Question about Video Game Consoles & Games
KDS xf-70 Monitor kills any pc it's hooked up to. when its powered up its ok, but as soon as a video card sends a singal to it , the monitor apparenly sends a high voltage back to the pc (ive not dissassembled it and tested the voltage), Does anyone have schematics to the hv and control board for that monitor?
SOURCE:
Garfunkel01
  • 56 Answers
SOURCE: x box 1 to pc monitor
there are special units that you can purchase to do this, other than that, there really isnt a decent way, unless you get an lcd with component inputs
Posted on Aug 15, 2007
petraman7
  • 1175 Answers
SOURCE: monitor diagram
www.servicing-manuals.com
Posted on Feb 02, 2008
skotkolr
  • 558 Answers
SOURCE: monitor light blinks
have you tried hooking the monitor up to a known working motherboard video or video card in a motherboard? it sounds like you may not have the settings in the motherboard correct jump the cmos clear to reset the motherboard connect everything then turn on your monitor then turn on the computer and get back to me in this thread.
Posted on May 08, 2008
linktriscuit
  • 89 Answers
SOURCE: Intel Mother Board D875 pbz
Did you try restting the BIOS? Here's the link to that Intel board.
http://www.intel.com/support/motherboards/desktop/d875pbz/index.htm
Posted on Nov 27, 2008
  • 4 Answers
SOURCE: KDS Computer Monitor loses video one half hour after booting up.
first, how long have you had it. if it has intergrated power supply,(does not have a big square box made onto the power cord) nine time out of ten your power converter/supply is going or is bad. return for a replacement. to the manufactuer not the store. they should replace it free of charge, if their honest. samsung has some models with this same problem.
Posted on Mar 18, 2009
I bought a used KDS USA Monitor Model 780 Rad-7SI. Guy told me it works fine but I didn't make him hook it up to anything. I get a power light but screen remains dark. Are there drivers of something I...
If you are using a laptop, try to "toggle" between the screens I think it's the F4 key to see if it turns on...if you are using a desktop see if you have more than one output for video. If you do, try the other port. If not, try hooking up a different monitor to your comp to make sure the video out is working. If so, then with this monitor powered on, lean it back and see if you can see "shadowed" items on the screen. If you can see words or anything on the screen (like the windows startup screen when you first power up) then the light inside the monitor is bad. Hope this helps
Oct 23, 2013 | KDS Radius Computers & Internet
Vidieo input 1 d-sub no singal
sounds like you may have the digital plug attachment to monitor/pc and your pc is not using digital or the settings on monitor is digital but you pc is analog. sometimes the pc cannot send the correct digital signal so you must use the analog plug cord(serial) a blue plug with a odd shape, one end wider than the other. i seem to remember the message you displayed coming up when a friend tried to connect digitally to his monitor but his pc could only send an analog signal so he had to use the other plug hook up. hope that this makes sense.
your monitor may be too new for your pc or vise versa.
Sep 16, 2012 | Gateway Computers & Internet
I have a Hanns.g 28 inch monitor it display no input singal video card is a GF 9600 GSO the monitor will power on but still display no input singal
Your GeForce 9600GSO may be malfunctioning. I suggest you unplug it, remove it, clean out any dust that may be in the PCI-Express slot (you can use a vacuum cleaner), then re-insert the graphics card and plug it back into your monitor. If this doesn't work then you'll need to either try another PCI-Express graphics card in the PC just to test whether it is:
1) The graphics card.
2) The other components such as mainboard, cpu, ram, etc.
If your don't have a spare graphics card then I suggest you take your PC down to tyour local PC shop and have a technician take diagnose the damage.
Apr 16, 2011 | Hannspree HW191D LCD Monitor
The KDS monitor says no signal then shuts off. I was using it on another computer and it worked fine
If it works with another PC OK, then you may have problem in your PC Video card, try reseating the video card if you can, also the RAM sticks. If the video card is part of the mother board then there may be nothing that you can do.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Sep 26, 2010 | KDS Computers & Internet
Wanting to hook up a different monitor to a notebook. the notebook is a dell and the monitor is kds 780
To hook up the monitor all you will need to do it connect it to the monitor port on the side or back of the notebook it should just start displaying on your external monitor as soon as you hook it up but if it dose not you may need to restart the system. Also the port you need to connect to is the only port on the computer the monitor cable will be able to plug into so don't be worried about connecting to the wrong port on your notebook.
I hope this helped.
Thank you,
Norse
Jul 02, 2010 | Dell Inspiron B130 Notebook
Monitor will not power up, removed monitor hooked
Confirm that it is not the cable, otherwise it does indeed sound like your monitor is dead.
Apr 07, 2010 | KDS Radius RAD-5 15 in. Flat Panel LCD...
As soon as i turn on my computer my monitor says no input signal and then goes to sleep i have an hp
either your video card has stopped working or your cable to your monitor or the monitor is bad. Try to hook another monitor up to it see if it turns off if it doesn't then the video card needs to be replaced. If it does its the monitor.
Mar 07, 2010 | HP Pavilion a305w (DM181AR) PC Desktop
IS THERE A PLACE TO HOOK UP SPEAKER TO KDS XF 7B MONITOR
This monitor doesn't have built-in speakers. You'll have to hook up separate speakers to the audio output jack on your computer with this one.
Feb 26, 2009 | KDS Visual Sensations 7b (Black) 17 in.CRT...
KDS monitor screen turns black
So how long have you had it, and try to blow it out. Sometime they just need cleaning. If that don't work send it back before warranty run out
Sep 27, 2017 | KDS Visual Sensations 190 (White) 19...
KDS xf-7s, vertical lines
I am sure you have open the casng of the monitor.
Try to look for cold solder ( dry solder ) pin around the horizontal yoke connector and touch up the solder joints.Or either horizontal yoke coil is open.
Caution: not to touch if don't have knowledge of the circuitry .
Solder it the while power is off.
The input is 240v AC and output at the Anode Cap Appox. 28000 volt for 14 -15" monitor.
Have a try.
Apr 19, 2008 | KDS Xtreme XF-7s (Silver, Black) CRT...
Video Game Consoles & Games Logo
35 people viewed this question
Top Video Game Consoles & Games Experts
Ekse
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
