Check out the videos Esther. That is normally caused by an overheating issue, and that is always cause by lack of airflow. Check the pipes at the back and the outside vent for birds nests and lint build up.
.Why does my GE dryer keep shutting off?
Most likely, a thermal overload switch is shutting down the dryer because it's getting too hot or the motor is overworking. A gas dryer can get too hot if the vent is clogged and, eventually, this can damage the motor. Or the overload switch itself can go bad. The timer can be broken, too.Feb 24, 2020
It seems like clogged vent problem but as I always say The best method is to do your home work and you must do total trouble shooting procedure and replace defective parts if necessary and
Best way is visual check and check for any faulty component and parts and check all thermostats and sensors and look for clogged vent or any damaged or rusty or cracked components and use step by step deduction method for trouble shooting
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
turn the drum by hand see if it turns fairly easy if it does then you may need to replace or clean the drive motor if not may need to service the tub rear bearing tub glides etc
