Question about Denon AVR-1082 Receiver
Denon AVR-1082/3802 Using External Power Amp for Front Channels
I have a Denon AVR-1082 that I have been using for the last 5 years with Vandersteen 1Cs in the front and Polk Audio 10Bs in the rear with no center channel or sub. I have a Denon POA-1500 Power Amplifier that I bought 22 years ago, but haven't used it since I bought the receiver. I recently tried to connect the power amp to the pre-out jacks to see if it would result in any noticeable improvement in sound quality. I connected the two front speakers to the power amp and connected the power amp to the front pre-out jacks but got no sound from the front speakers in any mode (stereo, 5 ch stereo, ext in w/SACD, etc.) I went into the system set up menu to the power amplifier assignment selection and tried both the Surround and Multi options without success. Since the manual provides no instructions for this, but shows how to connect the amplifier, I assumed that it should work without altering any settings on the receiver. The power amp worked fine the last time I used it connected to a HK preamp. Any suggestions on what I am doing wrong in the setup or what might be malfunctioning? The HK preamp was creating loud popping noises when I adjusted the volume, so I haven't tried to check the power amp connected to the HK preamp.
  • Dave Dec 13, 2007
    It turned out that the amplifier was not working. I took the amp to the local electronics repair shop for diagnosis and repair. $250 later, I have a fully functioning amp that was successfully able to drive my front speakers. The connections were straight forward. Once the amp was connected to the preamp out and the speakers were connected it worked. The extra power made a noticeable difference in the sound quality of the entire system. It has a fuller sound and handles loud passages better.
  • Dave Dec 13, 2007
    Repaired power amp solved the problem.
SOURCE: Denon AVR-1804 6.1 Channels Audio Problem
Make sure the input setting is set to 'Auto' while on those channels and not Analog.
Posted on Jan 20, 2008
  • 119 Answers
SOURCE: No surround sound from my Denon 3805
well as long as all signals are routed through the Denon your on the right track, now what else you have to do is connect all devices to the reciever do not loop one device through another. Also you have to try the different surround fields to hear the one you like the best for music I use 5Ch stereo for movies the surround field varies based on the type of movie
Posted on Feb 25, 2009
dunnbiker
  • 8546 Answers
SOURCE: left channels do not work when using surround modes
Ohhhhhh, so it has NEVER worked for YOU and it needed fixing when you got it. That changes everything. And you don't have the manual??
You can find the manual on Retrevo.com. Just register and download it. You're going to need it to make use of this unit anyway.
Make sure everything is connected correctly.
Look it over and play around with it. Speaker setup needs to be done before anything else. Did you get the microphone that comes with it? If not, go to page 23 and start there.
Posted on Feb 18, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have Denon AVR-2310...but lost
The manual... http://www.retrevo.com/support/Denon-AVR-2310CI-Receivers-manual/id/23452bh638/t/2/
I'm pretty sure you mean "LFE + Main".
You need to identify the speakers to the receiver as Large or Small regarding their bass-handling capacity more than their actual size.
"LFE" removes the possibly overloading bass in a given speaker channel containing 'small' speakers and sends it to the subwoofer.
"LFE + Main" is sort of explained on page 29 "Bass Setting". The intent of LFE+Main is to task your subwoofer with the bass that ALSO exists on all other speaker channels regardless of their ability to handle it all by themselves. As you can imagine, this might make the subwoofer respond to sonic events that are actually supposed to be directional from, say, the rear channel(s). In that case the event might seem to come from wherever the sub is located instead of the intended direction; or at the very least it might seem to come from both places which is probably not what the sound engineers intended when they recorded the piece.
Having full-range speakers 360-degrees around PLUS a subwoofer, I don't subscribe to the 'bass-is-non-directional' school of thought. If you've ever felt the concussion from and subconsciously glanced toward one of the speakers after, say, a huge explosion, the system is working.
Posted on Sep 04, 2011
  • 163 Answers
SOURCE: I have connected the audio from 3 devices into the
the unit is ok. User manual on page 42 says that the digital sources can not be output trough multisource output.
Try to use VCR-1 VCR-2 audio output jacks instead.
