Question about Magellan RoadMate 700 GPS Receiver
How to delete previous destinations and unneccesary addresses?
On my magellan 700 when you press the zoom out, zoom in and the repeat key at the same time you get a menu called "Final Assembly Test Entry" and none of the options is to reset the user data.
I have the latest 4.32 version software installed. I wonder if the oldest version had the option but it was removed by Magellan on this latest version?
Thanks in advance for any help you might provide me with!!
Rick
  • Anonymous Apr 09, 2008
    i have a navmanF10 navigate don't know how to delete old address.need to find out please.
    Problem Solver:
  • 20 Answers
Sorry Rick but Version 6 is the latest (shows 5.37) Bin the magellan and get a TomTom GO that will do auto updates.
Posted on Jan 08, 2008
SOURCE:
How can you delete individual previous destinations magellan 1470
go to addresses, then tap previous destination and there will be ( should be) an option to delete them.
if you need further help, hust let me know by replying.
bill
Dec 13, 2009 | GPS
How to delete old, unused destinations
Upon powering on, at the user menu press the "-" zoom out key the "+" zoom in key and the repeat button which is on top of your unit. Once your in the "hidden" menu, select reset user data.. your unit will reset and everything will be clean.
- If needed please ask more questions prior to rating -
Oct 23, 2008 | Magellan RoadMate 700 GPS Receiver
Roadmate 700/760 freezing/locking up
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.
Feb 29, 2008 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 360 reset
Called Magellan tech support, According to them you can't delete previous addresses, the unit will just override old destinations as you put in new ones.
Dec 01, 2007 | Magellan RoadMate 360 GPS Receiver
Deleting previous destinations and unneccesary addresses
goto prefences/deleate active track, should also be able to clear it if it was placed in routes by checking folders and select it,next press menu, then select deleate
Nov 30, 2007 | Magellan RoadMate 700 GPS Receiver
wouldnt buy another magellan at any price because of the problem of trying to find a solution and getting repaired
Nov 09, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700
J...
at the user menu press the "-" zoom out key the "+" zoom in key and the repeat button which is on top of your unit. Once your in the "hidden" menu, select reset user data.. your unit will reset and everything will be clean. If your trying to delete specific addresses I would use software to sync up and explore your MRM's files.
Nov 03, 2007 | Magellan RoadMate 700 GPS Receiver
Reset
Yes, you can reset.
Access the secret " " menu and reset user data, you'd be amazed at how much that can fix. At user menu (after reset) press "-" and repeat key at the same time. select "reset user data". Also, if your having GPS problems, you can also select reset GPS data.
Post again if this doesn't work for you.
-Daniel
Sep 18, 2007 | Magellan RoadMate 700 GPS Receiver
My GPS cannot locate my own position
Try GPS data reset. At user screen push the zoom out key and repeat button at the same time. Select Reset GPS data. This will reset the GPS settings. If after this you are still not getting any signal then you may have a loose RF cable inside your unit. If you feel comfortable opening up your unit and making sure the grey or black cable going from the big (main board) board to the board attached to the rear housing, then do that. Of course this is at your own risk. If you still get nothing after that, it may have something to do with your antenna, which you'll need to take off prior to opening your unit. Turn the antenna all the way out (past perpindicular to the unit) and pull straight out. make sure the connector isn't bent. Keep me updated if anything changes. _Daniel
May 06, 2007 | Magellan RoadMate 700 GPS Receiver
Does not clear prior destination
This seems to be just a software problem, re-installing the software should fix it. Before that though, try resetting user data. At user menu, press "-" zoom out and repeat button at same time. select reset user data, it will reboot automatically, then check to see if it is any better. If not, hopefully the software came with your unit and you can re-install it. Good luck and let me know if you need help with the installation. thanks, Daniel
Mar 03, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
278 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
