Acer Aspire  5610-4648  PC Notebook
Problem for Acer Aspire 5610-4648 (LX.AXZ0X.097) PC Notebook
Crystal eye webcam
By Thoyn on Nov 30, 2007
Hi, when I try to run my webcam program it says a problem has caused the program to stop working correctly and windows close the program and will notify me if there is a solution available. This is the fist time I have tried to use it and I haven't touched any setting
Same Problem
Apr 30, 2009
-   tw-g2390
-   Guest
Nov 22, 2008
-   how instal my web cam to see my friend on yahoo or skipe
-   Guest
May 01, 2008
-   Ever since I bought the travelmate 6492 the webcam has never took any video and the only thing I can do is take picture with a webcam-   Majozi
Mar 31, 2008
-   I have the same problem and the computer says the same thing-   tlsst
Mar 22, 2008
-   my crystal eye webcam,says that it is not available,it came with my lap top what can i do to get it back?-   melety
Best Solution
posted on Mar 11, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
How do you get The Crystal Eye Webcam to where you can see and hear other people?
ILOVEMYDOG!
Solution #2
posted on Jan 02, 2008
Very Helpful)
1cheesehead
Rank: Apprentice
Rating: 97%, 17 votes
I have
an acer 5520, and my webcam also stopped working. I tried everything to sort the problem with no success. I then removed all photographs from the 'pictures' directory and moved them into 'documents'. I could not believe it, the web cam started working again. As soon as any photographs are put into 'pictures' it stops working again. It seems too simple I know, but it works. Try it. My guess is that because the camera takes pictures it ties into the picture folder. When you add any of your own to the folder something beomes corrupt. WEIRD..
Was this helpful?
Yes
No
Solution #3
posted on Dec 02, 2007
Somewhat Helpful)
country42740
Rank: Wiz  Acer Expert
Rating: 80%, 452 votes
the most common solution is to remove or disable the hardware from device manager ,restart the computer and and reinstall or enable the driver(auto or from software support disc-depending by brand)
Was this helpful?
Yes
No
Solution #4
posted on Oct 02, 2008
Not Rated)
bigreggiesr
Rank: Apprentice
Rating: 0%, 0 votes
when i go on yahoo messenger and try to view my acer crystal eye it saying error not connected it a built-in cam what going on you think
Was this helpful?
Yes
No
Solution #5
posted on May 02, 2008
Not Rated)
RUGBYBOY
Rank: Apprentice
Rating: 0%, 0 votes
WAT THE HELL THAT **** WORKS LOL ITS CRAZY I WAS TRYING EVERYTHING.......LOL THANKS MAN
Was this helpful?
Yes
No
Solution #6
posted on Apr 12, 2008
Not Rated)
vuchiri
Rank: Apprentice
Rating: 0%, 0 votes
i have a acer traqvelmate 7320, and i was not able to get the ale cer cam to work eather, UNTIL i unistalled the the hole pack, and ONLY installed teh diver for the cam.
http://support.acer-euro.com/drivers/notebook/tm_7320.html
Select webcam BISON DRIVER. and install it, and reboot your computer
IT WORKS :-)
Was this helpful?
Yes
No
Solution #7
posted on Apr 07, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
HOLY ! After trying everything from downloading new drivers, to defragmenting, I was ready to give up on my acer crystal eye web cam. With nothing left to loose I tried the easy approach and simply moved my pictures into my documents folder- IT WORKED ! what the heck??? :)
Popular Solutions for Acer Aspire 5610-4648 PC
Questions and Unsolved Problems for Acer Aspire 5610-4648 PC
Do you recommend Acer Aspire 5610-4648 (LX.AXZ0X.097) PC Notebook?
Answer
Answer
my webcam isnt working? but im sure i have one and the microphone
Answer
i use sometouch pad sticker,how it removes.plz help me my id is fathimanasir100@gmail.com
Answer
MyWinLocker geeft problemen. Wil zoom herstellen van verwijderen!
Answer
do this series come with a webcam. if so, or if not, how do i access it.
18 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Mar 14, 2008
Same problem as many others - just simply hasn't worked at all since I got the TravelMate 6492 last week... Please supply a permanent solution ASAP, as the ability to Skype overseas family is ruined! Have attempted to re-load drivers & utilities (Acer & Bison) without any luck.
Comment by jambo1874, posted on Feb 06, 2008
I have a Apire 5520 and again my crystal eye web cam did not work, but as soon as i moved my pictures into a documents file, it works fine, i can't believe that the simple solution to make you webcam work is to move your pictures.
Comment by zosia, posted on Jan 25, 2008
I have an Acer notebook 7520 (ONE WEEK OLD) and have the same problem. The solution indicated works although it is weird and impractical!
Comment by Guest, posted on Jan 13, 2008
I had the same problem with my Acer Aspire 5520 and I moved my pictures into documents folder and it fixed my webcam issues.
Comment by Guest, posted on Jan 09, 2008
a problem caused the program to stop working correctly windows will close the program and notify you if a solution is available
Comment by 1cheesehead, posted on Jan 02, 2008
Mine worked four or five times the first day. But no longer. I even went back to a restore point from day 1. Still no luck. ACER please HELP!!!
Comment by Hsd0515, posted on Jan 01, 2008
Acer Aspire 5520-5912 Notebook A problem has caused the program to stop working correctly. Windows will close the program and notify me if a solution is available.
Comment by Guest, posted on Jan 01, 2008
same problem - worked once - tried uninstall and reinstall of driver and application software - same problem - i do not have a fix.
Comment by FH-Laptop, posted on Dec 30, 2007
Unable to run the Crystal Eye Webcam program. I worked briefly when we first got the computer, but now it closes and says there is a problem.
Comment by Guest, posted on Dec 29, 2007
Exact same issue. I just got it for x-mas and it worked once and not again after that. I keep getting the same message as noted by the other user.
Comment by jdcd7406, posted on Dec 29, 2007
its not working when i click on it
Comment by Guest, posted on Dec 17, 2007
Same thing Same story
Comment by Guest, posted on Dec 01, 2007
Thoyn's crystal eye webcam problem
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire 5610-4648 PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