Posted on Sep 26, 2011
Denon AVR1603 RESET
Starzy, to reset on a Denon AVR-1603
  • power off the unit using the front panel Pwr switch
  • press and hold SPEAKER A and B buttons;
  • keep pressing on the speaker buttons, switch on the AVR
  • when the display is blinking release buttons Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.avsforum.com/forum/90-receivers-amps-processors/1386123-help-denon-avr-1603-shuts-down.html
Denon AVR 1603 Operating Instructions Manual Last Function Memory...
Jul 24, 2016 | Denon Audio Players & Recorders
Denon AVR 1508 distortion on left channels
I have a different model, but sometimes suffer this when power outages or other strange things happen. Its usually the microprocessor getting confused and not doing its job properly, once none of the speakers came on at atll!
In the handbook, it will tell you how to do a factory reset - that always sorts mine (Same brand, Denon). Just a pain setting it all up again.
You should be able to find a PDF version of the handbook online if your's is misplaced in the house move.
Dec 17, 2013 | Audio Players & Recorders
Power amp 2 channel connection to Denon a/v amp
You don't mention which AR amp we're talking about.
I think you're trying to say you want to know where to extract the front channels from the Denon to feed the AR amp. Right?
That would be an output on the Denon to an input on the AR.
Basically, take an RCA cable pair from the Denon's Pre Out F & L and connect them to the (presumed) L & R inputs on the unnamed amp.
Set the AR amp at a reasonably high volume (if it has a volume knob) and leave it alone. Run through the speaker level adjustments on the Denon to match the Front to everything else and it will control the volume going forward.
May 28, 2010 | Denon AVR-3300 Receiver
Denon 1906 all the right channels speakers not working
when turn on the amp,the volumn cannot under control
Oct 10, 2009 | Denon AVR-1906 Receiver
Poor DTS/DD5.1 from the AVR-3801
I also run 2 AVR 3801`s in my home, These are nice receivers, excellent build quality, about the DTS and DD 5.1 not up to par, I would check the Menu speaker set-up, be sure and make sure you have rear surrounds set up at surround speakers, NOT the rear speakers, they are for a 7.1 configuration, then set up the white noise test signal to balance all 6 channels, you need to have the powered subwoofer balanced properely, if no results of improvement then check your digital connections, I would recomment the fibre-optic, but the coaxial works also with great seperation signal, last I would investigate the playback unit of the DVD or DTS CD player, something in your set-up is amiss and you can acheive outstanding surround with this model of Denon, I can attest to this for my past experience setting up HT systems even with High End Outboard processors I always am amazed at the 3801 output quality, remember the 5 ch stereo is a Matrix DSP not even close to a true digital sound, and as for more amp power sure it always helps to have extra but the 3801 are true 105w @ 8 ohm 0.05 THD and are real, should power you Missions, the next level are denons 4800`s and 5800`s at 125 and 175 but I would stick with the 3800 and be content. Hope you have some better results after tweaking your settings.
Feb 17, 2009 | Denon AVR-3801 Receiver
Denon AVR-1507 No sound on left front channel
Because the sound is only faint says to me that the power amp that controls the left channel is faulty. You need to look at the device(s) on the heatsink and probably replace them.
Dec 28, 2017 | Denon AVR-1507 Receiver
Help required for dumbo on Amps Denon AVR 2808CI
Your unit was probably damaged in shipping. Denon is a nice unit! Do you hear any clicks when you hit the power button??? You should hear two relay clicks. You should hear the power relay click at power on and 3 to 5 seconds later you should hear the speaker protection relay click if your audio amp section is ok. If you hear both relays click then your display circuit is at fault. Open the unit and look for breaks on the front pcb (behind the display) and on the main board in the power section ( where the fuses are ).
Good Luck!
barneyluc
Oct 10, 2008 | Denon AVR 2808Ci Receiver
DENON AVR 1906
Units dc protect mode is probably activating due to Blown channel (shorted output transistors) I work for a Denon Authorized repair Center in Michigan If shipping to Michigan is economical let me know kstahl65@att.net
Feb 05, 2008 | Denon AVR-1906 Receiver
Jan 18, 2008 | Denon AVR-1804 Receiver
Denon AVR-1082 Receiver Logo
365 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
