(P1681) This code came up because the gauge cluster stopped communicating with the PCM. You can look around yourself first. Check for blown fuses. A bad alternator could surge the system. Damaged wire could have caused a short. A related component could be defective and affecting the PCM or Gauge cluster. If you have questions please feel free to write back.
Try to download and install the webcam driver. You can download the webcam driver from your computer manufacturer's website (example: http://support.hp.com).
You can also find on the website if your laptop has a webcam software life youcam.
Copy this site and paste it in your ADDRESS BAR and hit ENTER.
http://www.toshibadirect.com/td/b2c/laptops.to
Then when you get on this site, click on SUPPORT and then select "REGISTER YOUR LAPTOP".Once you have registered your laptop you will be able to get the drivers for your computer.
There is a problem in the audio output circuit. Most likely the output IC(S) went bad. This is a solid state unit and there are no user replaceable parts inside them, Please take this unit into a pro to be diagnoised. Good Luck
