Question about Toshiba TP50H95 50" Rear Projection Television
Sound but no picture
When I turn the tv on, I can hear it but no picture. It tries to restart itself a couple of time then it turns off. Can you help?
Jay Walden
i have sound but no picture, if i move the tv or tap on the sid the picture comes on perfect ,but after while it goes off again, tap again it comes on
  • 934 Answers
This is a common problem that shops see every day... Due to the age, size and ultimately the heat this unit generates in several of the component areas it has developed ring cracks in one or more areas. The likely suspects are the convergence amps - this unit uses two STK392-110 Sanyo built amps mounted on a large aluminum heat sink. Or it coud be the vertical Ic, which in your unit is a LA7833 mounted on a smaller heat sink.
You'll have to remove the boards enough to look underneath and see where these components mount to the foil side of the PC board. If you inspect closely enough (get your reading glasses) you should be able to spot one or more of the pins in either of these two areas that are ring cracked. Simply re-flow a little solder on those pins and put it back together...
If any of this sounds too complicated call around and ask what a shop charges to comeout and solve this kind of problem (ring-cracking) causing intermittent picture loss. It shouldn't be costly.
Good Luck
Bill
Posted on Nov 30, 2007
SOURCE:
Sony KP-57WS520 57 inch rear projection TV. When I turn it on I hear sound and it cuts itself off and standby light flashes 5 times over and over, if I cut it on again I hear sound and then it cuts itself...
sanschargrin,
I hate to be the bearer of bad news but your unit has some optical engine problems. Here is a web site which explains it all and tells you where to apply for class action compensation. http://sites.google.com/site/sonylcdrptvproblems/
Thanks for using FixYa and for the great rating.
hardrocko
Dec 15, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Just replaced the lamp on my Toshiba 62HMX84. Picture still is not coming on I have sound. When you turn on the TV you hear a clicking sound that goes away and then the TV try's to restart itself Thinking...
I have a 62HM84 Toshiba TV. I lost picture on my TV in the past i have bought the lamps and i just put it on and the picture comes on. This time when i replaced the lamp nothing happens no picture. It tries 8 times to turn on, but nothing happens. Can you help me with is what is the problem.
Dec 15, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Hi. I have a 2004 52' Flat screen projection TV. For the past couple months, we have turned on our TV and all we hear is sound, but no picture comes up. We thought the bulb was having problems. We ordered...
The buzzing is the ballast arc gap,normal sound. When the tv starts does the lamp start to come on. Can you see any light from the back? Sounds like bad ballast. Unfortunatly this part is no longer available. the light engine will have to be removed and sent to Toshiba to be rebuilt.
Nov 26, 2009 | Toshiba 52HM95 52" HDTV Projection...
RCA HD61LPW42. No picture/sound.
Ur high voltage FBT,is dead the block of plastic with a red wire with a cap hook to the CRT(tv tube).Might also have to replace the whole power board?Because just couple parts it hard to determins,what else also ready to burn next!
Sep 12, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
TV shuts itself off..red light blinks 7 times.
the only way is by bringing to a tech.i think there is no need fro self-fixing with problems like this.try tapping the tv several times then turn it on.
May 28, 2009 | Televison & Video
I hope you can help me.. I own a Samsung DLP TV model no. HL56A650C1F, 56". The problem I am having is that it just turns off by itself and attempts to restart itself continuously. I hear all of the...
I hope you can help me.. I own a Samsung DLP TV model no. HL56A650C1F, 56". The problem I am having is that it just turns off by itself and lights "stand by" and "lamp" are flashing at same time.Sometimes, when I'm trying to turn it on- it shuts off by it self.
Mar 05, 2009 | Televison & Video
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
standby button blinks no picture no sound have tried to reset and restart nothing has worked to get tv to back on
Mar 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
You probably need a lamp. If after the initial fans turning on do you hear any other odd noises? Lamp pt#BP96-00826A
Nov 30, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
83 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
