 people viewed this question
Top Durabrand Car Audio & Video Experts
matt martin
matt martin
Are you a Durabrand Car Audio and Video Expert? Answer questions, earn points and help others
