Question about ASUS A7V333-X (A7V333-X/L) Motherboard
Unstable when starting my computer the first time after installing the asus A7V333-x I had to unplug the computer power cord unhook my monator wait plug all back up and turn my computer on sometimes I need to repeat all a few times to get picture This happens if the computer is turned off and back on whenyou get the computer on and a picture you need to run windows XP disk to reboot to start Running sllooowww shutters and has long pauses in general will not complete difrag and can not update drives
  • fgs2 Dec 06, 2007
    Unstable, here tom19511 sorry it took me time to get back to you. i am not a well man so please be forgiving of my lateness. you are on the track of part of the problem. i no longer need to plug and unplug the monitor and one defrag went to compleation. still can't update drivers, add software, uninstall, still slow stops at no particular spot, cd & dvd players are not working as should sometimes sometimes not, still can't run check and fix disk, and i still need to use xp disk to boot. this is my work computer and i'm not able to get much work. good thing can't trust disk drive to back up. what a mess
    Genius:
  • 1,601 Answers
Set Bios to default, and let me know if this works.
Posted on Dec 01, 2007
Why my skype vidoe call not working.
Hello here is a fault finder guide from skype:
https://support.skype.com/en/faq/FA1267/i-set-up-video-in-skype-for-windows-desktop-but-it-doesn-t-work-what-can-i-do
Here is the asus homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=A7V333-X&p=1&s=10
Make sure all the drivers is updated, by selecting your windows system.
Is the driver for the webcam, installed or updated ???
Look also here:
https://support.skype.com/en/faq/FA3681/making-a-video-call-windows-desktop
Do you see the webcam inhere ???
Update also skype to the latest version.
Good luck
Jan 31, 2013 | ASUS A7V333-X (A7V333-X/L) Motherboard
My problem is that after i istalled win 7, 32 bit, i am now experiencing a problem with audio sound drivers, please advise. tried to install realtek but aint workin.
the drivers are different for win 7 you wont be able to load your driver software if you are having winxp drivers you need to load the win7 drivers to get win 7 drivers you need to search the net and provide OS as win 7
Feb 17, 2011 | ASUS A7V333-X (A7V333-X/L) Motherboard
I have a asus P5GC-MX , i install a nvidia 9500GT but the display will not auto disable the internal graphic although i have set to PCI-E / Int
Did you install the drivers ->First from the CD, then install the graphics card?
No? Start over.
Once you install a device, Windows rushes over to match a driver with it. If you do not have THE driver already installed, (So Windows can find it), Windows will match up one of it's thousands of Generic drivers, or use the Onboard graphics driver already in use.
Power down, unplug the computer from power. Remove the graphics card observing anti-static precautions.
Press the Power On button in, and hold it in.
Hold it in for a count of Five seconds. (Count, 1001,..1002,..1003,..1004,..1005)
Let go of the Power On button. Do this procedure Two more times.
What you are doing is resetting BIOS back to the factory default settings, and clearing CMOS Error Codes.
Now plug your monitor back into the VGA port, in the I/O area of the Asus P5GC-MX mobo.
Plug the computer back into power. WAIT 1 minute, turn the computer on. When Windows has fully loaded, and all of your Start Menu programs, install the Drivers CD for the Nvidia 9500GT in your optical drive. Install the software.
If it asks you to restart your computer, Do Not at this time. Shut the computer down normally. Unplug from power. Observe anti-static precautions. Plug the Nvidia card in. Plug the monitor into the Nvidia card. Close the computer case.
Now, hows that?
[Advanced PCI/PnP Settings should be:
1.Plug n Play O/S -> No
2.PCI Latency Timer -> 64
3.Allocate IRQ to PCI VGA -> Yes
4.Pallete Snooping -> Disabled
5.All IRQ's (3 through 15) are set to -> PCI Device]
Aug 31, 2009 | ASUS P5LD2-VM Motherboard
Hardware monitor found an error
First I would make sure all the power plugs are properly plugged into the motherboard and all other devices.
If that does not solve it then I would get the Power supply tested at a local PC shop. Or just get a new decent power supply. Looks like the Power supply without a doubt is defective.
Jul 08, 2009 | ASUS A7V333 Motherboard
I need the manual for my asus motherboard a7v333 rev.2
The drivers and manual can be found at the link below. They are rather large but if you have a 1gb flash drive or larger you shouldn't have any trouble.
http://support.asus.com/download/download_item.aspx?product=1&model=A7V333
Apr 03, 2009 | ASUS A7V333 Motherboard
Jumper connections a7v333 asus
go to below link and download manual of ur motherboard...
and refer the diagram..
If problem not solve so pls reply me..
thanks and RATE ME
bye
Mar 08, 2009 | ASUS A7V333-X (A7V333-X/L) Motherboard
Picture stays on black
I had this same exact issue yesterday. I own the same TV model and here is what SONY had me do to get the picture back. Ultimately the picture comes back, but it will be very dim and needs repair. Most likely a power supply issue. Try these steps:
-Press power off or leave with standby light on for 5 minutes (wait the full 5 minutes)
-Unplug TV / Press top buttons 5 times each to remove static from system boards (yes, each button 5 times each)
-Wait one full minute and plug TV in and press power on
Jun 03, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
Asus MB av7333 x
Hi fgs2, the manual will walk you through setting up the board including the CPU, memory, connecting case leds. (Everything).
Download your Asus A7V333-X manual from Asus web site by clicking on the the link below. (You might want to save the link).
http://support.asus.com/download/download.aspx?modelname=A7V333-X&SLanguage=en-us
Good Luck! Take your time.
Have more questions, feel free to ask.
Mike
Apr 03, 2008 | Computers & Internet
Asus a7v333 motherboard
try and update your bios, hopefully your timings, were just messed up by the new memory, or you could try a cmos jumper reset.
Mar 03, 2008 | ASUS A7V333-X (A7V333-X/L) Motherboard
ASUS A7V333-X (A7V333-X/L) Motherboard Logo
85 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
