Question about Philips 55PP9401 55" Rear Projection Television
No power we had a problem with the sound then picture went black and white then unplugged and plug back up and will switch on and back off like it has a short
  • 934 Answers
Irene,
What's happening is that the Tv is cycling. The shutdown circuit is finding a problem whereby the voltages are too high causing the circuit to activate the shudown. the minute the voltages drop within range the micro reinstates the relay trying to power the unit back up..
Your set - with the exception of the micro circuit design is the same as a Hitachi 53UDX10B. It could be something as simple as a couple of caps failing to a component failure. Only way to tell for certain is to trace test the varoius voltages from the regulator forward through their various stages..
My advice is find a good reputable shop and try and take the unit to them for testing and repair. By taking it to them you'll save the pickup and delivery which in some cases could be a hundred dollars.. But from what you're describing it doesn't sound too serious and the Tv is doing what it was designed to do - shut it down to prevent a major problem.
Good Luck
Bill
Posted on Nov 30, 2007
Sony rear proj tv, no picture, menu appears, but in three seperated colors pin cushioned.
Best to first if you have not done so---UNPLUG the set for several minutes and plug back to power to see if that fixes it (it does a lot of the time especially if you had a power outage).
Nov 30, 2012 | Sony Televison & Video
Sony Bravia - no picture, no sound. Just a blank screen. We were watching a show and the screen went blank and no sound.
First thing to try: unplug from the wall; count to ten; plug back in; try again
Second thing to try: unplug from the wall; count to 10,000 (or wait 10 minutes or so); plug back in; try again
#1 worked for me when it would power on with no video, no sound, just small green light + white logo
Dec 06, 2010 | Sony KDF-E42A10 42 in. LCD Television
The tv went black no sound or picture. We
U have a solid green light from the LED power light indicator right?U have this DLP tv for awhile like two or three years,and use it alots right?Never change the lamp and the ballast right?Change the lamp and the ballast should solved ur problems.
Apr 01, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
My Vizio vx32L isnt getting power. the orange light comes on when plugged in but when you power it up the white light comes on but no picture. and it wont turn off unless you unplug it. please help me
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Nov 12, 2009 | Vizio VX32L Television
Sceptre LCD TV power come on, but there is no picture or sound.
There are two easy fixes you can try. Both require you to take the back panel off. If you are not comfortable doing this, take it to a repair shop.
UNPLUG IT.
Place the TV face down on a soft/solid surface.
After you get the back panel off, there are three silver boxes. There are white and black wires leading from the off switch to the top silver box. Take the cover off that box.
Inside is a ceramic fuse. Test that fuse. If it is blown, your local electronics shop can find a replacement.
If not, disconnect the white and black wires from the PC board. Remove the 6 screws holding it in place.
Look for scorch marks under the board.
Cut a thick piece of plastic and tape id down over the scorch marks.
Re-attach the board with the six screws and re-connect the black and white wires.
Turn the power switch to the OFF position and plug in the TV.
Turn on the power switch while WATCHING the board you just removed.
If you hear a sizzle, turn off the switch and get a thicker piece of plasic.
If not, the TV should come back on.
Re-assemble the silver box and put the back on.
Hope this helps.
Jun 08, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
LG 22" LCD Screen went white
same things happened to me...did you solve this?
Jun 08, 2009 | LG 42LC2D 42 in. LCD HDTV
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
Power led blinks but no picture or sound
Had the same problem myself. Took some doing but I managed to find a service bulletin that I downloaded. The problem is with the siene module and all you need to do is unplug connector JP63A from the main board and your TV will work again.
Take the back off the TV (there are a lot of screws) and look on the left hand side of the main circuit board that is mounted in the center of the TV. You will see a small white connector that is labelled JP63A, simply unplug it. Plug the TV back in and let it reboot. That's it, should be able to watch immediately.
Aug 15, 2008 | Toshiba 50HPX95 50 in. Plasma HDTV
Philips 55PP9401 55" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
