Question about Vtech ia5864 Cordless Phone
Vtech IA5864 calls out and won't hang up
I have had this phone a few months now and one day it called a number out but wouldn't hang up all I get is the operator saying if you want to make a call hang up and try again. I can't get it to hang up unless I unplug the phone line. When I connect the phone line again it calles out and does the same thing.
Can I fix this or should I just get another phone system?
  • jefflang Jun 11, 2008
    Calls out, but wont hang up. You have to unplug the phone to successfully disconnect. Then you get a dail tone, but when you call again, it does the same thing. Very frustrating.
  • misty1972 Jul 30, 2008
    Same problem. I bough this phone used on ebay. Owner said it owrked perfectly, but as soon as I go the phone, it won't disconnect th eline. What a POS.
SOURCE: vtech 5.8 GHz and says cant connect
Mine turned out to be not getting power from the surge protector.  Plugged it into the wall and it worked again.  If the power light is off to the base station it is not getting power and won't connect.  I know this is a duh, but I missed it.  Probably not what is wrong with yours.
Posted on Dec 11, 2007
bunnydawg
  • 5158 Answers
SOURCE: I have a vtech 5.8ghs
Reset the phone by unplugging BOTH the adaptor and the phone line (the phone gets some power from the phone line). after you have done that put each hand set into the main base till the lite flickers (not the charging stand)... phone should be good to go after that
Posted on Mar 16, 2009
  • 50 Answers
SOURCE: Phones stopped working. They only read
I'm not familar with the Vtech but I would suspect that all 4 units work off of the answering machine base. It sounds like it is seeing a dial tone.
Take a working phones like the wall phone, if it is easily removed, and use a known good connecting cable between the good wall phone and the jack that the Vtech is plugged into.
If that works, take the connecting cable loose and replace it with the Vtech connecting cable. If that works check the jack on the Vtech for crossed wire. If non found, connect it to the jack the wall phone was plugged into. If this doesn't provide satisfaction, let me know exactly what you did and what happened and we will go from there.
Posted on May 28, 2009
stwill2326
  • 77 Answers
first step is to unplug all power and phone connections from the wall for all Vtech phones and bases.
Second,plug each set and base in the wall for power one at a time.
Go back to the basics and pair the handset with the base of the unit.
Do this for all sets one at a time.
Posted on May 31, 2009
SOURCE: Not Registered Problem
This worked for the 7100, hopefully it works for other models:
When the handset says "not registered", it should still have a "menu" option. Select that, then the only choice is "register", select Ok. Now it says "searching for base", press and *hold down* the "locate handset" button on the base until the handset beeps and wakes up. Docs say this could take up to 30 seconds (it was about 17 for mine).
Posted on Jul 01, 2009
How to unblock a number on vtech cordless phone
see these links
Product Support ' VTech® Cordless Phones
https://www.vtechphones.com/support/technical-support/product/3394
Press VOLUME? until you see Call Block, then press MENU/SELECT. Press VOLUME? until you see Calls w/o num, then press MENU/SELECT. Press VOLUME? until you see Block, then press MENU/SELECT. All calls without a phone number will be blocked.
How to unblock a number on your VTech cordless phone - Fixya
www.fixya.com/support/t26508052-unblock_number_vtech_cordless_phone Mar 4, 2017 - my vtech 5.8 GHz disconnects while I am talking~replaced batteries and charges the phones for 24 hours. I cold talk 10 minutes during this time ... How can I unblock a number on my vetch phone. It ...
Mar. 11, 2018
SOLVED: How to unblock a Vtech cordless phone ...
Sep. 12, 2017
How do i unblock numbers from a vtech phone ...
Jan. 19, 2015
Vtech DECT 6.0 Digital Cordless Phone Unblock ...
Aug. 3, 2014
More results from www.fixya.com
unblock number on vtech cordless phone Google Search
Jun 11, 2018 | Vtech Lands Phones
We have a robo call two times a day - can I block the number? On a Vtech CS5111 phone
The only way to block calls is through your phone service to the house, not on the phone. Call your provider and see if you have call blocking. If not you will need to add that service. Usually for a few dollars a month.
Dec 29, 2016 | Vtech Lands Phones
Where is the volume control on the stupid phone, it is nowhere in the menu and no buttons or slider control
While on a call, press down/CID to decrease or up/DIR to increase the volume. (page 11)
To change the answering machine volume, use the VOL- and VOL+ buttons. (page 31)
To change the ringer style, press PROG, use up/down to select "RINGER". Use up/down to select the desired style and press SELECT. (page 9)
The above page numbers are from the manual at
http://vt.vtp-media.com/ecp/documents/product_Product/606/UserManual/1644/ia5864_manual_bkm.pdf
Jun 21, 2011 | Vtech ia5864 Cordless Phone
How do i enable call forwarding from my vtech phone to my cell phone
Hello! You can turn on call forwarding by pressing 72# then wait until you hear the two tones and dial your number that you wish to send the calls to and then hang up the phone. The two tones signal that it has understood your command and is putting the line into forward mode.
To turn off cal fowarding, press 73# and wait again for the two tones and hang up.
Apr 21, 2011 | Vtech CS5121 Cordless Phone
Need vtach manual for vtech ia5864 answering machine... after my headset lost its batery, now it doesn;t recognize/find my headset. the manual link takes me to the home page.... no pdf to look at.
Try download the manual from the manufacturer's web site at
Apr 09, 2011 | Vtech ia5864 Cordless Phone
If I enter the phone number and then press "talk", the numbers dial extremely quickly, a dial tone comes on, and I have to enter the numbers again. How do I fix this? It is a Vtech 6.0 DECT.
Usually there are two modes provided to all fixed line telephones. Tone mode and pulse mode. Pulse mode will dial the call slowly and Tone mode will dial calls quickly. Your phone is in Tone mode i guess. You need not dial the numbers again. Wait for few seconds and the call will get accomplished!
Aug 01, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
When a caller calls the number, the phone rings and cannot accept a message since the mailbox is full. How do you empty the mailbox?
there is a system to delete mailbox in manual book u can use it or in mail box after selecting option u can find erase or delete option choose it click on yes u can delete ur mail
Nov 01, 2009 | Vtech ia5864 Cordless Phone
How do I take call
  1. To remove a number while listening to your list: Dial 07 as you hear the number, or right after hearing it.
  2. To remove a number when you are not listening to your list: Press *. Dial the number, then press *.
  3. Repeat for each number you're removing.
  4. Hang up.
Feb 28, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Hear other people on phone & phone no longer rings & voicemail not working
Could be line trouble. You probably need to make a service call.
Apr 03, 2017 | Vtech 2432 Cordless Phone
Vtech ia5864 Cordless Phone Logo
245 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
