Question about Watches
Pocketwatch quit working
My pocketwatch (Colibri PSW 95941W) had the batteries die and when I replaced it, the second hand wouldn't move. It sort of goes back and forth but doesn't go anywhere. Any ideas/solutions? Thanks for your time.
Stephen
[email protected]
  • 183 Answers
If the battery is good...
then go to a watchmaker/technician and have them put it on a cyclonic for a few moments with a drop of gear oil on the plate to free up the gear train. Sometimes they can get sticky in pocket watches. These are typically watches that arent sealed very well. If running it on a cyclonic doesnt work then you will most likely need to have the watch serviced. I suggest NOT letting them overhaul the watch but instead instructing them to replace the watch movement. The watch movement in Colibri's is usually a Myota and only costs a few bucks wholesale. A reputable repair house will only charge for labor and the new movement rather than tell you the movement needs to be overhauled.
I dont recommend trying this particular repair yourself.
Posted on Sep 17, 2009
  • 14 Answers
Stephen,
Pocket watches are watches the collect dust (from the pockets they sit in) very easily, so you may have an issue here with that being the cause of why your hands are not moving as they once did. Then again, it could be VERY easily that you went to a place to have them replaced and the battery you purchased was "aged" and no longer has power enough to make the watch function properly. I would suggest that if you replaced it yourself in a place where you bought the battery and went home to put it in, go to a place where they put it in for you as they will overturn the stock much quicker. If the clerk is someone of real knowledge they will even be able to tell you "we sell a 20 of that one every week" or something of that nature. As I have suggested to others this is the time of year where quality of service for a small watch battery is much less then it will be when you go in in 5 weeks when the store is happy to see someone.
Posted on Dec 01, 2007
SOURCE:
What type of battery I need to buy for Colibri touch senzor lighter ( model 70-80s )? Thanks
they do not have a battery when they quit you throw them away and buy a new one
Apr 30, 2016 | Colibri Watches
I just bought an Emporio Armani AR2020 wrist watch and when I received it, the hands on the watch wouldn't move. Do I need a battery for the watch? Is it broken?
That specific watch has a quartz movement, and it does not have a sweeping hand that moves to count the seconds. If the hour and minute hands are not moving there is a possibiliy that the battery has died. If after the battery is replaced and the hands still do not move then it's an issue with the quartz movement.
Dec 25, 2012 | Watches
Pocket watch hands try to move but just can,t
Hi.
Pull the hand adjust out and move the hands back and forward to make it hasn't seized up, also try another battery just in case the other one is not fully charged up.
Regards.
Dec 08, 2011 | Colibri Watches
Battery required for colibri lasertron lighter
This lighter would normally use a CR1240E-T lithium 3 volt battery. If you still have an old flat battery, it can be charged if you know what you are doing. OK, so you don't have an old battery, so there are 2 types of battery that you can use to sort the problem. A lot of advice out there suggests using a CR1225, with a little packing to make up for the lack of thickness, this I have found barely works, as the capacity is so low to start with. And now for the real solution........ I use two silver oxide 391 batteries (11.6mm X 2.1mm @ 1.55volt each). With bits of paper to insulate the positive poles from shorting, and more paper to insulate the screw down cover from touching the top battery. The whole thing takes only a couple of mins, and you'll have months worth of bright red light and powerful sparks. Good luck John P. [email protected]
Feb 21, 2011 | Colibri Watches
Sweep second hand sticking on colibri pocket watch. How can I correct. I just had battery replaced.
mcdevito75 here, This is a very common problem easily fixed, when the battery was change the repair prerson could have interfered with the seconds hand bending it ever so slightly so it hits the other hands or it became loose, return to the person who changed the battery, they"ll take the back off and fix that seconds hand. Remember this may be no ones fault so I don"t know about any extra charges for service on your watch. This is just my info to you.
Jul 02, 2010 | Colibri Swiss CSQ Pocket Watch
I have a Westclox battery operated wall clock with chicken on face. The battery is new. The second hand tries to move but just "clicks" How can I fix this?
Sounds like it is just worn out.
Sometimes you can replace the generic clock works in these type of clocks. Go online and do a search for battery powered clock works, and see if you can match yours. They are removed quite easily after popping off the clock hands, and removing a nut under the hands that holds the clock works in the chicken.
Here's a link to a site that sells the clock movements... http://www.clockworks.com/
Jun 09, 2010 | Watches
Second hand doesn't move for each second
Your TAG is fitted with EOL (end of life) feature. This is the cause of that 4 seconds interval movement of seconds hand and thus indicating the time for battery replacement. The timekeeping is not affected by this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
Mar 20, 2009 | Tag Heuer 2000 Classic WK1311 wristwatch
How do I change the date on a Colibri Pocket Watch?
Usually all quartz watches are supplied with calendar setting mechanism and it is very simple-
try to pull out crown and you will notice that there are two clicks,so, when the crown is pulled out to the first click, the date can be adjusted by the turn of the crown. When crown is pulled further out (second click)- the watch is in hand setting position and you can adjust time.
Did it help?
Dec 15, 2008 | Colibri PWS-95877-N Pocket Watch
Watches Logo
774 people viewed this question
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
